Splitter mod , would you do it ?
Discussion in 'Chainsaws and Power Equipment' started by wishlist, Apr 8, 2019.
  1. wishlist
    wishlist Guest
    Found a local dealer with a Timberwolf in stock , I’m afraid to go and look at it . Probably would bring it home
  2. wishlist
    wishlist Guest
    Some folks are just plain stubborn Dennis!
    You should have come over , I would have hired you to keep the fire going . The new 30”x10’ft evaporator eats the wood up fast .
    Made 430 gallons , hauled 19,600 gallons of sap .
    Thanks for the invite, I’ll see if I can swing over , I have 90 places to open up that week at the park .
  3. brenndatomu
    Blacksmithden...I think...
    Edit: here ya go...
    Log splitters
  4. amateur cutter
    The 4 way is a great option on a push through splitter. It takes a bit to learn to stage the rounds by size to avoid as much re-splitting as possible. The wedge isn't actually adjustable, but I put a small shim in it to raise it 2" for bigger splits. It's worked very well. Log lift is a real back saver.
  5. Eric VW
    Nailed it!:D
    Thanks Brenndy!!!:salute: :handshake:
  6. 94BULLITT
    94BULLITT
    Frederick County, VA
    I've never used one, but I have read that several places. I thought if it got jammed get a block of wood and let the splitter push it through.
  7. Hatchetdancer
    Hatchetdancer
    I split mostly by hand so them “ moose knuckles “ that require a splitter usually stay in the woods or go to my buddies outdoor stove. I have found having about 3 guys on a splitter makes it go much faster
  8. Backwoods Savage
    If you come to the gtg, I'm sure that Cole is bringing his big splitter and you might get some ideas. Sorry, there is a picture of it somewhere on here but right now I don't know where. It may have been in a PM.
    But for sure it appears we will have several splitters here.
    That is a lot of syrup!!!!
  9. chris
    my splitter was vertical - horz. tried the vert. on big rounds- pia moving under wedge and over that step plate even on hard ground. So after I mangeled enough section of it I rebuilt it as horz only - big stuff I put in tractor bucket or fork lift to get them on beam . I use a thin wedge design with a spreader behind it - slices through rather than brute force to render it asunder.
    i have made 4 way units even had one cast up, did not like them even with back set wings ( call it a 2 stage split)
  10. wishlist
    wishlist Guest
    Made it over to a Timberwolf dealer today. Very nice splitters , expensive but look well made .
    I did find out that Timberwolf is no longer making their line of spitters anymore . Tw-1 and the rest are done . They are in the process of updating all the designs and features . Makes me wonder how bad the dealer would like to sell me a splitter?
  11. Canadian border VT
    Interesting on timberwolf..
  12. 460magpro
    460magpro
    usa
    I think it is sad they did away with the two 5and6
  13. cnice_37
    cnice_37
    Interesting indeed...
    T.Jeff Veal and Hammy like this.
  14. 94BULLITT
    94BULLITT
    Timberwolf was acquired by Automated Biomass. Biomass splitters are ergonomic and user friendly. They just recently designed the Timberwolf alpha which looks like a big bad TW splitter, just raised up and more user friendly. IMO it would be the ultimate splitter.
  15. Eric VW
  16. T.Jeff Veal
    We built the rack behind the foot for big rounds. They slide pretty easy on it. Roll one up, flip it over and split. We have split some 46" rounds or bigger like that.
  17. 94BULLITT
    94BULLITT
