Splitter switch, Problem solved
Discussion in 'Chainsaws and Power Equipment' started by HDRock, May 8, 2014.
  1. HDRock
    Now I will have one hand free.
    Simple solution, Pic 1, squeeze the trigger for clamp pressure twice, motor is on, runs continuous , Pic 2, squeeze the release lever once, motor is off , clamp stays put :)
    HoneyFuzz, BillinTX and rookie1 like this.
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    Is the clamp the final solution or just a temporary fix?
  3. HDRock
    I don't see any reason to do anything else, works great, And when I get ready to sell it, it will be stock And still have that extra safety feature intact.
    You don't need to turn it off until you get done splitting
    I could tear it apart and replace the momentary switch With a regular on off switch But it wouldn't be snow and water resistant.
    I could also wire it, always on, and plug the splitter into the 20 amp footswitch I have, but why? this works
  4. nate
    nate Banned
    Palmer, AK
    I had welded an extension on the lever on the one I had so I could use one hand to push the button and hold the lever down.
    I don't know what brand your machine is, but the one I had, the motor had to be off for it to retract. Running it non-stop, I'd have to wonder if the motor and pump are up to that task?
  5. Stinny
    HD… sounds like you got er by the short hairs now mistah… :D
    HoneyFuzz and HDRock like this.
  6. HDRock
    The splitter is a harbor freight 7ton, the ram will retract with the motor running.
    I think the motor n pump will be ok, That button is just an added safety feature someone thinks I need.
    If I do burn it up, well, I guess I will just have to move on to bigger and better things sooner :D
    MasterMech, Stinny and HoneyFuzz like this.
  7. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Sounds like a great idea buddy ! Good thinkin !
    HDRock and Stinny like this.
