1999 Dodge Caravan rack and pinion removal...need help
Discussion in 'The DIY Room' started by saskwoodburner, Aug 25, 2017.
  1. stuckinthemuck
    stuckinthemuck
    The Caravan spent its winters in Florida so there is very little rust on it. Pretty much the only reason I'm putting the effort into fixing it. The load valve seems to work as advertised. I tried using one of those hand vacuum pump Harbor Freiht specials and got fluid out of all the bleeders at the wheels except the right rear. Will dig back into it tomorrow and see what I can figure out. Thanks for the reply...
  2. gmule
    gmule
    Conifer Colorado
    Follow the brake lines from the master cylinder down to the distribution block. There is an electrical connectors in the middle of it unplug the connector and unscrew the switch. And reinstall it. That will re center the valve
    stuckinthemuck and Kris Wagner like this.
