“Walter” the TD6
Discussion in 'Chainsaws and Power Equipment' started by J. Dirt, Jul 2, 2019.
  1. J. Dirt
    J. Dirt
    A little more tear down. Pulled the plumbing to the left side, pulled the left side fender broke one bolt. Unbolted the right side fender leaving the hydraulics attached and ratchet strapped it up out of the way. Removed the clutch springs and linkages and pulled the cover.
    F8D385C9-FD17-4838-B558-E6A6DF4230DC.jpeg A408BD7D-EF32-44FA-A8FC-26F03275CBA7.jpeg 89994CA3-62F6-4A4B-9EB6-937F4DDE8436.jpeg CD192816-C4B0-4A0D-A8E6-662CA0923F3D.jpeg 1A85FFB0-DC88-4B48-B860-91A75D947E30.jpeg
  2. J. Dirt
    J. Dirt
    To pull the clutches you have to first remove the clutch forks. From the underside of the machine there is a bolt,keeper, jam nut and threaded post/bushing that goes through the casting and into the bottom end of the clutch fork. You have to remove the bolt and the keepers and remove the 1 1/2” jam nut. Once that’s off the threaded post has two slots machines across its face like a big Phillips head screw. That’s the part I’m at now..... The posts are pretty well stuck so I heated with the torch then sprayed the heck out of them. Might give it a shot later with more heat.
    I forgot to mention it’s in a horrible spot, unless you remove the diagonal braces underneath first. I’m trying to do it without, but I may have to.......
    Here’s the bolt with the keepers and jam nut on. 85C941CA-445F-4FE4-8267-B8B20C457F03.jpeg
    Looking out of the tight spot I’m in under the back of the tractor. 99D8AF78-1D0F-49EA-B73E-1EB1838DF395.jpeg
  3. AJtree88
    AJtree88
    Cool to see you bringing that ole girl back to life. Probably going to be a few sessions of “heat and beat” along the journey.o_O
  4. J. Dirt
    J. Dirt
    Got that right! Surprisingly hadn’t been to bad so far..... key word so far.....
  5. J. Dirt
    J. Dirt
    Well tried making a tool out of and old wrench with no luck so I decided to give up on the tight quarters work and tear out the diagonal braces.
    Some torch heating, swearing, cheater pipes, 6’ pry bar and 10 lb sledge I got them out! 2CE3E485-89C1-4EFF-B022-EF556DBC6799.jpeg They don’t look like much, but 3” solid square stock they got some weight to them!
    I made tons of room so I can get at the clutch fork pivot bushings though :dex: Now I’ve got to come up with some sort of giant Phillips head that can go on a breaker bar. I’m thinking on welding something up, but who knows. A15D1DDE-2B45-4A6E-B882-EFEAE7EAF7BF.jpeg C9110EC5-6035-47C5-87D1-F88F065DB94E.jpeg You can see what I’m talking about in these pictures. They are 1” coarse thread studs and I need to be able to get something into those plus looking slots and crank them loose.
    Any thoughts throw them out there....
  6. brenndatomu
    Hmm...I feel like I have seen a tool like that somewhere in the past...
    amateur cutter and J. Dirt like this.
  7. J. Dirt
    J. Dirt
    Same here just can’t figure where!?
    I thought of taking a socket that fits over the stud and grinding up a grade 8 bolt to fit sideways in the slots. The grinding slots in the socket for the bolt to sit in and tack weld them in place. It’s only one groove that I’d be grabbing, but?????
    amateur cutter and blacksmith like this.
  8. J. Dirt
    J. Dirt
    Drag link socket. 24488E4A-46C0-400E-BB49-C6D05816B8C1.jpeg Talked with the guys in the shop this morning and he said give this a shot. Said he’s used it on Mack truck king pins so it should be strong enough.
  9. brenndatomu
    Yup, there it is! :thumbs: :handshake:
  10. Dumf
    Dumf Banned
    Maine
    Hey J., "do not remove label under penalty of law". :rofl: :lol:
    Nice buy, but how do your close neighbors feel about the lovely roar ?
  11. Warner
    Warner
    https://www.mscdirect.com/browse/tn...MI6LmTlbax6AIVBG6GCh32GwLBEAQYCCABEgL4afD_BwE how about something like this?
  12. J. Dirt
    J. Dirt
  13. Warner
    Warner
    Ahh, yeah that ain’t gonna cut it.
  14. jmb6420
    jmb6420
    Grand lake, Oklahoma
    Drag link Socket and maybe some heat. PB blaster to start with.
  15. J. Dirt
    J. Dirt
    Been soaking it down for a while. I’m going to pull on it once no heat then I’m going full torch mode!
  16. J. Dirt
    J. Dirt
    Well just tried that socket and broke the one side free, with the help of a 3’ pipe. Nothing doing on the other side so I’m going to have to lay the heat to it. Maybe tomorrow when I have time and it’s not raining.
  17. jmb6420
    jmb6420
  18. Jnb
    Jnb
    New Brunswick
    I have run into stuff like that before and the tool you need for that is that hand held impact driver that you hit with a hammer. Like what Warner posted. They do work quite well when you get how to hold it figured out. Easy for me to say that as I already own one, but sometimes you are better off to spend the money on a tool insted of spending hours fooling with something.
  19. Jnb
    Jnb
    New Brunswick
    Ya, you could be right on that tool not being big enough for a 1" diameter stud, I am just catching up now lol.
  20. J. Dirt
    J. Dirt
    Yep, just a bit small for this job. Although it’s on my bucket list of tools because I know how handy they are!
