Time to get familiar with Dolkitas... picked up a 6401 today.
Discussion in 'Chainsaws and Power Equipment' started by Jon1270, May 11, 2014.
  1. Jon1270
    Jon1270
    Pittsburgh, PA
    Isn't that an argument for getting the OEM jug if you aren't going to modify it?
  2. Chvymn99
    Just my 2 cents... But after looking at the piston and cylinder wall damage and your explanation. I'm just drawing from work experience here. Once in a while we will get a new mold in and we will guald up a ejector pin like that in no time. Usually it can be summed up to: Clearance, a piece manufactoring debris (most likely not clean correctly), and/or not greased correctly. But once its starts it doesnt get any better, it just gets worse with each swipe. With the speed of that piston, it may not have taken that long to do that damage under the right circumstance. So I can see where they where going with it ingesting something or manufacturing defect from the get go.
    DexterDay and Jon1270 like this.
  3. cnice_37
    cnice_37
    My vote is big bore kit... or sell it to me for $30 and have a 100% ROI !!
  4. draftgear
    draftgear
    WI
    Great read here, sorry no suggestions but hedge is saying you can port a 79cc OEM, (effectively by good builders) whereas the AF 84cc not so much....I think anyways.
    Hedgerow likes this.
  5. Hedgerow
    Hedgerow
    SW Missouri
    Yes and no...
    If cost is a factor, then good, solid, bolt on power is available from an 84cc BB kit... It will run fine, and be cheap...
    The best scenario, where price is not an option, is the 79cc OEM jug...
    Performance equal to the BB kit, with mod potential... But more $$$.
    BB kit don't mean more hp... Just means different power... More torque, not necessarily more speed...
    Less$ though...
    draftgear, DexterDay and Jon1270 like this.
  6. Jon1270
    Jon1270
    Pittsburgh, PA
    I'll probably let those options marinate for a day or two. Regardless, I'll need to grab a new impulse line, base gasket and may as well get a wrist pin bearing and some OEM retaining rings just to be sure. In the meantime I can try cleaning up the cylinder and rinse the crankcase out in case there are unseen particles of something or other hiding in there.
    Does anyone have clever suggestions for removing the thicker globs of aluminum from the cylinder bore? I've used Mastermind's mild abrasive method once on lighter deposits, but I'm hesitant to go flapping big pieces of flexible abrasive at such small targets. It's tempting to lay a fresh utility knife blade in there and see if I can't slice 'em off sideways. The plating has to be harder than utility blade steel if it tolerates constant friction with the piston ring... right?
  7. mdavlee
    mdavlee
    Sanding will get it. The lining is hard to grind through with sanding wheels
  8. cnice_37
    cnice_37
    What's this base gasket talk? I'm sure Hedgerow knows the factory squish on your options and can talk you out of a gasket.
  9. Jon1270
    Jon1270
    Pittsburgh, PA
    I think I even already have the appropriate sealant, but I haven't ever tried measuring squish, or done any other sort of mod. I've never had a chance to even try a non-stock saw, so I don't really know what I'm missing.
    Right you were. I've sanded out the aluminum transfer, and underneath it I did find some minor scuffs in the plating - the sort of marks I can only see under very bright light, and can't feel at all. I scraped the little lump of aluminum off of the piston ring too, and then used the piston to push the ring down the bore, examining the fit at various points. I have a little LED reading light with its head on a long flexible stalk, so I put that light inside the cylinder on the far side of the ring. Towards the bottom end of the cylinder the ring springs out a little into the transfer ports and pulls away from the bore a bit so I can see a sliver of light between the ring and bore, but the slightly scuffed area doesn't pass any more light than the unscuffed areas. Above the transfer ports the ring fits as close to perfectly as I can see - no light at all comes through. Tonight I'll use a Mastermind-style arrangement to run a square of Scotchbrite through it just to finish the cleanup. I'll post photographs in the morning.
    MasterMech and Chvymn99 like this.
  10. mdavlee
    mdavlee
    I figured it would clean up. Motoseal is what I use.
  11. Jon1270
    Jon1270
    Pittsburgh, PA
    Yup, I have a tube of the same from when I rebuilt my 350.
    mdavlee likes this.
  12. Jon1270
    Jon1270
    Pittsburgh, PA
    For the curious, here's the intake side of the cleaned up cylinder in the merciless glare of my LED reading light, with the contrast amped up to make the detail stand out. I didn't bother with an exhaust-side pic because it cleaned up perfectly.
    I'm not sure what to make of this sort of broad scuffing, but if there's a smoking gun here I can't see it.
  13. mdavlee
    mdavlee
    If you can't feel anything with a finger nail then it's probably just discoloring.
  14. MasterMech
    Even if they are areas where the plating has been damaged, which is likely, micro spots like that low in the cylinder will not kill the engine. If it's sanded smooth, the ring is likely to just ride over top of the imperfections without any significant detriment to the remaining life of the cylinder.
    If I were keeping the saw or just wanted to run it awhile, I would run that cylinder. If it was getting sold for sure, I think making it a 7900 or the BB kit would be worth the piece of mind considering he's into the saw for peanuts at this point.
    mdavlee likes this.
  15. Jon1270
    Jon1270
    Pittsburgh, PA
    It's a little more than discoloration, but not much. I can't feel anything with a fingernail, but there are 2 or 3 spots where I can feel a bit of a catch or roughness by dragging the corner of a steel ruler across. The whole intake port is only half an inch high, so we're talking about a line that's maybe a quarter of an inch long, and a rough patch that's about an eighth of an inch across.
  16. lukem
    Unless you have any intention of keeping this saw, and as good as the jug cleaned up, I'd be very tempted to put in a new piston and send it down the road for a nice profit. Heck, even if you do plan on keeping it, I would run with that jug for a while...you could always sell it later if you wanted to go big bore down the road.
    mdavlee likes this.
  17. Jon1270
    Jon1270
    Pittsburgh, PA
    Yes, it would be easy to make money with this one, and I realize this cylinder is pretty darn good whether I keep the saw or sell it. I suppose the main reason I'm thinking of upping the displacement is to make it easier to rationalize keeping it. Restored to stock, keeping it would make no sense because it's capabilities are too similar to other saws I already have.
    MasterMech likes this.
  18. DexterDay
    Those small imperfections will fill with carbon over time. I wouldn't worry about it.
    I used this cylinder and was told by several members that those lines are insignificant and will fill with carbon over time.
    No worries. Get a good piston kit (Meteor w/ Caber rings) and run it ;)
    the GOAT and mdavlee like this.
  19. Jon1270
    Jon1270
    Pittsburgh, PA
    From what I can see, Meteor doesn't make one, and even the OEM pistons are unavailable except as part of a whole top end kit. All I'm seeing is cheaper aftermarket stuff. Anyhow, I suspect you're just trying to get me to make it a 6400 so I'll have no need for it and put it up for sale.;)
  20. MasterMech
    You have pennies into it really. I'd make it a OEM 7900 and then decide if you like it. If you do (and I suspect you will) maybe get it ported, set it up for the biggest wood you want to handle, and enjoy it. Even after springing for the OEM kit, you will make $$ on the saw if you want to unload it. I dunno what guys pay for a ported 7900 but imagine that you could at least break even if you went all out on it and decided to sell it. You have such a clean chassis to start with that I'd have a hard time not making it something special.
    mdavlee, concretegrazer and Jon1270 like this.
