20" bar for Stihl MS 250
Discussion in 'Chainsaws and Power Equipment' started by 94BULLITT, Aug 2, 2015.
  1. MasterMech
  2. jon1212
    jon1212
    Utah........ugh!
    On a stock saw, a weak to average roll out on the recoil will start the saw.
    Brad Snelling had a video of his 8 year old daughter starting a Dolmar 421 with Easy Start.
    concretegrazer and clemsonfor like this.
  3. 94BULLITT
    94BULLITT
    Frederick County, VA
    I found that video. It does look like it is easy to start.
    concretegrazer likes this.
  4. unclefess
    unclefess Guest
    I am thinking of selling it , it is not broken in so that could be the problem it has a 16'' .325 63ga is the 3/8 lp you have the same as the chain on the ms170 or is there a different gauge ,the catalog raises more questions than answers, thanks for the reply.
    clemsonfor likes this.
  5. MasterMech
    Different gauge. The 170 usually runs .043 while I'm running .050. The 63PS chain I use is some pretty hungry stuff. Smooth and fast.
    Run a little more fuel through that saw and see if you like it any better. ;)
  6. unclefess
    unclefess Guest
    so i should ask my dealer about a 3/8 lp .50ga is the kerf the same as .43ga ? this sounds like a great improvement im surprised he never mentioned it, i have been very happy with them over the years and always get a good deal . so ps and ps3 is the differance ?
  7. Oldman47
    Oldman47
    Illinois
    In order to change the chain gauge you also will need to change the bar. Each bar is designed for a particular gauge. Your dealer may have been trying to save you the cost of a new bar.
  8. unclefess
    unclefess Guest
    thanks oldman, im aware of the bar and sprocket needing to be changed but did not know there were different low profile gauges, he did say i did not want regular 3/8 when i asked if the 261 used the same size chain as my other saws , just did not want another file size , the more i try to simplify thing the more complicated they seem to get , its my fault for not asking more questions when i bought it , im sure he would have set it up with a different bar and chain for the same price , i got a decent discount on the saw , as i said they are good to me there as i have bought a lot of stuff other than saws , i was expecting this thing to be like my old 346 husky but the bar change may be the answer .
  9. XXL
    XXL
    Ontario, Canada
    It's of no real use to me so if you're interested, send me your zip code and I'll check on the shipping costs.
    clemsonfor and 94BULLITT like this.
  10. MasterMech
    The .050 PS/PS3 will be a wider kerf than the .043 PMM series chain. In order to convert the 261 to Picco (PS/PM/PS3) chain you need a special bar that's not a very common part. In fact, this isn't a common setup on a saw this big. There hasn't even been a chisel chain available in 3/8" Picco until the last couple years.
    Here's the complete setup.
    Rim is 0000 642 1240
    Chain is 63 PS - 60
    Bar is 3003 000 6313
    unclefess likes this.
  11. Eric VW
    My small saw is a Husky 445 that I enjoy running a 20" bar on. I use Lowe's bought Husky chain on it and it pulls, oils fine. Great for up to 18" felling, bucking and limbing. Easy on the starting, a little picky on hot restart after 3 years in, but not terrible- and my shoulder ain't too good either! Nor my lower back, or the pre-emergent inguinal hernia:eek:
    clemsonfor, unclefess and 94BULLITT like this.
  12. unclefess
    unclefess Guest
    mm, thanks for the part numbers , i used the 261 yesterday i think its now on its fourth tank ( and will get more use as i sold the 391ll ) i will get a price for those parts .
    thanks again
    clemsonfor and MasterMech like this.
