2 stroke oil question to the motor guys and gals!
Discussion in 'Chainsaws and Power Equipment' started by WeldrDave, Nov 2, 2013.
  1. shane brown
    shane brown
    Ville Platte, Louisiana
    I have been running saber pro at 100:1 in a poulan 245a for over 3 years and have never had a problem. In fact , It seams to run better, less smoke, virtually no carbon build up. Run it in my J-reds and efco. Very cost effective with peace of mind. You may think no way, I have yet to have an issue, even at extreme heavy use.
  2. SquareFile
    SquareFile
    somewhere
    I've read there is nothing to worry about.
    Hey, did you vote?
    http://firewoodhoardersclub.com/forums/threads/the-unofficial-fhc-mix-ratio-poll-thread.9733/
    clemsonfor likes this.
  3. shane brown
    shane brown
    I have been selling sabre pro to many customers and they like it. They keep coming back for more.
  4. shane brown
    shane brown
    Yep! Just voted thanks.
  5. SquareFile
    SquareFile
    somewhere
    Awesome......your welcome
  6. SquareFile
    SquareFile
    somewhere
    What are the benefits to using a leaner mix?....... Other than cost
    clemsonfor and PullinMyPoulan like this.
  7. shane brown
    shane brown
    You don't see the carbon build up in the exhaust ports, fouling of plugs and such. When running leaner I noticed less smoke and even better idling and smother running on amsoil.
  8. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Ive used Husky and Husky xp oil forever. Never a prob ! No locked up saws :). Im sure they are all good. Its more how a person mixes it i think :)
    Chvymn99, clemsonfor and shane brown like this.
  9. shane brown
    shane brown
    The 245a seems to like it over the conventional oil. Seems more robust and has a different smell than standard oil. Not as heavy on the lungs.lol.:smoke:
    HoneyFuzz likes this.
  10. shane brown
    shane brown
    I second that fuzz. I like the husky stuff too.
  11. SquareFile
    SquareFile
    somewhere
    Very interesting.
    Checkout some of the oil threads here.
    They are within a page or two.
  12. shane brown
    shane brown
    I think full synthetic is the way to go personally. But if I had to choose conventional it would be husqvarna oil!
  13. shane brown
    shane brown
    A bit off topic but, I let a friend borrow my 2255 J-red with a new sugihara 20" bar and he bent the bar tip. Almost to the point of binding chain and sprocket tip. Maybe should have installed a titanium bar! Lol. My rant for the day.
  14. shane brown
    shane brown
    The new sabre pro oil from amsoil also contains a great fuel stabilizer. Helps with ethanol and such. Of course many oils are these days.
  15. angelo c
    angelo c
    People's Republic of North Jersey
    You get to check your bearings more often....like Mike said, the case bearings need lube too....
    mdavlee and clemsonfor like this.
  16. mikey517
    mikey517
    Highland Lakes, New Jersey
    40:1 Dolmar full synthetic oil (or Stihl Ultra synthetic) w/ 93 octane Hess gas (the ONLY station with separate hoses for each grade).
    stuckinthemuck likes this.
  17. clemsonfor
    Buy it once I use up the quart and a half of amsoil I have I am getting some Lucas from Orileys at $9.99/qt. Will mix at 32:1 its good stuff
    Chvymn99 and mdavlee like this.
  18. clemsonfor
    o_O Theres no smoke and no carbon cause theres virtually NO oil in the gas!!!
    haveissues and mdavlee like this.
  19. clemsonfor
    I have never fouled a plug out in everything from weed eaters to saws to my boat motors some of which were pushing 40 years old. I think fouled plugs stopped happening when 30wt @16:1 fell out of fashion. Assuming you have good healthy ignition system.
  20. clemsonfor
    I use to use it. Its semi syn. But I switched when I went full syn. And I was glad Randy and Terry said that was some of the worst oil for leaving carbon deposits.
