  1. savemoney
    So true. Sub, are you getting involved in any spring or early bird sales?
  2. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Speaking of birds how are Ye doing with the Hummers?
    savemoney, jtakeman, ivanhoe and 4 others like this.
  3. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Got after the new control panel with a vengeance today...
    Waiting on two resistors for the heat control assembly, but they are an easy couple minutes to slip in and snug the screws down
    I needed a 1 megohm and an 820K ohm resistor for the #1 and # 2 heat positions.
    I had ordered 1/2 watt parts and the clown sent me 1/8th watt...
    I had not opened the package until today as I was not ready for them..... arrrrrrgh :picard:
    Only about $4...oh well..
    Otherwise it's ready to plug in the test motors and let it rip.... :yes:
    jtakeman, wildwest, ivanhoe and 2 others like this.
  4. gbreda
    gbreda
    NH
    True, just big 200-250 lb black bear. As long as not dealing with momma bear and cubs, they are pretty docile-which is why I felt ok being about 30 feet away and yelling at him. Oh, with a quick escape door into the garage right next to me :p
    Not any Revenant type bear around here
    imacman, jtakeman, wildwest and 4 others like this.
  5. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Finished up with some last minute serious Whupazz on the new controller this morning.
    Plugged that bad boy in and all was quiet (AS it should be)
    Pressed the Reset button (Still all quiet as it should be )
    FLIPPED THE MAIN SWITCH Yessssssssssssssssssss
    Panel lights (Main/pwr..Combi and booster) come on (As they should)
    Booster fan comes up to speed (As it should)
    Twisted the Combi fan speed control and the combi fan spools up ( As it should)
    Flipped the Burn switch and the cycle timer starts cycling with the Red lamp blinking off and on with the feed setting (As it should)
    Checked the various heat settings and everything is in the ball park
    Then I noticed that the panel volt meter is not reading ????????
    Grabbed the VOM off the desk and checked the voltage at the meter terminals.
    Reading perfectly ???????????????????
    Shut the unit off and swapped the meters. Nope...same issue.
    Scratch head and wonder WTF
    Same meter I used in the Panel for the Big stove.
    Arrrrrrrgh.
    Puzzling over the debacle and then I spot the issue.
    The Meter has the big V in the face but not the Alternating current mark under the V
    Both meters are the same...
    EBAY from across the pond (China)
    I ordered the correct meter (0-150 volt AC )
    Somebody grabbed the wrong chit and tossed it in the box.
    I now am the happy owner of two 0-150 volt DC meters :picard:
    New meter coming from a different vendor
    Testing is going well.
    The 1 megohm resistor is a tad high ( 1.04) and as such the timing is a tad long at 11 seconds.
    May switch to a resistor in the 900K range (Each 100K is one second on the timer)
    I had ordered some 820K ohm resistors and they were marked wrong on the package and what I got was 866K Ohm (8.6 seconds off time)
    Easy to swap these out...takes a couple minutes to change them.
    No need now as the testing can continue with the current parts.
    When we get to prime time I want the specs spot on for the best fire control.
    Some pics...
    jtakeman, wildwest, ivanhoe and 3 others like this.
  6. subsailor
    subsailor
    Winthrop, Maine
    I'm probably going to order a ton of MWP from SIB and haul a ton of Platinums from Rockies over the summer. My garage is getting jacked up and a slab poured this fall. Once that is done I will buy more from SIB and have them run into the garage instead of killing myself hauling them into the basement.
  7. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    It is getting close to the R day for you, how's that working out?
    imacman, jtakeman, wildwest and 3 others like this.
  8. IHATEPROPANE
    IHATEPROPANE
    This is a family site
    imacman, jtakeman, Luneyburg and 4 others like this.
  9. IHATEPROPANE
    IHATEPROPANE
    Good stuff! A month or two from now that schedule will be real nice once you get used to it.
    imacman, gbreda, jtakeman and 3 others like this.
  10. bogieb
    Can tell it is "summer", Friday drive home from work was very slow because of all the campers, trailers and general tourists. Left work about 3:10 and got home 4:45 - and I finally got off the highway and took surface roads to be that quick. Sure, it's 50 miles, but usually I can do it in 1:10 - 1:20.
