Drive link touch up
Discussion in 'Chainsaws and Power Equipment' started by Sandhillbilly, Jul 16, 2019.
  1. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Anybody have a simple idea on cleaning up the little burrs on the drive links after you throw a chain. I’ve thrown more chains with this 562 than I ever have in all the time I’ve been running a saw. Apparently it just won’t tolerate a chain as loose as my other saw
    M2theB likes this.
  2. Nixon
    Nixon
    West Sunbury,Pa .
    I use a dremel tool with the sanding drum attachment . It’s not as aggressive as the stone type attachments ,so you don’t grind off more than is neccessary .
    You can pick up a very inexpensive dremel type tooland attachments at HF .
    Not the same quality as the real tool . But it does a great job at trueing up drive links for <$30..
    M2theB, XXL and Chaz like this.
  3. clemsonfor
    I have just used a flat file. The same one I use to file the rakers with to get the burs off so I. An get it back in the bar groove.
    Sent from my moto g(7) using Tapatalk
  4. Ronaldo
    Ronaldo
    Should be running that chain nice and snug, otherwise the link tips/tilts and cause premature wear. And causes the chain throwing that you've experienced.
    Chaz, tamarack and clemsonfor like this.
  5. bushpilot
    bushpilot
    Eastern Washington
    I just touch it (each side) on my grinder.
    Chaz and clemsonfor like this.
