I broke down and bought an Echo CS-2511T!
Discussion in 'Chainsaws and Power Equipment' started by Scotty Overkill, Feb 24, 2019.
  1. Well Seasoned
    X2, some lovely accommodations locally, and would be awesome to meet you! I guarantee a great time brother!
  2. buZZsaw BRAD
    I was at the local Stihl dealer today and i saw this saw on the shelf. When i first saw (no pun intended) your post i said "that dude has some big hands" but i was wrong. The saw is like holding a football. Ive been considering a new Stihl 193, but after picking up the Echo i might convert. The price was comparable too! I have a Husky 334T which i dont use a lot, but need a reliable handheld saw. Have you used it yet?
    J. Dirt, Screwloose and brenndatomu like this.
  3. J. Dirt
    J. Dirt
    Little late to the party here! Don’t know how I missed this thread, but time to bring it back.
    I got my 2511 around the same time Scotty Overkill did and I never had the pleasure to cut with it in stock form! Somehow it came home landed on the bench and the muffler fell off:whistle:
    Tossed the center cat and baffle, cleaned things up then had a heck of a time brazing back together, hence the messy job. 70F85BAF-02D1-4D27-95CF-4208724C80E3.jpeg Opened the outlet and added a little pipe/deflector. DECFDEA0-31F2-4CB1-B6C7-E964F31C730D.jpeg
    Another thing I found was there was no spike on the saw so I snagged one from my dealer. 5F751393-F22B-487C-B431-9DEB6946E8BE.jpeg
  4. J. Dirt
    J. Dirt
    I’ve been running the 14” 3/8 lp .050 set up that came on the saw and it cuts ok. 4D74A7A5-9C4B-4F4A-87F3-2AD5B9C41D94.jpeg 2DF78F9D-76B9-43BE-9085-60421A174757.jpeg Although it chatters like crazy!!! So recently I picked up the stuffs to do the 1/4” conversion.... stay tuned! :binoculars:
  5. Horkn
    Or "Broke Back saw collector, I can't quit you!!"
  6. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I’ve heard it said about guns ...” if you know exactly how many you have, you don’t have enough”! I guess the same could apply to chainsaws:emb:
  7. Scotty Overkill
    I opted to do a CAT "bypass" instead of opening the muffler all the way, just to make it a quick and easy job.....made an angled chute deflector and the exhaust now goes out of the opening at the bottom of the cover....
    Here's a short video of the saw running the 1/4-.043 Stihl carving bar and chain, notice there is no chatter at all in the cut, and for a small saw, it does quite well. It's become my favorite climbing saw, and I will be buying/modding another this coming winter....
  8. buZZsaw BRAD
    what is the advantage of the Stihl carving bar vs. Echo stock bar?
  9. Scotty Overkill
    On the 1/4 pitch chain, the cutters are closer to each other in series than on the 3/8 pitch....therefore, the saw has less "chatter" in the cut, and is much smoother in the cut.
    This new narrow kerf .043 1/4 pitch chain is pretty awesome for a climbing saw. That little echo is like a filet knife in the tree
  10. buZZsaw BRAD
    so the carving bar is 1/4 pitch and not the stock Echo bar? Does the carving bar lessen kickback with the narrow nose?
    blacksmith and J. Dirt like this.
  11. Scotty Overkill
    These echos come standard in 3/8" - .043, and the carver bar may or may not help a little with kickback, but the 1/4 chain is known for slightly higher risk....
    brenndatomu, Barcroftb and J. Dirt like this.
  12. J. Dirt
    J. Dirt
    Scotty Overkill can you post a pic of the tail of that bar? I just got mine and want to see what you did to get yours to fit up and oil.?
    blacksmith and Barcroftb like this.
  13. Scotty Overkill
    I'm in for the night, I'll have to take the bar off the saw and get some pics when I get a chance.
    I welded the factory Stihl oiler holes shut first putting a piece of copper into the drive slot of the bar, and re-drilled new tensioner holes that matched the echo. Then, carefully drilled down from the bar slot to the tensioning holes, because that's where the Echo oil channels from.
