3/4 ton gas truck suggestions
Discussion in 'Chainsaws and Power Equipment' started by capetownkg, Jan 16, 2014.
  1. OhioStihl
    OhioStihl
    Southern Ohio
    At first glance I liked the tan truck however, it has 285 tires on stock rims. The rims are not wide enough for the 285 tires so the tread tends to be rounded instead of square. They will wear out faster and if you wreck because of a blowout the insurance company will turn their back on you. I know it sounds like I am reaching but it is what caught my eye. Just be careful not to overload the truck.
    I like the interior of the gray truck better. The center console is great to hold odds and ends. If your going to haul with a trailer your fine. If you are going to use the bed then the short beds will fill up fast. Also, the heated seats tend to crap out but isn't too bad to fix. I have had the standard mirrors and the tow mirrors, the tow mirrors work great when pulling. If you are not going to haul a gooseneck you might be able to sell the hitch. If you want to keep it, you can get a insert that has a tie down attached to it instead of a ball to help secure odd loads.
    I am having a great time while you look for a truck. I love truck shopping and it isn't my money. This is fantastic!
  2. the GOAT
    the GOAT Banned
    Maine
    I hate truck shopping -- probably why I've had the same truck for almost 16 years.
  3. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    My '83 K-30- 4x- bullet proof drivetrain, 7.4 gasser,-
    $535 purchase. $400 for new valve seals and other stuff. 65mph top speed- (4.56 in the pigs), I'll go 300 miles rnd. trip on occasion for 1.5 cord, including trailer.
    That additional 16K would buy a lot of gas.
    the GOAT likes this.
  4. capetownkg
    capetownkg
    southern, MD
    Beats the sticker price on a new one! Always a truck market.
  5. capetownkg
    capetownkg
    southern, MD
    Beetle-Kill I would love it if you came and rebuilt a truck for me! :rofl: :lol: I will come out to the divide and you come out to southern maryland. I miss those mountains and snowboarding. I worked at winter park years ago, time of my life!
  6. lukem
    You might be able to drive that truck 35K miles on $16K in gas...
    basod, the GOAT and Beetle-Kill like this.
  7. Beetle-Kill
    Beetle-Kill
    Capetownkg, Winter Park is literally my backyard, if you follow my canyon and go over the Divide. I pull lots of wood from Fraser and Tabernash, but coming back over Berthoud with a full load and no trailer brakes can get a bit ...uhmm.. uncomfortable?
    Question?- did you ever fart around up in the Vasquez drainage? Love that area.
  8. the GOAT
    the GOAT Banned
    Maine
    But you'd have to drive like a 100k miles to break even on the purchase price of $16k for a truck that gets ~4-5 MPG better.
    (hope my math isn't too far off -- it's my justification for keeping the V10)
    Oliver1655 likes this.
  9. capetownkg
    capetownkg
    southern, MD
    Awesome! I lived in granby and worked the timberline lift the last year it existed. Been over Berthoud in some hairy conditions thats a heck of a pass. Literally the divide was what I looked at every day.
    Beetle-Kill likes this.
  10. Beetle-Kill
    Beetle-Kill
    "Hairy" is an understatement my friend, especially back-in-the-day, before it went to 3-lane. I could tell you stories..........:eek:
  11. Beetle-Kill
    Beetle-Kill
    Mike From Maine- my beater '83 does 9-10 mpg on average. It helps ( I think), to have the secondaries on the Q-Jet not operational. Loaded or un-loaded, still has the same exceptional gas mileage. :cool:
  12. MasterMech
    You've got to be missing out on some substantial amounts of power with no secondaries. Are they vacuum or mechanical? (I'm too young to remember! :rofl: :lol:) We had an '85 454 in a farm truck. C-30 Dually, 4 spd Reg Cab Flatbed. All it did was pull a 24ft Steel Cattle Trailer and suck down gas from dual tanks. Had to take a tractor with you if expected to get it back out of the fields. :)
  13. Beetle-Kill
    Beetle-Kill
    MM, if you have any insight on a good replacement carb. / intake manifold set-up for this tank, I'm all ears. This is my first BB, don't want to stress it too much, I've been told they don't like RPM's above 3500.
  14. MasterMech
    While I'm pretty familiar with the Big-Block pickups from '88 onward, there are others who are much more knowledgeable than I in the subject. I do know my '89 makes max HP at 3600RPM so you may be right about them not liking higher revs. But that could be due to the ridiculously restricted heads ("Peanut Port") rather than any sort of bottom-end weakness.
    The restrictive heads, while part of why these engines make gobs of torque at barely above idle, are also why putting a bigger manifold/carb on the engine will not necessarily yield better power. I don't think the Quadrajet was such a bad unit if it's rebuilt back to specs. They were on an awful lot of these trucks.
    jeff_t and Beetle-Kill like this.
  15. basod
    basod
    Mount Cheaha AL
    That's not terribly bad considering the 4.56 gears.
    Considering you're running 2 barrels all the time now, a holley 650 would probably suffice, going to 700/750 would probably keep the secondaries disengaged unless you really stomp on it.
    I have Holley 600cfm on Ole blue(350) they only open up on a couple hill climbs - granny low up the driveway for sure.
    The sound of a quadrajet engaging is too awesome to not have hooked up:thumbs:
  16. MasterMech
    The stock TBI unit on my '89 is rated right around 650cfm IIRC. So a 6-750 should be plenty feeding a truck 454 with the peanut port heads.
  17. basod
    basod
    Mount Cheaha AL
    I'm not a big fan of the '03-07 nose so my bias leads me towards the gray 02. The gooseneck hitch on the tan truck always makes me wonder how much the truck was pulling - probably a camper and most of it's life.
    I wouldn't pay anywhere near that for either truck though 10-12k at most
  18. Beetle-Kill
    Beetle-Kill
    My problem, up here, is getting more air in the system, not fuel. And then, getting that spent air/fuel out. I shall work on it.
  19. Hinerman
    Hinerman
    NE Oklahoma
    See video for real world (not my world for sure)...Tundra does have bigger brakes and stiffer frame. Thank Toyota for the improvements in the US 1/2 ton trucks
    Tundra is not a Cummins,,,,no kidding. But it is a truck. You are right---they are reliable. See video.
    According to these guys it does. See video.
  20. OhioStihl
    OhioStihl
    Southern Ohio
    Capetownkg, did you ever find a truck? If so, please show us some pics. I like looking at truck porn!
    Chvymn99 likes this.
