034AV Super Pull Rope Replacement
Discussion in 'Chainsaws and Power Equipment' started by Grizzly Adam, Oct 19, 2015.
  1. raybonz
    raybonz Moderator
    Carver, Mass.
    Hell just do it should only take you 3 minutes lol..
  2. clemsonfor
    I like it but dont use it often.
  3. clemsonfor
    I dont have any silicone spray!!! I just looked out while outside splitting.
  4. MasterMech
    You would only miss out on the area that's covered by the rubber while the window is closed. And over time, I'm sure a certain amount of the Rain-X will deposit on the rubber where it contacts the glass.
    Hell, I'd do both! It just dawned on me that I have never had this problem on any of my vehicles but I have seen it on others of the same make/model. I use Rain-X on all of my vehicles religiously. Even use their washer fluid. I hate driving in the rain in a vehicle that doesn't have it.
    Chvymn99 and raybonz like this.
  5. clemsonfor
    It is nice for sure. Almost dont needs wipers usually.
  6. clemsonfor
    It would only deposit on the rubber wiper that goes down the glass ...the middle part of the window.
    MasterMech and raybonz like this.
  7. raybonz
    raybonz Moderator
    Carver, Mass.
    What I don't like about Rain-X is when I use the wipers it looks like a smear to me.. Worse when dark and lights hit the windshield..
  8. clemsonfor
    I'll do both. I have rainx its not the old style but the newer spray bottle type. I need to get silicone.
    MM you put rainx on your side windows? Normally?
    raybonz likes this.
  9. MasterMech
    Yes, all glass, even the mirrors. (Exterior!)
    If it's buffed off correctly it shouldn't do that. Wax on, wax off. I apply, wipe, let it dry thoroughly (it should "haze" the window and feel like a grease coat) and then buff it off with a large clean towel. Once you get an eye for it, you will know when it's time to switch to a clean area of the towel. Should not leave long rainbow streaks when you go over it with the dry towel. I usually buff the majority of it off with one rag/towel and then go back with a perfectly clean one to finish.
    I've never had the washer fluid leave streaks like that either. Just a real easy way to keep the main area of the windshield beading off nicely.
    clemsonfor and raybonz like this.
  10. raybonz
    raybonz Moderator
    Carver, Mass.
    Might need to revisit this at some time..
    MasterMech likes this.
  11. Grizzly Adam
    Grizzly Adam Guest
    So, turns out there were two motors for the 034 Super. Didn't have a carb kit for either anyway. Guess I will try another dealer.
  12. clemsonfor
    I would of just ordered it off ebay. Dealers dont stock much of anything I have found. Saves time and fuel.
  13. Grizzly Adam
    Grizzly Adam Guest
    Well, if I would have just ordered it off ebay I would have had a 50/50 chance of being wrong so I'm glad I didn't.
    Chvymn99 likes this.
  14. clemsonfor
    Look at the carb number on the carb. You can't be wrong. Stihl does not make carbs. They source them from companys like tillson and walbro. It will have a walbro number most likely and you look for a kit for say walbro kt-69 just to make up one. Thats what I tried to tell you last week.
  15. Grizzly Adam
    Grizzly Adam Guest
    OK, I missed that part. Thought I could say the chainsaw model and they would know, didn't realize there would be multiple possible motors.
  16. clemsonfor
    Thats fine. It could of been there was more than one carb. There was an 034 and a 034 super right. Those were different size p/c.
    Normally you can buy a kit by just model but getting the carb id is best. You also need to do it one random saws that are not as easy to source parts for...like an earthquake chainsaw. It actually has a walbro carb on those too.
    BuckthornBonnie likes this.
  17. Grizzly Adam
    Grizzly Adam Guest
    Yeah, there is a 034 and a 034 super, but the super itself has mulitple possible motors. I made sure to confirm that bit of info.
  18. clemsonfor
    Ahh I gotcha. You never know who your talking with at those places so I didnt know if they confirmed that or not.
  19. Grizzly Adam
    Grizzly Adam Guest
    Think I will have to give my Poulan 3400 Countervibe some run time until I can get the 034 all patched up. Got some more locust to cut and the ms250 doesn't do so well with it.
    clemsonfor likes this.
  20. Grizzly Adam
    Grizzly Adam Guest
    It's a Zama C3A S4. RB-31 kit on the way from Amazon Prime.
    Chvymn99, MasterMech and raybonz like this.
