3/8" vs .404"
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Nov 29, 2014.
  1. Jon1270
    Jon1270
    Pittsburgh, PA
    Any idea by how much?
  2. mdavlee
    mdavlee
    I haven't measured but probably 1/8" at least. I'll try to get a measurement here shortly.
  3. Freakingstang
    Freakingstang
    its probably very close to 1/8" wider.. those 404 teeth seem HUGE compared to 3/8.
    growing up real close to Amish logging country, most loggers used an 046/460 with a 20" 404 bar. There was a few that ran 066/660's with a 24/25" for the big hardwoods.. they claimed it held an edge a ton longer with the wider tooth/kerf.
    mdavlee likes this.
  4. MasterMech
    I believe it.
  5. Moparmyway
    Moparmyway
    New York
    So do I
    Hedgerow likes this.
  6. Kg461
    Kg461
    Provencal, La.
    Very nice!!!
    Moparmyway likes this.
  7. Birddogtg
    Birddogtg
    Central ohio
    404 is great chain if you have a big enough motor, the problem with it is it will not bore with a 11 tooth sprocket so if you do a lot of boring in a logging situation you will need a 13 tooth sprocket nose.
  8. MasterMech
    oooOOOooo, pretty!
  9. Moparmyway
    Moparmyway
    New York
    91cc and 92cc powerheads
