2018 & 2019 Firewood Work
Discussion in 'The Wood Pile' started by thewoodlands, Aug 24, 2018.
  1. MikeInMa
    Can't like this enough. It does suck. Real temps 95 and higher. Dewpoint low-mid 70's.
    Changes in air masses forecasted for Friday. Until then, sitting/sleeping under ceiling fans in AC, like the majority of July and August.
  2. thewoodlands
    thewoodlands
    Just before the first bad heatwave moved in earlier this summer, I pulled a muscle in my back so the window units never were put in, our basement is between 68-71 with a TV,stereo and small fridge with a couch and recliner so that is where I've been hanging out.
    I have some stacking to do and then it's off cutting in the woods. Since last year was a chitty year for sledding we're hoping for some early snow and cold so we can run the sleds.
    Maina, T.Jeff Veal, Chaz and 6 others like this.
  3. MikeInMa
    Oh.... just saw where tonight's low is to be 76. Avg daytime high this time of year is 78.
    I know temps elsewhere are much higher, but this region's population isn't used to it. Schools that have opened, are having early dismissals due to heat and no AC.
  4. MikeInMa
    Sorry to hear about your back. I hope it's gotten to feel better.
  5. thewoodlands
    thewoodlands
    The back is just fine, it took about a 45 days for it to be 100 percent.
    Maina, T.Jeff Veal, Chaz and 4 others like this.
  6. thewoodlands
    thewoodlands
    I did more splitting today and finished the first stack of wood I started yesterday and then started our second stack. I would've kept going but we lost power at the house (an inline breaker kicked out on the line out front) so I hooked up the generator for a bit until the power came back on.
    milleo, Maina, Thor and 12 others like this.
  7. WeldrDave
    Well, I wasn't doing $#!T today! Yes, in the shade temps! DSCN3190.JPG DSCN3191.JPG
    milleo, Slocum, Maina and 8 others like this.
  8. brenndatomu
    That front just came through here about 3 hour ago...wasn't that bad...cooled way off after !
  9. thewoodlands
    thewoodlands
    It's still 75 here with the cold front coming in later tonight, hopefully it isn't that bad.
  10. bear 1998
    bear 1998
    S.C.Pa
    Its still a sultry 81*.... maybe some relief friday....A/C ran pratically all afternoon...
  11. thewoodlands
    thewoodlands
    The last two days we've had cloud cover with some pretty good winds, it was about 86 today and muggy but the ice cold water did the trick.
    We lost power for 45 minutes today so the wife came out to tell me so I called it a day and got the genny hooked up so we would have power throughout the house.
  12. Well Seasoned
    Nice job woody!
    We got hot today around 89°F and the storms pushed through around 6pm-ish. Wind was strong, it rained a bit and has moved through. A few pine came down, but that's it.
    Maina, WeldrDave, Chaz and 2 others like this.
  13. thewoodlands
    thewoodlands
    We had some hard rains earlier too, it didn't cool anything off. It will cool off some and then heat back up just in time for when the kids head back to school.
    Do those pine coming down mean you don't want a pile of our pine logs. :zip:
    Maina, Chaz and bear 1998 like this.
  14. T.Jeff Veal
    Worked Tuesday afternoon and Wednesday morning splitting and stacking some white oak. It's been hot, but I turn the fans around, so that helps. I'm behind on our wood also, so been letting the fans run 24/7.
  15. RI Dan
    RI Dan
    Rhode Island
    Bucked up two oaks that fell on our property this morning. Figured I would get to them before the heat really turned on. While finishing up the second tree someone turned the heater on and I had to call it quits. Will finish up tomorrow morning as the temps are supposed to drop into the low 60's this evening.
  16. thewoodlands
    thewoodlands
    After running into town so we could pick a few things up, I did some work. In pictures 1834 and 1835 I split some pine smaller so if we get a good rain, I can burn the stuff pictured in 1836. The stuff I split in picture 1835 is under cover so it will stay dry.
    In picture 1837,38 and 39 I split some rounds and then did some stacking, I plan on finishing this stack tomorrow.
    milleo, Maina, Chaz and 5 others like this.
  17. Well Seasoned
    Nice processing Woody! :yes:
    Maina, Chaz, bear 1998 and 1 other person like this.
  18. thewoodlands
    thewoodlands
    Thanks Well Seasoned , I'll finish it up tomorrow and then get ready to finish insulating the garage on Sunday morning.
    We decided that we would paint (white) what OSB we put up this year before putting up shelves and workbench.
  19. Well Seasoned
    Good thinking!
  20. thewoodlands
    thewoodlands
    Maina, bear 1998, Chaz and 6 others like this.
