“Walter” the TD6
Discussion in 'Chainsaws and Power Equipment' started by J. Dirt, Jul 2, 2019.
  1. J. Dirt
    J. Dirt
    Good news the right side pivot is out along with clutch fork.
    47FA65E0-B4AD-4AA5-A323-D0C4DB542378.jpeg 94353CEC-BA6D-4FEE-A976-A879C4251540.jpeg 1C51D35B-3070-4091-B1CB-EF7A4689D8A4.jpeg
    Bad news is..... the left side is still stuck, I cracked a piece off the head of the stud and also sheared off the socket I borrowed! :headbang::mad:
  2. eatonpcat
    You meant socket I bought! :cool:
  3. J. Dirt
    J. Dirt
    Yeah x2! One of which I don’t get to keep. I’m at a point of welding a bolt on to this thing and cranking it out. I’ll have to do some machine work to refit it once I’m done, but I’ve got the other side for a pattern at least.
  4. brenndatomu
    You mean weld a nut on it and then grind the grooves back in it? I bet that will work...:yes:
  5. J. Dirt
    J. Dirt
    Yep! Hope between the weld heat and being able to have something for a socket to bite we’ll get her!
  6. brenndatomu
    When welding a nut onto a broken off bolt or stud, I usually just plug weld the center of the nut...you could weld a pretty big nut on that pin...then use a big wrench with lots of leverage on it...I'd be shocked if you couldn't back it right out then...
  7. amateur cutter
    If you have a good air chisel, stick a bit in the slot & rattle the hell out of it before you heat it. Helps more than you think.
  8. J. Dirt
    J. Dirt
    NOS manual in the mail today to ad to the collection. D57A9C2B-2BDD-4B5D-9E7D-A99FC1D631BF.jpeg
  9. J. Dirt
    J. Dirt
    Well I done did it..... blasted it with the air chisel then tried welding on a big nut. Snapped it off. :mad: Couldn’t get a good shot at it with the welder. So I ground it up nice and took a 5/8 bolt and tapered the end so I could get a good fill on the weld. 5AF38F7A-6AF8-401E-9810-D584CAB56BB9.jpeg Managed to burn my arm through my shirt but got it stuck good! The 3/4” drive breaker bar with a pipe on the handle and broke it free. Switched to the 3/4” ratchet with the pipe and was able to make two clicks per pull:faint:. Three full rotations later it was moving free enough to throw the impact gun on. 46DCCF5A-4401-4828-959C-3574C2213BED.jpeg So it’s out, but I think I’m going to be hunting a replacement or doing some machine work.:thumbs:
  10. B.Brown
    B.Brown
    USA
    Way to go!! See, where there's a will, there's a way!!
  11. brenndatomu
    I'm sure those pins will see some never-seize going back together...
  12. J. Dirt
    J. Dirt
    I’m going to use a can per stud!!!
    Degreased and washed down ready to pull!
    75FA11E8-C877-4C90-9A60-8817CB424B69.jpeg 0766F588-B91D-437A-9AF5-C28F8E8C1542.jpeg
    That’s it for today...
  13. brenndatomu
  14. J. Dirt
    J. Dirt
    Weeeellllll hahaha
    It’s been sitting at the same place I left off. Way to many other priorities and projects. Although the weather is changing and I want to get it done before winter. Stay tuned....
  15. B.Brown
    B.Brown
    USA
    Waiting, lol
  16. J. Dirt
    J. Dirt
    Progress!!
    Had to make some little retainer tools and ended up chiseling our all the discs once I got the clutch on the bench.
    71213785-AA1B-48A8-829E-3F4F15C1A845.jpeg 4A834089-8992-4385-AA60-CA017C2558CE.jpeg 05429EA9-733B-4E0A-898D-785CE0D94429.jpeg C07AC02F-C786-4EF7-8B3D-4907CEA7E7F7.jpeg
  17. M2theB
    M2theB
    Central Massachusetts
  18. J. Dirt
    J. Dirt
    2287820C-32B6-4DAE-884E-5D52964FC215.jpeg Disassembled the clutch including the 1500 lb spring! :eek:Gently with the help of my floor jack and a tractor drawbar.
    The other clutch is free and ready to lift. Still need to disassemble the brakes. Unfortunately I ran out of gas for the day.:sleeping:
  19. J. Dirt
    J. Dirt
    Somewhat of a fight getting the brakes out, but a big hammer, choice words and the torch took care of it.
    63D7F772-B7A5-45B0-B479-6F39F2CCFE8F.jpeg 8928093E-9487-4532-A358-0CA12A39F42E.jpeg
  20. brenndatomu
    The heavy equipment mechanics secret sauce...
