Tools of the trade or your inventions
Discussion in 'The Wood Pile' started by T.Jeff Veal, Oct 2, 2018.
  1. Timberdog
    Timberdog
    Az
    Stlshrk, ABOrman, T.Jeff Veal and 4 others like this.
  2. buZZsaw BRAD
    I remember you telling me back when i first posted about it. I first used a 5/16 bolt, but it bent a bit too easy and broke after i bent it back a few times (im rough on my tools) went to a 3/8". Dunno if a point (like i did) or side ground would make it "stick" better in a log. Sometimes the point wont stay even if i swing full force. I repurposed the head into a wedge. See Thread Fiskars wedge
    Only tried it on a few smaller rounds. It works well with a small 4lb. sledge. I could see me splitting like this in old age vs. swinging an axe. The only problem is the metal is hardened (could chip easily and i chamfered it to lessen this) and the edges are not parallel so it will tilt after a few whacks. If i had a big grinder id grind the top to make them even. A couple members had suggested using the old handle for a pickeroon. If you end up making one, post the pics. Id love to see it.
  3. ABOrman
    ABOrman
    To ANYBODY that has had or does have any back trouble a pi maroon is worth every cent. Just picked up a husky Sappie. The head is great but the handle is junk. Waiting on it to break so my boy ca rahandle it for me. I have no back left so it helps a bunch. Anybody ever build something like a gorilla bak? I’m thinking we will be building one for bothe splitters. I’m disabled and my help is dad72 and my cousin 70 lol. We don’t hit it to hard. I love this club!
  4. T.Jeff Veal
    What is a gorilla Bak?
  5. Yawner
    Yawner
    Louisiana
    How do you cut that plastic, with a shear, knife, or some kind of saw?
  6. Yawner
    Yawner
    Louisiana
    You must be really strong is all I can say. Those rounds don't look small.
  7. Yawner
    Yawner
    Louisiana
    I have one I like. I can't find a link to where I bought it, it was not too costly, I think it was made by a small shop, it wasn't a big manufacturer. It has a small axe head on the other side of the pick part, axe is maybe 1.5" tall.
  8. MrWhoopee
    MrWhoopee
    Shingletown, CA
    Backsavers I've posted elsewhere, but they definitely fit here.
  9. ABOrman
    ABOrman
    Look it up on YouTube it’s a log lift log wench. Looks perdy slick
  10. amateur cutter
    MS 192T LOL. Chainsaw cuts em fast & clean.
  11. T.Jeff Veal
    Make sure you use 2 at a time. I have one and pulled a back muscle bad, moving some heavy half rounds to the other splitter.
  12. ABOrman
    ABOrman
  13. ABOrman
    ABOrman
    Here you go T. Jeff Veal
    I do not have any relation to this product. Just thought it would fit this catagory
  14. MrWhoopee
    MrWhoopee
    Shingletown, CA
    And people say my electric splitter is slow....
  15. ABOrman
    ABOrman
    I subscribed to your channel! Good videos I’m surprised at that little splitter. I don’t mind slow
  16. T.Jeff Veal
    Whose channel? T. Jeff Veal or Mr. Whoopee?
  17. ABOrman
    ABOrman
    Yours I think Phinious J Whoopie? Lol
  18. T.Jeff Veal
    The channel with the saw videos is T. Jeff Veal, which is me. Sorry for the confusion. This was a thread I started, have you seen the beginning? Several good ideas have been posted on here. Glad to have you here. Subscribe to my channel if you want. I post a video occasionally.
  19. jo191145
    Yeah I built something similar. Used the winch on my atv. No sense letting a machine go to waste while I break my back.
    Instead of that screw in Gorilla thing I use “Rafting Dogs”. Work great. Couple good whacks witha three pounder and your all set. Recommend never getting underneath one just in case it pops loose tho. Not many people would make that mistake once, certainly not twice. LOL
    Have a separate car battery wired in to the winch instead of killing the little atv battery. Winch comes with a wirelessremote which is nice. Only con is the remote turns off between rounds. Takes about 5 seconds of button pushing to fire it back up. Oh the agony!!
    One last hint. Build the pipe much stronger than you think it needs to be ;) mines scabbed together because I didn’t :)
    52F934EE-9365-4DEA-8BBF-464D1CB4F713.jpeg E115133F-9AAB-4E2D-8B63-2E02B7BD6C39.jpeg FF938861-968D-4551-9CF1-F43D91184E43.jpeg
  20. rottiman
    My design chop saw for 10" and smaller rounds. Especially handy if you have alot of tops to process.
    Screwloose, GrJfer, Marvin and 8 others like this.
