  1. wildwest
    Thanks BB, not sure where to start. Guess I'll start 1 ton cleaning and go from there. Going by ear the stove sounds different, hope it's not one of the fans.
    Help please? I can see two blowers in my stove, this makes it look like there is a 3rd?
    7. The convection blower is defective. See Section 8.2: Testing a Component and
    test the convection blower.
    8. he combustion blower needs cleaning. Carefully clean blower housing and make
    sure blower louvers are not blocked.
    9. The exhaust blower is defective. See Section 8.2: Testing a Component and
    test the exhaust blower.
    #7 and #8 are the same blower?
    LETTER COMPONENT
    A HEAT EXCHANGER TUBES
    B BURN POT
    C IGNITOR
    D CONVECTION BLOWER
    E THERMISTOR
    F L-250 THERMAL SWITCH
    G HOPPER
    H CONTROL PANEL
    I HOPPER SAFETY SWITCH
    J PRESSURE SWITCH
    K F-160 THERMAL SWITCH
    L POWER CORD RECEPTACLE
    M THERMOSTAT TERMINAL BLOCK
    N COMBUSTION BLOWER/FRESH AIR
    INTAKE
    O EXHAUST BLOWER
    P BOTTOM AUGER #2
    Q TOP AUGER #1
    R ELECTRONIC BOARD
  2. wildwest
    ETA, I just cross referenced on the parts legend at Drolet, seems they are calling it a combustion fan or convection fan but still the same blower.
    ETAA, both fans working. Got into both squirrel cages on the combustion/convection fan, they were surprisingly clean considering the wind/mud/dogs here.
    badbob, imacman, Ambient and 3 others like this.
  3. Dpopps
    Dpopps
    MI
    Thanks for the birthday wishes! My lady is taken Me out this weekend. :beerbbq:
    It's been warming up, still some cold nights but nothing real bad. Might have put my last bag in two nights ago, forecast is looking decent. I'm ready for some sun and warmth, can't wait to get back up north.
    badbob, imacman, Ambient and 7 others like this.
  4. gbreda
    gbreda
    NH
    WW, I would say cleaning is a good start.
    Did it smoke the hopper just once or more than that? Any differences in wind when it happened? Do you have an OAK or is it pulling in house air?
    badbob, imacman, Ambient and 5 others like this.
  5. will711
    will711
    Pocono Mts.
    Yum , and every meal is better with Beer :cheers:
    badbob, imacman, Ambient and 6 others like this.
  6. wildwest
    Happy Belated Birthday!
    Thanks G! It's still down tonight. It wasn't really that dirty but the ash is black (it was gray for years) Still smoking after a VERY thorough 1 ton cleaning including the blower blades (they turn freely by hand and work when the stove is powered up).
    1 Smoking hopper started last evening, of course we each had to try a couple simple fixes, so we smoked out the house a few more times last night :confused:, again this morning with a hail mary that maybe it was a fluke:deadhorse:, and then again this evening after I did the cleaning and checking everything I know of and what I found in the manual.
    2 The wind has been unusually calm but still a breeze. We watched the flame last night during an exploritory test, does not leak smoke on higher settings, the flame both torched AND waned within seconds during that.
    3 3" OAK, vent cover is clear and holds a sheet of paper up against it when the stove is powered up.
    Could it really be as simple as a cap? (I sure hope so). WWW hopefully bringing home a new cap tomorrow. Few stores here, limited selection here so I could order a better one if needed, hope our ACE has a 4" cap.
    Intake, exhaust, chimney and OAK are all open and clean, the blowers both work, but the stove still fills with smoke that eventually comes out other crevices. It appeared to quit leaking smoke at a higher setting... Exhaust pipe is straight up ~15'
    badbob, ivanhoe, imacman and 4 others like this.
  7. Ambient
    Ambient
    Northern New York
    I have the SBI Osburn 7000, the same manufacturer just a different product with more bells and whistles. I gave up on using really dirty or dusty pellets for the trouble they cause. The pellet dust builds up in the auger tunnel. I would suggest this is possibly the issue. As it burns back into the auger chamber it may be the cause.
    I blow out the chamber during proper cleanings and I found I need to keep a strong air flow with the combustion and exhaust fans. Over all this does what we wanted, but it is a beast at best.
    badbob, ivanhoe, bogieb and 3 others like this.
  8. gbreda
    gbreda
    NH
    Hmmm. This year I am getting quite a bit of black buildup on the fire bricks and walls of the fire box. Mostly during low burns and cleans up on high burns.
    New gaskets, cleaned stove and piping and the pellets are OK.
    I am thinking I have a weakening combustion blower but do not have a magnahelic to measure. Unit is 10 years old so combustion blower would make sense here.
    Wonder if you are having similar issues?
  9. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Does your exhaust blower have ball bearings or bushings ??? The bushing motors need to be oiled a couple times a year...
    I use 3 in 1 blue top can oil in my exhaust fans...
    A motor that's getting dry will slow down and cause issues.
  10. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Negative pressure in the house.
    Installation in your general environment is at all limits for the stove anyway.
    imacman, badbob, ivanhoe and 4 others like this.
  11. wildwest
    Thanks Ambient and gbreda, and SmokeyTheBear.
    BUMMER, the exhaust fan is failing. It fooled me yesterday, it only spins well intermittently. Happen to open the clean out cover to look while it was spinning well, and did not cross my mind to stay there and watch it for awhile.
