Single wall versus double wall stove pipe?
Discussion in 'Modern EPA Stoves and Fireplaces' started by fishingpol, Jul 2, 2019.
  1. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I'm planning a late summer install of a free standing stove, and I have been watching videos and reading up on stove pipe. I should have plenty of clearance from the back of the stove and pipe to the wall.
    I've read posts about some members having double wall pipe from the stove to the Class A. I'm just trying to determine what would be best.
    The pipe will go straight up 6' from the stove to the Class A at the ceiling box. Up through the attic crawlspace and through the roof. Maybe somewhere around 15 feet total.
    So why are some of you using double wall off the stove? Is it for cat stoves or helping with the draft? Just curious, but want to make the best decision.
  2. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Closer clearances to combustibles, mainly. There is probably some draft enhancements as well, but we didn’t use it for that reason.
  3. brenndatomu
    DW stays cleaner too...the internal temp stays higher. As they say, heat with the stove, not the stovepipe.
    Also, the DW that I am familiar with is stainless steel inside, so it will last a lot longer than single wall steel...
  4. fishingpol
    fishingpol
    Good answers. Thank you both.
  5. Well Seasoned
    Yes, great answers! The are many dbl wall stovepipe companies that offer lifetime warranties.
  6. woody5506
    woody5506
    Upstate NY
    I used double wall telescoping pipe from the stove to ceiling for clearance reasons, ease of use and hopefully a much longer lifespan than single wall. I was under the impression single wall is cheaper but more prone to failure and double wall was more of a (but not certainly) a "one and done" type of deal.
  7. fishingpol
    fishingpol
    ^ This has me thinking now that I could get a rear heat shield and move the set up back towards the wall a bit for some extra space, keeping in mind to keep the hearth big enough for the next size up stove.
    We will be just above minimal height requirements for draft, extra flue temp may not be a bad thing.
  8. Well Seasoned
    Just follow the data plate on the stove, if it's old and doesn't have one, then the 3ft rule is in place. Single wall stove pipe needs 18"
    A heat shield either on the wall or on the pipe reduces the clearance by 66%, that may buy you enough.
  9. fishingpol
    fishingpol
    I brought the Castine with us. I'm looking forward to seeing how it operates as a freestander. Probably installing an OAK to reduce drafts. I have a good location to run one outside.
    Also, putting the regular legs back on it. I had the short legs for fireplace install at the last place.
  10. Backwoods Savage
    Jon, I've never ran double wall so have no personal experience with it. However I'd have no problem installing it and don't think you would either. And I agree with the old saying about heating your house with the stove and not the stove pipe. Also, I doubt it would help the draft much in your case but still would not do any harm.
    papadave, Chaz, fishingpol and 2 others like this.
  11. Canadian border VT
    Only thing to add on many cat stoves you want the pipe a foot up to be 500 double wall requires a probe not a magnet thermometer..
  12. fishingpol
    fishingpol
    Another thing to consider for down the road as I'll probably get a cat stove.
  13. moresnow
    moresnow
    This is what I use. It flat out works. Another reason to go this route is to have the option of lifting up the lower section for a bottom up cleaning with a Sooteater whenever you desire. Nice to be able to keep a eye on things. I believe you will find the price appealing as well!
    https://www.menards.com/main/heatin...8-black-stove-pipe/dsp6tl/p-1444453726558.htm
    I get the rest of my components at the same place. It all works together nicely.
    fishingpol and papadave like this.
  14. fishingpol
    fishingpol
    Great link moresnow. I went on Selkirk''s page a few days ago to get ideas. I don't have measurements yet of what I am working with, but I did get familiar with their different types of pipe.
    The Jotul is easy to use a Soot Eater from the bottom up. I just have to take the baffle out and straight up shot it goes.
  15. billb3
    Which comes in handy if you've a stove that can burn low and slow. It's nice to have a chimney that can support it.
    brenndatomu and Well Seasoned like this.
  16. OhioStihl
    OhioStihl
    Southern Ohio
    Agreed, double wall is easy to clean with the telescoping feature and an extra layer of safety.
    Fanatical1 and fishingpol like this.
