Got a problem for the Gurus
Discussion in 'Chainsaws and Power Equipment' started by papadave, Jun 11, 2019.
  1. Eric VW
    I’ll just take the high road and wish you well in getting the machine running...:D
    :wacky:
  2. Chaz
    Chaz
    Southwestern NY
    One must never let the magic smoke out of electrical circuits.
    :whistle:
  3. papadave
    Wait, ......what?:whistle:
  4. Horkn
    I've seen that recently!!
  5. Chaz
    Chaz
    Southwestern NY
    :doh:
    :hair::hair:
  6. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    It could be on your band saw table...:whistle:
    farmer steve, Barcroftb, Chaz and 3 others like this.
  7. eatonpcat
    First time for everything! :D
  8. Horkn
    Barcroftb, Eric VW, Chaz and 3 others like this.
  9. amateur cutter
    Hey, that was a pto clutch before it became a paperweight.:doh:
    papadave , check the connection at the back of the key switch & make sure it didn't just pop loose. Does sound like a bad ground connection though. No power from battery to anything.
  10. papadave
    I knew I shoulda stayed outta' that danged ditch.
  11. In the Pines
    In the Pines
    gotta keep them pixies contained.
  12. ironpony
    ironpony
    Mid Ohio
    did you say
    here hold my beer and watch this...............
  13. papadave
    Nope, no drinkin' involved.
  14. Canadian border VT
    There's the problem..
  15. papadave
    Well, looky what I just found. Yep, blown fuse. No idea why that would happen, but if that's the problem, it's an extremely simple fix (and I don't have to find the multimeter).
    I'll buy several, just in case.....you know, I decide to mow the ditch again.:picard::rofl: :lol:
    Thanks to everyone who offered help.
    Now, all I need is a few days with no rain, and I can get back to moving firewood.:yes:
    Loon, Thor, amateur cutter and 4 others like this.
  16. papadave
    So, trying to pop in a new fuse and it blew right away (nice little light show). Pulled the neg. cable and put in the fuse, but the cable sparked like crazy when putting back on and of course the 2nd fuse blew (I bought 2 5 packs).
    Something else is wrong. No bad connections at the switch, and I can't see any loose/frayed wiring.
  17. billb3
    Any part of the mowing deck able to rise up and crush a wiring harness ?
    I had an ignition switch go bad in my tractor. Replaced the switch but now if I get up off the seat in gear, instead of shutting off the engine a fuse blows. The circuit is full of diodes and one of them or something else went bad when the switch shorted out inside. One of these days I'm a sit with the wiring diagram and figger it out but for now I just don't get up off the seat with it in gear.
    amateur cutter, Chaz, huskihl and 3 others like this.
  18. brenndatomu
    You have a power wire shorted to ground...something that is hot with the key off...battery cable...or maybe a main supply wire to the fuse box?
  19. papadave
    Was thinking possibly the PTO clutch wiring.
  20. Canadian border VT
