27" Wide Ash vs MS880 + video
Discussion in 'The Sawyer Room' started by Shawn Curry, Jan 31, 2016.
  1. Eric VW
    How about a sloped Dray?
    1964 262 6 and Shawn Curry like this.
  2. Shawn Curry
    Shawn Curry
    Western NY
    Hmm interesting. I guess anything that could lift one end would work if you put something under it for support which is a good idea anyway.
    1964 262 6 and Eric VW like this.
  3. Eric VW
    On that note, using a farm Jack to get your log up on one end per mdavlee's suggestion, you could then support the log with cribbing and remove the Jack, no?
    1964 262 6, mdavlee and Shawn Curry like this.
  4. Eric VW
    Yes, this post is redundant to your post that I quoted.... I see that now. But still reinforcing.:whistle:
  5. mdavlee
    mdavlee
    I cut squares and stack them under the ends.
    1964 262 6, Shawn Curry and Eric VW like this.
  6. bocefus78
    bocefus78
    Indiana
    Engine cherry picker, then crib it up and ditch the picker?
    Sink a 6x6 post in your milling area. Use a boat crank winch on pole, run cable up pole, thru a pulley, and back down to log? This assumes you mill in the same spot.
    Just throwing ideas out...I've never milled anything (yet)
  7. mdavlee
    mdavlee
    If the log is small enough a block or round and a longer piece to pry it up and then someone else puts the cribbing in
  8. bearverine
    bearverine
    Winchester, Indiana
    Dang it. Watched the first one, then clicked on the video of Farm Girl fishing on the river and experienced 2 hrs of lost time..... Dang it.
