2 stroke oil
Discussion in 'Chainsaws and Power Equipment' started by chucker, May 13, 2015.
  1. Moparmyway
    Moparmyway
    New York
    Divide cc by 16.4 (16.387) for ci
    mdavlee, Kg461 and Eric VW like this.
  2. Kg461
    Kg461
    Provencal, La.
    All this oil debate is interesting but IMO carb jetting and tuning is more important and chain being the most important link . Nothing adds up if the chain isnt on par like Mdavlee, Hedgegrow, Mopar, Squarefile and some other guys have figured out to a perfection
  3. concretegrazer
    concretegrazer
    Southwest MO
    I thought that oils job was to lubricate. :wacky:
    splitoak and Kg461 like this.
  4. Kg461
    Kg461
    Provencal, La.
    Yes which reduces and manages temperature
    splitoak likes this.
  5. Moparmyway
    Moparmyway
    New York
    You are lumping me in with some real slick chain dudes ............... I dont even deserve to be mentioned in the same breath as the others.
    I got lucky with 1 chain in 1 or 2 races ...................... luck runs out sooner than we expect !!
  6. mdavlee
    mdavlee
    Making fast chains is 30% skill, 50%, and 20% voodoo:jaw:
  7. concretegrazer
    concretegrazer
    Southwest MO
    It reduces friction thereby preventing more heat. But the overall fuel charge is what's cooling. At least that's the way I understood it.
    Kg461 likes this.
  8. Kg461
    Kg461
    Provencal, La.
    Sounds right. The way I see it is heat is what causes the air took in to expand and force the piston downard. If oil reduces temperature wouldnt that mean it was impeding combustion to a point?
  9. mdavlee
    mdavlee
    I wonder if the autotune huskies where they use so little fuel is the reason some of the oils cause them some running issues.
    porsche965, Kg461 and Moparmyway like this.
  10. Kg461
    Kg461
    Provencal, La.
    Mike this is just a guess and thoughts. If the autotune leans the saw out in search of max rpm and then u add more oil,(32:1), and try and force the xtra oil through the jetting set up for 50:1, wouldnt that make the saw even that much more lean?
  11. Kg461
    Kg461
    Provencal, La.
    I would bet if somebody wanted to run 32to1 in mtronic/autotune , if they redrill the main jet it would run much better?
  12. concretegrazer
    concretegrazer
    Southwest MO
    How much different is the husky strato than the stihls?
    Is it a jetting problem or an issue with the programing? Are the carbs the same except the solenoid?
    Kg461 likes this.
  13. Kg461
    Kg461
    Provencal, La.
    I think the autotune only searches for rpm is my understanding
    concretegrazer likes this.
  14. concretegrazer
    concretegrazer
    Southwest MO
    Are you saying the oil causes the heat from the fire to be less?
    Kg461 likes this.
  15. Kg461
    Kg461
    Provencal, La.
    I think to a point yes but just a guess
  16. mdavlee
    mdavlee
    There's not a great difference but the huskies seem to go longer on a tank. most of the carbs are zama.
    porsche965 and Kg461 like this.
  17. mdavlee
    mdavlee
    Oil has more energy than gas per btu. It takes more heat to ignite it. Some of the oils don't burn as easily as the others and don't contribute to the boom.
    splitoak, concretegrazer and Kg461 like this.
  18. Kg461
    Kg461
    Provencal, La.
    That makes sense. Thats why Im thinking I will like the less viscous R2 . Im thinking it will combust more efficiently
  19. Kg461
    Kg461
    Provencal, La.
    Im thinking R2 , K2 at 32to1 will be a much better choice in mtronics/autotune
  20. Moparmyway
    Moparmyway
    New York
    I wonder about R50 and 800 off road .................... those are 2 thick oils in the container and everything runs great without any tuning issues, unlike H1R
    Kg461 likes this.
