12 volt wiring question
Discussion in 'Everything Else (off topic)' started by bocefus78, Jan 28, 2014.
  1. bocefus78
    bocefus78
    Indiana
    I am going to hook up a 10w 12 volt led flood light to my shed at the camper. From my research, I cant find a wiring table that goes lower than 5 amps and this thing isn't going to pull 1 amp.
    What sized wire would be appropriate but leave me enough capacity to add 1 more 10w light if necessary? One way run length would be approx. 25 feet at the longest and as little as 10 feet depending on light placement.
    Thanks.
  2. Grizzly Adam
    Grizzly Adam Guest
    Personally I would just pick up some cheap 14 gauge house wire. More than enough and cheap.
  3. fox9988
    fox9988
    NW Arkansas 72717
  4. NW Walker
    NW Walker
    Olympic Peninsula
    Once you start using low power devices such as LEDs on a low voltage DC system, the voltage drop calcs start to become a non issue and physical strength of the install becomes more important. I personally don't like to go much below 16g wire for lighting runs as the crimps start to get really weak with smaller wire gauges. I would recommend 14 or 16 gauge for that reason, plenty of cable for the load and enough physical strength for your terminations.
    Gary_602z likes this.
  5. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    I would also run it in conduit or plastic to keep rodents from chewing on it.
    Gary
  6. bocefus78
    bocefus78
    Indiana
    Cool. Ordered a spool of 16 and an in line fuse holder. This light will be for nighttime maple sap boiling. Last year the open fire lit up the area. I'm using a pos stove this year so I won't have any light.I can't go loosing my beer every 5 minutes!
    fox9988 likes this.
  7. lukem
    Speaker wire works good for 12V LED wiring. That's what I'm using on LED strip lights. I think it is 22GA and that's overkill for the power draw.
