3/8" vs .404"
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Nov 29, 2014.
  1. Ron660
    Ron660
    NW Louisiana
    Dave, using a RS chain square filed? Is that 385 ported?
  2. mdavlee
    mdavlee
    Yes and no it was stock. I may be able to get a video of it ported in a day or so.
    DexterDay likes this.
  3. Kg461
    Kg461
    Provencal, La.
    Will the 404 put more of a load on the saw and cause alil more engine temp than 3/8? Any harder on the bearings and crank?
  4. mdavlee
    mdavlee
    It can load the saw more depending on how aggressive the chain is filed.
    Kg461 likes this.
  5. Kg461
    Kg461
    Provencal, La.
    What about wear on the saw?
  6. MasterMech
    Changing the chain will not change how much power the saw puts out. At worst I think you might drag the RPMs low enough to make stalling the chain easy and perhaps see a bit more clutch wear but I can't see it doing anything terrible to a saw 70cc and up.
    You really need a saw with big brass ones to see a performance gain over 3/8" however.
    JustWood and Kg461 like this.
  7. mdavlee
    mdavlee
    The gain is time between sharpening and longer tooth to last longer.
  8. Kg461
    Kg461
    Provencal, La.
    Been pondering the idea of a 24" 404 bar on my ported 461for noodling
    Oliver1655 and mdavlee like this.
  9. mdavlee
    mdavlee
    That or a 28" is what I'm planning on.
  10. Kg461
    Kg461
    Provencal, La.
    Think ill wait until Cannon releases their lw bars in october before I buy another big bar. Ill stick with my 28es light for now that is if it dont blow my saw up!!! Lol!!
    laslabjohn and mdavlee like this.
  11. mdavlee
    mdavlee
    I sold both my stihl light bars. I had planned on some tsumura but I may hold out til cannon gets theirs done.
    Kg461 likes this.
  12. Kg461
    Kg461
    Provencal, La.
    I love the es light but I would rather have a Cannon . Back to the 404 just a scenario. If u took the same saw with 28" bar one with 404 and one 3/8 and buried the bar for say 15min. Of cutting. Which setup do yall think would run the most engine temp. Or would they be the same?
  13. mdavlee
    mdavlee
    I would say after 15 minutes they'll even out
  14. Kg461
    Kg461
    Provencal, La.
    Now u got me thinkin??!!! Lol! Why after 15 minutes?
  15. mdavlee
    mdavlee
    I would think it would be heat soaked completely by then.
    Kg461 and MasterMech like this.
  16. DexterDay
    DexterDay Administrator
    Northeast Oh
    X2... After that long? The saw has reached its max temp.
    Chad did a test with the 660's and tested temp. If I recall, after about 5 minutes, the saw never got any hotter. It reached an equilibrium. It can only generate so much heat and produce so much cooling air.
    mdavlee and Kg461 like this.
  17. Ron660
    Ron660
    NW Louisiana
    I've always wondered what the normal engine operating temperature of a chainsaw engine is. Since they don't have thermostats I wonder what the max temps are??
    What was the max engine temp?
  18. DexterDay
    Northeast Oh
    I would have to look it up on AnotherSite.
    Ron660 likes this.
  19. Jon1270
    Jon1270
    Pittsburgh, PA
    Are there standard kerf widths for various chain pitches? Does .404 necessarily make a wider cut?
    Kg461 likes this.
  20. mdavlee
    mdavlee
    It does make a wider cut.
    Ron660 and Kg461 like this.
