20"-24" Saw Opinions
Discussion in 'Chainsaws and Power Equipment' started by Zack323, Jul 4, 2023.
  1. The Axeman Commeth
    The Axeman Commeth
    Fridley MN
    Thanks for all the advice on the 440. I snoozed and loosed. Got sold already. Must have been a good deal.
    T.Jeff Veal, Screwloose and FarmerJ like this.
  2. JD Guy
    JD Guy
    Upstate SC
    Don’t wait on the MS 261 then, it’s going to be gone too! But if you just have to have 24” bar capability then pass…
    Zack323, Stephiedoll and T.Jeff Veal like this.
  3. Zack323
    Zack323
    Douglas, WY
    I think I'm sold on a 4910 20". I can do the exhaust modification and intake modification myself. I like the warranty they carry. After all, I'm only cutting pine (and clog my chimneys haha). If I really like the saw, I will buy a new one down the road and send it directly to someone to be ported. As a former motorcycle mechanic, I can appreciate working on something new vs. used.
  4. Zack323
    Zack323
    Douglas, WY
    I'm sold! I've watched and read too many reviews. The saw impresses me. I'll be ordering next week, most likely through Home Depot. Generally easy to get things replaced if something goes wrong.
  5. MasterMech
    Chainsaws tune differently than cycles or other two-stroke tools. It's because we tune them with no load at RPMs significantly outside of their typical working range. And yeah, we gots self-tuning saw engines these days! (Stihl M-Tronic, Husqvarna AutoTune) Fuel injection is a thing too.
    T.Jeff Veal and JD Guy like this.
  6. JD Guy
    JD Guy
    Upstate SC
    MasterMech and T.Jeff Veal like this.
  7. huskihl
    huskihl
    I believe Sawdust Man has a minty newish Shinny 492 for sale at a respectable price. Same as a 4910
  8. Sawdust Man
    Sawdust Man
    Truth.
    I'm asking $325 shipped.
    It's burnt about 10 tanks of e-free mixed at 40:1 with echo red armor.
    Just listed it on evilbay on Saturday, but I'd gladly sell it direct.
  9. Canadian border VT
  10. Zack323
    Zack323
    Douglas, WY
    What do you mean by 'tune them with no load at RPMs significantly outside their typical working range'? For me personally, I'm not looking to get too carried away. I'd like to scream through 16"-18" Ponderosa Pine or Lodgepole. At this stage in wood cutting, I could use a faster saw for efficiency.
    T.Jeff Veal likes this.
  11. isaaccarlson
    isaaccarlson
    Colfax, WI
    The max rpm on my 350 isn't much higher than the rpm in the wood.:D
  12. FarmerJ
    FarmerJ
    Minnesota
    You basically turn the fuel up until it is over revving and “4-cycles” or changes tone.
    that way when you’re hogging into wood hard, it’s got sufficient fuel to get the job done.
    T.Jeff Veal and Zack323 like this.
  13. MasterMech
    Because of the difficulty in tuning the carb under load, we tune them with no load and then listen to how it responds to load in the wood.
  14. MasterMech
    I swing through occasionally still. Haven't burnt wood for heat in six years now, but love to see some familiar names here from time to time.
    Chvymn99, Screwloose, thistle and 5 others like this.
  15. JD Guy
    JD Guy
    Upstate SC
    Nice to see you “stopping by” :thumbs:
  16. isaaccarlson
    isaaccarlson
    Colfax, WI
    That's not quite right. It doesn't over rev, it just spins faster than it does under load.
  17. Zack323
    Zack323
    Douglas, WY
    I hadn't thought of this, but most of my cutting is in the 6000-7000 feet range. Power is certainly lacking at this altitude due to thinner air/less air. As with a motorcycle, you generally lean an engine out at altitude. As I understand, the H/L screw is a fuel adjustment screw. The further out you turn the screw, the more fuel you are adding. Is that correct? 2 stroke motorcycles have an air screw which is counterintuitive as you open the air screw, you lean the engine.
  18. huskihl
    huskihl
    You are correct on both
  19. isaaccarlson
    isaaccarlson
    Colfax, WI
    That means you lose roughly 20% of your power at 6-7000 ft. All the more reason to have a ported saw....You might still have stock power at altitude. We drove the old buick at 12,500 ft, and while the power was down, it still had plenty of go left.
  20. MasterMech
    And this folks, is why the world needs turbochargers. :dremel::saw:
