2017 maple syrup season has begun!
Discussion in 'Hobbies and Interests' started by Farmboy707, Feb 19, 2017.
  1. Scotty Overkill
    It was 1/8" stainless sheet, TIG-WELDED together. Pan weighs around 70lbs empty....lol
  2. savemoney
    Love Locally made MS. It is readily available from local producers. Nothing compares to real MS. It is pure taste, no additives. Goes on a lot of food, not just pan cakes. I even dip strawberries in it.
  3. yooperdave
    Wish I was there to help out....
    I miss those days!
  4. Farmboy707
    Farmboy707
    Southern Ontario
    I just drink it straight out of the pan after it cools down a bit lol
  5. yooperdave
    If you have any clean snow left, build yourself a maple flavored sno cone!
  6. JIMBETHYNAME
    JIMBETHYNAME
    Poughkeepsie ny
    This is a serious question as I've never done this before.
    Do you guys just drill a hole and stick the tap in, or is there more too it?
    And once its in, can you turn it on and off?
    Well Seasoned and yooperdave like this.
  7. yooperdave
    Pretty much.
  8. JIMBETHYNAME
    JIMBETHYNAME
    Poughkeepsie ny
    Do you just pick any maple tree or is there certain things that make one tree better than another?
    Well Seasoned and blacksmith like this.
  9. blacksmith
    blacksmith
    central Pa
    You can use any maple tree but sugar maple gives you the best yield!
    Well Seasoned and JIMBETHYNAME like this.
  10. blacksmith
    blacksmith
    central Pa
    Mmmmmmm maple syrup sno-cones! :drool::drool:
  11. blacksmith
    blacksmith
    central Pa
    Scotty Overkill made his own taps. It was made from some plastic hose. I believe it was 1/4" I.D. hose, it was cut at the end so as it looked like a birds mouth.
    The hole that was drilled in tthe tree was one drill bit size smaller that the O.D. of the hose so that it fit tight into the hole that was drilled so that it wouldn't leak around the tube.
    Next we used gallon jugs to catch our sap. We drilled a hole in the cap of a clean plastic gallon jug the O.D. of the plastic hose so it's a nice tight fit. Drill a small breather hole in the cap so ants can't get in but the perssure can be equalized.
    Insert the plastic hose into the cap, drill a small hole through the plastic hose and apply a small ty-rap so the hose doesn't slide out of the cap.
    Force the plastic hose into the tree and screw the cap on the jug and wait for it to be filled! That is a very cheap inexpensive was to collect your maple sap.
  12. yooperdave
    These are what I used to use but without the hooks on them. Just hung cans off of the spouts. The plastic hose set up sure makes life easier!
  13. Scotty Overkill
    I use plastic barbed spiles by U.S. Maple, I started out using the ones blacksmith mentioned.....
  14. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Going to be a slow year unless we get a cold snap. Got these from three trees taped. Mutiple taps.
  15. JIMBETHYNAME
    JIMBETHYNAME
    Poughkeepsie ny
    How far into the tree do you drill? Do you have to reach the center? Or is it just as far as the tap is long?
  16. blacksmith
    blacksmith
    central Pa
    If memory serves me right I think 3/8" to 1/2".
    Well Seasoned likes this.
  17. stuckinthemuck
    stuckinthemuck
    The sap flows through the Sapwood just under the bark. So technically, all you have to do is penetrate the bark and a growth ring or two to get sap to flow. Of course if you did that, your taps would keep falling out so you have to drill deep enough to support the weight of the bucket or jug or sap lines.
  18. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    2-2.5 inches
  19. JIMBETHYNAME
    JIMBETHYNAME
    Poughkeepsie ny
    Thaks for the lesson guys!
    Now for the wiseass question.............
    When the sap is gone from the tree, does it collapse like when you suck the air out of a empty soda bottle?
    :rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
    Sorry, I just had to
    Well Seasoned, Loon and blacksmith like this.
  20. Farmboy707
    Farmboy707
    Southern Ontario
    I go 1.5 inches and i use 5/16 health spiles and hang buckets I have my black walnuts tapped with drop lines into 5gal pails.