    After feeding the cats and birds I got right out and started mowing. Walked out the door as the local news was starting so it was 5. I got my yard done and the neighbor's 3/5 done and walked back inside at 7.
    Gathered my 3 gas cans, put some Seafoam in them and went to fill them up. 1 can is for premium (for the bike), so I put a couple gallons of premium "mix" in the truck before filling that can. The other two cans are regular, so I had to make a separate purchase.
    Got home and pulled the car and bike out of the garage. Dug out the snow blower from the back corner and filled up the gas in it. Then started it up and let it run for a minute or so - so that is summerized.
    badbob, imacman, jtakeman and 4 others like this.
  11. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    We can debarte that statement until the lactating bovines come home at least.
    imacman, ivanhoe, jtakeman and 3 others like this.
  12. jtakeman
    :eek:
    imacman, wildwest, ivanhoe and 2 others like this.
  13. ttdberg
    ttdberg Pellet Pig
    CT
    Looks like we have a top-five day on tap here friends, so get out and enjoy it!
    :dancer:
    imacman, wildwest, ivanhoe and 3 others like this.
  14. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Wet and sloppy outside this morning.
    Built a fire in the Small Whit (64 F in here) cooked up the coffee and switched on the computer.
    Flipped the new stove controller on to let it sit and churn away.
    Sipping my cup O Joe and watching the cool little LED lamps on the control panel doing their thing.
    With the Red cycle lamp blinking on and off it's almost like Christmas. :yes:
    Ahhhh yesss
    It's been a long busy season with all the "Building Projects"
    2 control panels and the Munchy machine...
    Real glad that this stuff is over... :makeitrain":makeitrain":makeitrain"
    Munchy ended up costing over double what I planned on.
    Getting the new controllers done and ready makes me feel far more at ease ..
    Losing a stove during the winter weather could be a real serious problem...
  15. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Panel testing pretty much all day now and working sweet.
    Decided that the fan speed control needed a LOCKING DEVICE to prevent accidental adjustments.
    Machined a cool little aluminum angle and drilled and tapped it to allow the small red knob to screw in and lock the speed control easily.
    That bad boy will keep any unwanted adjustments at arms length for sure.
    I ordered up a little bigger selection of resistors to be able to fine tune the heat ranges.
    LIFE IS GOOD
    Earl764, wildwest, bogieb and 4 others like this.
  16. jtakeman
    Swapped out the sn*w tires on the buggy and Joeys putt putt, Oil changes done on all 3, Rear brakes on the buggy. Lawn mowed, Garden tilled. Road Trip to the HD and Fixed the broken pole for the bird feeders.
    Pooped me be, But fishing will fix that tomorrow!! :)
    :seasoned:
    Ooh and a couple of these :coldone: to heal up the aches and pains tonight!! :D
    :cheers:
    Earl764, imacman, wildwest and 6 others like this.
  17. Pete Zahria
    Pete Zahria
    New Hampster
    I got dressed and had breakfast..
    Dan
    :sleeping:
    subsailor, Earl764, imacman and 7 others like this.
  18. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    A clue for JT, cows.
    imacman, wildwest, bogieb and 3 others like this.
  19. ChandlerR
    ChandlerR
    Seacoast NH
    Well, finally a decent day. My upstairs tenant moved out so I've been freshening up the apartment. Mostly paint so no biggie. Finally brought the Harley home from it's winter hibernating spot. Took a long ride hone but as I neared my house, it cot freakin cold. Seabreeze. It was 52 at my house.
    Hope y'all have a safe and pleasant holiday weekend and don't forget to remember all the fallen who have made it possible to do what we do.
  20. Pete Zahria
    Pete Zahria
    New Hampster
    What a Veg day for racing fans...
    9:00 Monaco GP
    11:00 Indy 500
    5:00 Charlotte 600
    If I figure right,
    I'd say you could gain maybe, what.. 3-1/2 to 4 pounds??
    Dan
    ivanhoe, jtakeman, bogieb and 5 others like this.
