Sears LT-1000 Tractor- Replacing the old rotting rubber feet & rusting metal foot rests?
Discussion in 'The DIY Room' started by don2222, May 5, 2019.
  1. don2222
    don2222
    Salem NH
    Hello
    The rubber foot pads actually held moisture under them which accelerated the rusting!
    So for approx a whopping $30 bucks, I got some steel diamond plate that was easy to cut the same size as the rubber foot pads with a jig saw and weld them in!
    https://www.farmandfleet.com/produc...MInK761P6E4gIVmEwNCh0LPA1cEAQYASABEgJtGvD_BwE
    Any one also do this?
    This seams stronger and may last?
    Now I have to ad quick steel to putty the holes and then some primer and paint.
    Also upgraded the OEM tractor seat. :)
    Craftsman LT1000 Lawn Tractor Seat Upgrade Anyone?
    Pic 1 - old rubber foot pad that fell off
    Pic 2 - metal is rusting away under it!
    Pic 3 - cutting the new steel diamond plate
    Pic 4 - grinding sharp edges
    Pic 5 - same shape as rubber feet
    Pic 6 - welding it on after wire wheeling dirt & rust
    Pic 7 - all welded on and grinder smooth
    Pic 8 - looking good needs primer & paint
  2. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I wonder if truck bed liner spray or roll on would work after welding and cleabing the rusted holes. Or even wheel well undercoating?
    papadave likes this.
  3. don2222
    don2222
    Salem NH
    Thanks for your comments
    I am going to try this quick steel for the holes
    papadave and fishingpol like this.
  4. don2222
    don2222
    Salem NH
    Hello
    Wow, that quick steel hardens very Quick and gets very hot!
    U can only mix a very small amount at a time!
    The quick steel works quite well and grinds down nicely. It is expensive though.
    My welding friend’s advice is to just put a piece of aluminum under the hole and weld it and remove the aluminum then grind it down. Faster and cheaper if you are a good welder.
  5. badbob
    badbob
    The new floor plates look fine.If you did not sand/grind and treat the metal underneath,will happen again.The metal epoxy will probably fall out from vibration/flex. You need to take a welding class,LOL.
    fishingpol and Horkn like this.
  6. don2222
    don2222
    Salem NH
    I did have welding training and still learning. The new epoxy putties are really good but we will see how long they last. My welder friend just said put a piece of aluminum behind the hole and weld it, so maybe I will try that next, certainly good stuff to learn and be good at. :) Have you done that trick?
    Also got Por-15 to treat the metal underneath. Looks like good stuff,
  7. don2222
    don2222
    Salem NH
    Hello
    The type of metal and the rusting makes it very difficult to weld the small holes. Therefore Since most of the welding went well, I am filling in with the quick steel to make it look better after painting and undercoating. The Por-15 is the best undercoating, it can be painted over rust.
    So we will see but better than no??
  8. don2222
    don2222
    Salem NH
    Finally, a little primer on top. :)
  9. don2222
    don2222
    Salem NH
    After about a month and getting a package with no contents except the plastic bag with a paint label, sears sent out another can of Polo Green custom color and I got in a box instead of a bubble envelope!
    So I just finished masking and applying the first coat!
  10. don2222
    don2222
    Salem NH
    Here are the final pics
  11. don2222
    don2222
    Salem NH
    Last pic
    The welded diamond plate will not fall off like the rubber foot pads did and may last longer than the tractor. LOL
