What 2 Cycle Oil Should I use?
Discussion in 'Chainsaws and Power Equipment' started by woody5506, Mar 25, 2019.
  1. Screwloose
    I just use Echo's oil. I'm impressed with the modern oils. 3 Summers ago my son ran a full tank of straight gas through my hedge clippers. I thought for sure that it was toasted but it appears to have done no harm whatsoever. Never even got stuck.
    tamarack, Horkn, farmer steve and 2 others like this.
  2. JCMC
    JCMC
    Just outside of Shushan, NY
    We had a Homelite XL that got straight gassed and run then a 32:1 mix was poured in and it started right up and ran better than ever go figure.
  3. yooperdave
    I pay no mind to what 2-cycle engine oil I buy or use; its usually the least expensive/on sale that ends up in my saw.
    But then, my saw isn't modified at all.
    But, then again, it was bought in 84 or 85. Pretty good run for all you believers in name brand oil, no?
    And las long as the can of worms has been opened, I have only paid for bar oil about half of those years. Yup, used drain oil (off and on) here!!
    :yes: :handshake: :D
  4. JCMC
    JCMC
    I am using Poulan synthetic at 40:1 plus a quarter oz. of lube control LC-20 works for me.
  5. Casper
    Casper
    Pennzoil for air cooled engines. Used it when I flew a couple hundred hours a year with a Rotax or Hirth powering a CGS Hawk. Greensky Adventures was always impressed with internals during the scheduled tear downs of the engines.
    I always ran ethanol free (tested with the olive jar trick) or avgas in ultralights. Rotax had issues with carb boots being chewed up with ethanol. We had a Rotax 582 seize in flight at Sun-n-Fun while being flown by a reporter, with only 30 hrs on both engine and air frame. This was due to a cracked carb boot sucking air. Farmer let us keep the plane in his field until Lockwood Aviation could rebuild the motor, which they did over night at the show. The fact the reporter had the seizure and Lockwood was a large U.S. distributor for Rotax was a major reason Rotax upgraded the boots as quick as they did.
    I literally trusted my life with that stuff and it served myself and others well. I figure it's good enough for my saws and I use an old Stihl 028 Super AV as a primary.
    Stlshrk, Chaz, tamarack and 3 others like this.
  6. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Olive jar trick??? Care to explain, never heard of it
  7. Casper
    Casper
  8. Horkn
    my cutting buddy runs it close to 100:1 in his stihl magnum 460, he goes a tad richer, but not much, like 90:1. He's not had an issue in like 5+ years. I'm not willing to risk it that close.
  9. Horkn
    keep in mind that any even semi modern saw is designed to run on e10, which is 10% ethanol. Ive been running e10 for over 20 years in all sorts of 2 stroke engine. not one issue.
    Yes, rotax had issues with carb boots cracking and allowing air in and running lean. they realized that thye had issues with tir boots, and fixed that. this was for sleds to pwc to ultralight engines. I personally would never use any pennzoil product if given the choice.
  10. Casper
    Casper
    The part in bold, why?
    Horkn and farmer steve like this.
  11. Canadian border VT
    A lot of people worry about what is the best oil! My mechanic told me, people should spend less time worrying about the best oil and a lot more time thinking .. did you remember to mix oil in the gas!!
  12. Screwloose
    Exactly !! I know people who will argue over oil but leave the gas cans open in the rain.
  13. papadave
    :hair::picard:
  14. bushpilot
    bushpilot
    Eastern Washington
    I'm glad someone opened it ... I use the same stuff, unless I find something cheaper.
    I mix it with the cheapest e-free I can find, which is unfortunately premium. Because I have some older equipment that I don't want ethanol in, and I don't want to stock multiple fuels in the garage, all my saws and other equipment gets the same. It costs a little more, but saves some hassle.
    Otherwise, cheap gets the job done for me.
  15. JB Sawman
    JB Sawman
    pennsylvania
    Hey farmer steve I am located glenmoore chester county pa
    farmer steve, Screwloose and Horkn like this.
  16. Slocum
    Slocum
    North Central Indiana
    I use stihl mix. I have a few of my dads saws that he bought when I was a kid. They haven’t ran for years but I checked compression a couple years ago and they all were in spec. I wish these saws had hour meters cause the have been around the block. He always used stihl mix and I will continue to.
  17. Horkn
    Because they have cheaped out and used sub par base oils in the past. I've personally seen enough sludge deposits in valve covers and oil pans from Pennzoil that I won't use it unless that's the only choice.
    It's like how I won't use fram oil filters. Except that is even more extreme when those fail, especially on a motorcycle, and they rupture, dropping oil onto your rear tire. Btdt, no thanks ever again.
  18. Screwloose
    Ever cut a Fram open ? I'm not using those to protect my investment !!
    Horkn, Sandhillbilly and OldJack like this.
  19. OldJack
    OldJack
    Saskatchewan, Canada
    Yes, I have. Not much there.
    farmer steve, Horkn and Sandhillbilly like this.
  20. Czed
    Czed
    Wv
    Found much better deal's on ebay with free ship
    Than what my local shops sell them for.
    farmer steve and Horkn like this.
