372xp XTorq unlimited coil
Discussion in 'Chainsaws and Power Equipment' started by J. Dirt, Jan 14, 2018.
  1. mdavlee
    mdavlee
    Oem jug?
    p61 western and J. Dirt like this.
  2. J. Dirt
    J. Dirt
    Yep bought the saw brand new almost a year ago. Maybe 10 tanks through it. Not a ton of use.
    concretegrazer and p61 western like this.
  3. mdavlee
    mdavlee
    Ok. Just wanted to make sure. Seen an aftermarket top end have plating flake and it wouldn't hold a tune. Have you taken the carb apart and checked metering lever height?
  4. J. Dirt
    J. Dirt
    Not yet.... just getting into this one so I’ll make sure I check it!
    By the way...Thanks for the help so far!!
  5. J. Dirt
    J. Dirt
    This was the best run this afternoon. Still on the unlimited after market coil.
    Notice the idle out of the cut, then the idle after I cleared it.
  6. Fabz
    Fabz Banned
    Buffalo ny
    Did u check fuel filter ? If good try new fuel lines ... could have a pin-hole and as the tank empties it sucks air ...
  7. J. Dirt
    J. Dirt
    L 1 turn, H 1 5/8 turn, the T screw (what I called LI earlier) almost has the throttle cam sitting on the threads, barely on the ramp of the screw. 4AE9D12B-A6D0-433E-A300-BE52D8BFF0E1.jpeg
    I checked and had 153 psi compression cold.
    blacksmith and huskihl like this.
  8. mdavlee
    mdavlee
    It sounds pretty rich on H but shouldn't be enough to load it up like that. Maybe lean the H out a little and richer the L if it doesn't make it sluggish.
    huskihl and J. Dirt like this.
  9. J. Dirt
    J. Dirt
    Just getting up there in R’s it seemed on the high end I thought in the 13,300 neighborhood? I know you said stay under 13,5 but I’m getting a bit worried or shouldn’t I be? I’ve got 40:1 in it now too.
  10. mdavlee
    mdavlee
    13.3-13.5k should be fine. That could be your problem.
  11. J. Dirt
    J. Dirt
    To rich on the high end? Then slamming the throttle closed at the end of a cut the fuel that’s blasting in has no were to go and causes an instant rich stall? Makes sense... if I’m trying to keep it from stalling and tickle the throttle I can usually save it.
    huskihl and The Wood Wolverine like this.
  12. The Wood Wolverine
    I’m not 1/1000th the saw guy Mike is, but the symptoms you describe, if someone came into the bike shop describing them, I’d think float bowl level. So maybe something to the metering lever height?
    J. Dirt likes this.
  13. huskihl
    huskihl
    That right there is spot on. The chamber, plug, and case are too rich for an instant idle.
    J. Dirt and The Wood Wolverine like this.
  14. J. Dirt
    J. Dirt
    Tomorrow! The quest for the perfect tune continues!! :saw:
  15. The Wood Wolverine
    Learning from you guys fer sure.... I make the 394 pig rich to mill with and I’ve never had those symptoms. Course, I ain’t bucking with it the either.
    J. Dirt likes this.
  16. huskihl
    huskihl
    The added heat from milling is probably burning the added fuel. You might notice it at 1/4 or 1/2 turn richer. I see it on most saws when I do a rebuild, as I always start rich and work my way up to a good tune
  17. J. Dirt
    J. Dirt
    Could some of my trouble be due to things finally breaking in?
  18. J. Dirt
    J. Dirt
    Same here! Thanks for the help guys!!! Keep it coming!!
  19. beaglebriar
    beaglebriar
    North Bumphuk, Pa
    A slight tear in the fuel line where it passes through the floor plate can happen on these saws. That will mess up your tune for sure. Being used that little I doubt there's a problem with seals or anything like that.
    I have a good limited coil you can try if you want to. Where in NY are you located?
    J. Dirt likes this.
  20. concretegrazer
    concretegrazer
    Southwest MO
    Was it running fine before you started messing with it?
    J. Dirt likes this.
