Partially seasoned wood in a catalytic stove
Discussion in 'Modern EPA Stoves and Fireplaces' started by rfogg, Aug 21, 2019.
  1. rfogg
    rfogg
    Monkton, Vt
    Canadian Border when you burned your almost dry wood the first year were you able to get 8 hr burns?
  2. Canadian border VT
    Yes, but I got less Heat then I did the next year with very dry wood.
    My house is odd it's a split-level post n beam 2200 square feet with 17 ft ceilings on over half of it..
    IS carries about 90% of the heat load unless I'm on vacation. It could probably quite easily do all of it..
    But the location of the stove is not on the lowest level and the water lines in the basement are 40 feet away and 6 foot below stove..
  3. Canadian border VT
    rfogg .. more than happy to show you the stove and the house if it's convenient for you in the future. PM me
  4. Backwoods Savage
    Welcome to the forum rfogg. Also congratulations on the new stove and it is a dandy!
    Yes, you can burn unseasoned wood in any stove, but you may not like the results. However, if it is close there are a few things you can do. As some mentioned, you can get some good dry wood and mix it or the same with pallets; just be careful.
    The best thing you can do along with the above is to add wood when you have a big coal bed. Also, leave the bypass open for longer than normal and watch the temperatures on both the firebox and flue. Get the flue especially a bit hotter than normal before engaging the cat and also don't dial the stove down to try getting a pure cat burn; you are better off running the stove hotter than normal and then you won't have to clean the chimney nor the cat quite so often.
    Once you get better wood (think strongly about the 3 year plan), you will absolutely love that IS stove and wonder why you get more heat than with other stoves you've had. In our case when we went with the Woodstock stove we cut our wood needs in half or more! You may do the same.
    Good luck and again, here is some good reading for you, especially because you have burned for such a long time and was taught a different way: Primer on Woodburning by Backwoods Savage
    FatBoy85, Rich L, Chaz and 4 others like this.
  5. CoachSchaller
    CoachSchaller
    Southeast Michigan
    I have an Ideal Steel and everyone here has given great advice. Wood in the basement does not tend to dry out too well. Even in winter I find it better to keep it outside and top covered. Another species is cherry. It dries really quickly
  6. NVhunter
    NVhunter
    Northern Nevada
    I used Chip Drop for firewood last summer. They delivered the wood rounds within a day but they delivered mostly cottonwood rounds, all which were 3.5 feet in diameter and 25 inches long. I'm still chopping and splitting these rounds which have been dropped over a year ago. Some of the small splits I got out of them I tested with my moisture meter, and it tops out at 50% then flashes "high" after its above that.... Well the splits from the chip drop a year later from the cottonwood is still above 50%... so if your in a hurry for dry wood, I'd pass up on Chip Drop. I don't think you can ask for specific types of wood either...
    My Ideal Steel will burn anything but it's a fight with wood less seasoned that's for sure.
    Good luck and you're getting a great stove.
  7. rfogg
    rfogg
    Monkton, Vt
    Thanks again for all the info guys. I'm really feeling like this transition won't be as hard as I originally anticipated.
    Again thanks for all the suggestions and help.
  8. mrfancyplants
    mrfancyplants
    South Carolina
    You may be right as i’ve Only used chipdrop for chips so far, however there is a place for comments where you could say: “pine or cedar only please.”
    I don’t know for a fact that they will honor your request. But, the company I worked with was pretty careful that they could actually deliver to my location. I would think they would have moved on to the next drop location if the instructions didn’t line up with what they had.
    I’m half tempted to request a a load of locust. It would likely never get filled, but a boy can dream, right?
  9. Marshel54
    Marshel54
    I am going to be a dissident on the Woodstock.
    Not real satisfied with my AS. I do believe I may have draft problems. We are working on it for this year.
    Everyone said it was my wood. Just about all the pieces I checked, and there were many, fresh split and brought to room temp. were in the 19% range with a couple in the low 20%. So I don't believe 20% to be a magical number. I also burnt some of that kiln dried $800/cord supermarket wood to put the wood issue to rest. Not any difference.
    I did burn 30% less wood with the stove going 24/7, but didn't get the drive you out heat I got from my Non-EPA stove. If the burn doesn't get better the Non-EPA stove will go back in.
    Just my thought.
  10. Canadian border VT
    Marshel54 that's interesting, I believe 20% wood should heat you and dry should bake you!
    It could be a draft issue. My only other question would be what is the Max BTU difference between the AS and the EPA stove??
    In old Motors.. a 6 cylinder got better gas mileage but an 8 had more power!! Do you follow my analogy?
  11. Canadian border VT
    rfogg .. I can anticipate your weather;). What is the style of your house? How well is it insulated? And what is the location of your stove in comparison to central use area of the home??
  12. rfogg
    rfogg
    Monkton, Vt
    It's a raised ranch with 2x4 construction insulation is ok for the wall dimensions. Newer windows but not the best. Stove is in the basement pretty much center of the house. We will be moving it towards an outside wall but utilize the same chimney.
  13. NVhunter
    NVhunter
    Northern Nevada
  14. Eric VW
    This is how we heat- bottom up. Man cave basement and upstairs are toasty all thru the heating season.
  15. Marshel54
    Marshel54
    The AS would be the 8 cylinder and the Rebel the 6. Rebel wasn't that big. Couldn't find max BTU on it. It is old.
  16. Highbeam
    Highbeam
    To the OP, the IS has a steel cat so is very tolerant of wet wood. Get the cat hot and keep it hot, the cat won't care about some steam passing through but that steam will condense in your chimney and make more creosote than a noncat.
    I would also consider the manufactured firewood. NIELs or other.
  17. Rich L
    Rich L
    Eastern Mass.
    I second the NIELS (Northern Idaho Energy Logs ).Those things burn hotter than any of the compressed wood products that I've seen.Semi dried wood doesn't stand a chance of not burning well when mix with a couple of the NEIL's.You might even get a better deal than me since your closer to where they are made.
  18. rfogg
    rfogg
    Monkton, Vt
    Well I ordered my stove and I should be able to pick it up in about 3 weeks.
    I looked into NIELS and they don't have a distibutor in my area. I found some Bio Blocks but they want almost $600 a ton. So anyway I have a cord of kiln dried coming for $450 and we will see how that works mixing it with the wetter wood.
  19. brenndatomu
    Geez ow :bug: they run $2-250 a ton around here!
  20. Canadian border VT
    Vermont brenndy.. over 20% of the people in this state burn wood!!
