Finally have a Tandem Axel. What should I look out for?
Discussion in 'The Wood Pile' started by cigarsmokingzombie, Jul 20, 2019.
  1. cigarsmokingzombie
    cigarsmokingzombie
    Delaware
    The peer pressure on this forum is incredible with all the equipment everyone has. What do newbies need to be aware of when hauling on a tandem for the first time?
  2. Chaz
    Chaz
    Southwestern NY
    I have no experience with tandem trailers.
    So, best I can say, "Don't overload it."
    :yes:
  3. cigarsmokingzombie
    cigarsmokingzombie
    Delaware
    I will test the overload capabilities tomorrow. :)
  4. cigarsmokingzombie
    cigarsmokingzombie
    Delaware
    Guess I should buy a jack and spare tire first.
  5. tree killer
    tree killer
    Central me
    If you are looking to get more life out of the tires take larger turns instead of just cranking it around in open areas, especially loaded. It looks like a 7k GVW, it will take a lot mpre than whats on there.
  6. cigarsmokingzombie
    cigarsmokingzombie
    Delaware
    Thanks, yes 7k. Gonna load more tomorrow.
  7. Chaz
    Chaz
    Southwestern NY
    Oh, look out for potholes.
    :whistle:
  8. buZZsaw BRAD
    No trailer here, but my biggest fear would be a FHC member following me home or putting a tracking device on the trailer! :whistle:
  9. Chaz
    Chaz
    Southwestern NY
    We don't stalk, we wait for the GTG
    :saw:
  10. cigarsmokingzombie
    cigarsmokingzombie
    Delaware
    I really struggled finding the right drop for my hitch. Was thinking it should angle up a little when empty then it would even out when loaded. I went with a 4 inch drop which had the trailer level when empty. Full loaded today was still level. Should I stick with that?
  11. cnice_37
    cnice_37
    Sounds good to me. Jackstands on the back if loading equipment... got brakes and controller?
  12. Chaz
    Chaz
    Southwestern NY
    Unless you want gravity's help in unloading, I'd say yes.
  13. cigarsmokingzombie
    cigarsmokingzombie
    Delaware
    Yes to breaks and controller. Not sure what u mean by Jack Stands?
  14. GrJfer
    GrJfer
    The Woods of Arkansas
    Great looking firewood hauler. It should serve you well. Can offer much advice on the tandem as I have a single axle trailer that I use. I am however looking to upgrade it to a tandem.
  15. Chaz
    Chaz
    Southwestern NY
    Jack stands like you'd put under a vehicle for maintenance.
    Helps ensure that the vehicle doesn't fall on you in the event of a jack failure.
    Will keep the back of the trailer supported.
  16. Chaz
    Chaz
    Southwestern NY
  17. cigarsmokingzombie
    cigarsmokingzombie
    Delaware
    Ok, that’s what I thought. But that’s just for maintenance right?
  18. Loon
    Loon
    North of the border
    Nice trailer zombie.:yes:
    Nice perennial garden also.Is it mulch or pebbles? :coldone:
  19. CDF_USAF
    CDF_USAF
    Dover DE
    Set your brakes each load and don't load tail heavy, it's easy to run over one of the trucks weights before you run out.of trailer.
  20. Chaz
    Chaz
    Southwestern NY
    No, he means, if I'm not mistaken, that if you're gonna load any heavy equipment, you should use jack stands under the rear to support the trailer.
    I could be wrong, but...
    cnice_37 ?
