394xp
Discussion in 'Chainsaws and Power Equipment' started by denny461, May 31, 2015.
  1. redneckdan
    redneckdan
    Northern Minnesota
    I had my 395 set pretty fat. Running a 36" bar with an 8 pin I had to be cutting a really full saw buck for it to clear up. I'd like to get a tach after I get it rebuilt so I can be a little more scientific about the tune.
  2. Gunn
    Gunn
    Plover, Wi
    I got a tach just to see where my tunes were. I found out I was pretty conservative after taching a saw.
    Moparmyway, foragefarmer and mdavlee like this.
  3. denny461
    denny461
    Scipio, indiana
    I can't wait for the muffler to get here so I can run it again.
    I am no mechanic but when I pulled the old muffler there were some burs in the cylinder from the studs when the tree smashed which caused the exhaust to blow past the gasket. So I took a file to the face of the exhaust port to knock the burs down and was surprised to see how many high and low spots it had.
    The new muffler is a nwp from baileys. Has anyone used an aftermarket muffler before.
    Does anyone think it should change to tune of the saw. As far as tuning the carb I mean.
  4. Gunn
    Gunn
    Plover, Wi
    Hard to say, usually Chinese mufflers are slightly different than oem. Whether it's port sizes, internal baffle layout (in some cases no internal baffles), different specs for spark arrestor screen mesh, etc.
    It should be pretty close but you won't know until you fire it up.
    denny461 likes this.
  5. mdavlee
    mdavlee
    I used a hyway on a 395 if I remember right. It was fine for a stock saw. The tune will have to be checked with the new muffler.
    Moparmyway and denny461 like this.
  6. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Im running a Hyway on the 460. I was pleasantly surprised by the quality and loved the larger outlet hole and no baffle. The paint blistered after a few tanks, but it can be repainted w stove paint. Id recommend them as a cheap alternative to OEM.
    MasterMech, Moparmyway and denny461 like this.
  7. denny461
    denny461
    Scipio, indiana
    good to here that there not all that bad. for no more than what I have in the saw I didn't want to sink 100@ into a muffler. I would rather put the money saved toward chains and feul:D
    Moparmyway likes this.
  8. Gunn
    Gunn
    Plover, Wi
    You should be fine. The 394 muffler is a box. I had issues with my hyway 064 mufflers. Both had the guarding from the front cover vibrate off. The spot welds didn't hold. But 394 shouldn't be an issue.
  9. mdavlee
    mdavlee
    The hyway are a little thicker than oem as well. Nicer to weld on for me.
  10. denny461
    denny461
    Scipio, indiana
    I got home last night and the new muffler was waiting by the door. I installed the new muffler and started it up. Started like it did before. Sounded pretty good. I will cut with it tonight.
  11. denny461
    denny461
    Scipio, indiana
    Not really happy with the muffler. Saw did not have as much power than before. I took a chisel and a hammer and knocked the pipe inside the muffler away from the exhaust opening on the side of the muffler. This did not make much difference. I for some reason can't get a saw shop to check the tune on carb because of the muffler.
    The saw starts and idles fine but it only dumps the chips at your feet instead of throwing them 10ft out the back.
    Any suggestions or thoughts on this would be appreciated.
  12. mdavlee
    mdavlee
    Do you have a tach? Got any pictures of what you did to the muffler?
  13. denny461
    denny461
    Scipio, indiana
    No tach. Thats why I was taking it to saw shops. I could get some pics uploaded tomorrow at work.
  14. mdavlee
    mdavlee
    Ok. Is it blubbering in the cut or screaming?
  15. denny461
    denny461
    Scipio, indiana
    Still blubbering. My gut says it needs leaned out or the muffler needs opened up.
  16. SquareFile
    SquareFile
    somewhere
    What's your H screw set at? Factory spec is 3/4 out. Wj39 will feed a lot of fuel from the L side. Sometimes enough the H can be closed.