    Snowy Rivers , I'm sorry I don't know which it has. A few years ago Pete oiled his, I could not find where to put the oil, called Drolet and was told they are oilless.
    Also learned today there are infact 3 fans (not two). It looked like the combustion and convection squirrel cages were on the same motor and ran together, nope, they run independently.
    imacman, badbob, ivanhoe and 2 others like this.
  12. gbreda
    gbreda
    NH
    Same on the Harman. I'll give it a shot though
  13. subsailor
    subsailor
    Winthrop, Maine
    I was having the same issue last year. Changed both door gaskets last summer, no longer an issue for me. My stove is the same year as yours and I, too, suspected my combustion blower but it seems OK this year.
    imacman, bogieb, badbob and 5 others like this.
  14. gbreda
    gbreda
    NH
    Changed the firebox gasket a month ago. Didnt do the ash pan though.
    I cant imagine the ash pan wears much as it isnt opened/closed anywhere near as often but maybe?
    imacman, bogieb, wildwest and 3 others like this.
  15. badbob
    badbob
    Yes,some versions of your stove have 2 exhaust/combustion blowers.Having never worked on one,I cannot help.But,seems like you have figured it out.
  16. ivanhoe
    ivanhoe
    Northern Ontario
    imacman, bogieb, will711 and 2 others like this.
  17. IHATEPROPANE
    IHATEPROPANE
    X2
    imacman, bogieb and ivanhoe like this.
  18. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Many DRAFT/EXHAUST fans were are of the ball bearing design and do not require oil.
    Many of the older stoves like our Whitfield Advantage have Oilite (Oil impregnated bronze) bushings in the draft fan motors and require a few drops of light Hi heat type oil every few months.
    Another thing to pay attention to...VERY IMPORTANT
    The draft/exhaust fan (Has the impeller in the exhaust flow) run on a regulated voltage that is "usually" controlled based on the heat setting (Higher fuel feed...higher voltage "faster fan speed"
    It is not uncommon to have the speed control (Triac) on the control board go south and play nasty games with the fan speed...
    When you toss in a fresh fan BE SURE YOU PAY ATTENTION to the new fans activities and make sure that it is not behaving the same as the old one.
    Removing the old fan and checking it for free, smooth rotation is a good starting point...
    If the fan runs rough/noisy then it is used up and needs replacing
    Also if the fan is stiff when cold then the bearings grease has hardened up...same end result...motor has given its all.
    Didn't I read that the stove is fine on HIGH heat position ?????
    Might be a good idea to check the voltage at the fan WITH IT RUNNING.
    Back probe the connectors at the fan (USE ALL SAFETY PRECAUTIONS WHILE HANDLING LIVE VOLTAGE) Voltage at the fan is probably in the 70 volt range on low and then goes up as the heat setting is increased.
    Every stove is slightly different, and unless you can get a copy of the tech manual it's a guess as to exactly what the Manufacture had as a setting.
    Generally though the 70 volt range is probably about right on low.
    If the Triac fails/has failed the power feed can be real strange....from odd voltages to only half wave (Looking at the power on an oscilloscope the 120 volt AC is a nice wave form that curves from baseline to above the line..then below the line. (Alternating current)
    A triac control chops off segments of each part of the wave in equal parts above and below the line... this give the motor a "little shot" of power...The segments have to be in exactly the same part of the corresponding wave or the motor will be noisy.
    If one segment is weak the speed can be way off as well.
    A failure of half the wave form will usually keep the motor from running.
    Testing must be done with the motor running...
    A basic VOM will work fine Digital or analog... (Small hand held multimeter)
    Harbor freight sells some fair ones real reasonable
    God luck...BE SAFE
  19. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Yesterday was productive on the Munchy.
    Dug out the BAD AZZ mag drill (Had not used it in years) this bad boy is just plain heavy.. so rigged it with the tractor and got it up on the frame.....
    Drilled the bolt holes for the main shaft bearings with ease...
    Welded the shaft into the rotor assembly.
    welded the impact bars (1/4 inch round rod) to the rotor assembly at 4 postions.
    To achieve a nice clean fit and good clearance control against the anvil I tossed the rotor back in the lathe and machined the OD of the bars to get the clearance down to about .150" .
    The rotor is large enough that it will not clear the carriage on the lathe, so a workaround had to be done..... a long boring bar in the tool holder and machine to just beyond center and then flip the rotor end for end and machine the other side... A ROYAL PITA but it got the job done.
    A good close up shot of the finished impact bar and the anvil
    The welded front surface has the weld all the way across the face and the trailing surface is skip welded just for stability.
    I got the beast bolted back in and the pulley bolted on.... Sitting there looking at it....I was curious... I grabbed a couple handfuls of half shells and then spun the rotor pulley by hand and tossed the shells onto the top of the rotor..
    KARUNCH...... All sorts of nice little pieces flew out the bottom.. :yes:
    Today the plan is to get after the design on the sheet metal hopper.
    Pretty simple arrangement with a couple baffles to stop shells from flying out the top.
    Attaches to the frame with four 1/4" bolts
    Getting real anxious to see this BAD BOY doing it's job...
    IHATEPROPANE, bogieb and ivanhoe like this.
  20. gbreda
    gbreda
    NH
    X3 !!
