Fed up with Combustors
Discussion in 'Modern EPA Stoves and Fireplaces' started by bobdog2o02, Feb 18, 2019.
  1. Backwoods Savage
    True, but I still have much better success at 500 rather than 400.
    Chaz, Screwloose and Eric VW like this.
  2. Backwoods Savage
    As for maintenance on tube stoves, I wish I could point you to the many posts I've seen in this forum regarding this but guess you'll have to do a search. I've had not much luck with the search tool on this forum. As for your statement about pulling tubes and soaking, I don't know where you got that idea... Same with the pipe cleaner. I take that as perhaps a shot of sarcasm so wont' take it any further.
    Yes, Woodstock makes several stoves with both tubes and catalysts.
    Canadian border VT, Chaz and Eric VW like this.
  3. Canadian border VT
    I think a lot of the tube versus cat debate, is really a moot point with firewood hoarders that burn dry wood. This also goes with two companies in this area that make wood stoves. Hearthstone will not sell a cat stove because they think people don't like it. Woodstock does cat stoves because of the higher efficiency.
    Yes if you burn unseasoned wood in a tube stove. You will have to clean out the tubes because it will get clogged with creosote. Most burners on this site, will never experience that! In short buy what you want!
  4. BDF
    BDF
    All modern stoves require maintenance of some kind and to some degree (no pun intended). Secondary stoves require checking and occasionally replacing the secondary burn tubes as they age, warp and generally go to hell. Tube stoves have some type of insulating material above the tubes and that requires inspection and occasional replacement.
    I think what we really have here are that some people maintain wood stoves while others feel that as long as they hold fire, they are fine and require nothing. Both groups are right really- as long as you can light a fire in a woodstove and not have it all leak out into the house, it IS working and if that is all that is wanted, then the stove is delivering.
    This all works best when people choose a wood stove which best suits them; generally, cat. based stoves require more maintenance and have higher per- year running expenses than non- cat stoves, so I believe they are lousy choices for people who want to minimize maintenance running expenses and routine attention. It seems that these people are also not particularly interested in efficiency or anything else and simply want a wood stove that burns wood which all points toward the lower cost stoves available because in the end, any iron or steel box will work as a wood stove in fact.
    The problems crop up when a person gets the wrong stove IMO; I have not been happy with non- cat. stoves, stoves w/out an ash pan and grate and a handful of other things. None of which made those stoves 'bad', just not the right choice for me. I really do not believe this is a 'Chevy / Ford' thing as much as it is a 'Volkswagen Beetle (the air cooled ones) vs. MG' thing: if you just want to use a car to travel, the MG is a mistake. If you like to drive, enjoy tinkering (OK, if you want a dedicated second career :rofl: :lol: and just have to experience Joseph Lucas electrical systems :rofl: :lol::rofl: :lol::rofl: :lol:), get the MG.
    Just my opinions and observations, not passing judgement on anyone or telling anyone he / she is wrong.....
    Brian
  5. In the Pines
    In the Pines
    No one can prove the payback. They don't make the same stove cat/noncat.
    Impossible to empirically prove it's worth the payback.
    Yes that is maintenance for all stoves. But that isn't what was said either.
    So don't cherry pick the comment.
    stuckinthemuck likes this.
  6. billb3
    It's pretty clear what was said and what I referenced.
  7. Eric VW
    Let’s stick to the CAT discussion folks... a tube/cat debate can exist in another thread- Sound gooder? :salute:
    I hope you get some resolution bobdog2o02 if it’s possible to install a steel cat in your burner. :yes:
    Maina, Backwoods Savage, Chaz and 5 others like this.
  8. concretegrazer
    concretegrazer
    Southwest MO
    Where's the fun in that? :loco: :crazy:
    But as to the op's cat some prefer steel & some ceramic. Just keep up with the door gasket "maintenance" as cold air leaks are a major cat killer.
    Perhaps other BK princess owners should be consulted? rdust & Highbeam
  9. fox9988
    fox9988
    NW Arkansas 72717
    Yes, and window leaks. Not sure why but I remember BKVP stating that an air leak would kill a cat.
  10. DBH
    DBH Banned
    Downeast, Maine
    OK boys and girls here is one who has burnt cat stoves since the 90's...until now. Now, it's 2 non cats....none of that tube pipe cleaner stuff, or insulation blanket replacement either
    The stoves have burnt both steel and ceramic.....NO difference in longevity, maintenance, or light off except very very slight. This has been in 2 90's VC Encore 2550 used hard for heat since 2000.
    The steel cat after a couple of years deformed badly; the ceramic cat after a couple of years started to break apart. No overfires ( we're experienced users ), just normal heating use up to room temp.
    In fact, one of the cat stove makers recommended ceramic. So, there it is: ~ 12,000 hours of life + or - mileage. None of this "10 year" stuff IF the stove is used for more than entertainment or romance. :rofl: :lol:
    Sud Chemie the manufacturer of most cats had preferred their ceramic for durability when they were selling direct out of Mass.
    There you go.
    JMNSHO
    Highbeam, Chaz and Eric VW like this.
  11. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    That all makes sense now, i guess the thing that got me was the 5 yr warranty on the cat that BK offered on the new unit. As a guy coming from a non-cat...... that warranty led me to believe i should expect 5yrs. Now with 98% efficient propane recently installed i guess i'll be weighing which makes more sense
  12. DBH
    DBH Banned
    Downeast, Maine
    The VC Flexburn Encores we tried also had a 6 year warranty. Look carefully, after the first cat replacement, the next cats have the standard pro rated.
    BK has a super product as well as excellent service direct from the company. As said, if the BK would have fit we would have got the Ashford, cat or not.
    Reviews of BK and Woodstock are uniformly excellent.....as is Jotul.
  13. Locust Post
    They do not offer a steel cat for my Buck stove but I am fine with the ceramic and yes I love my cat stove. I have to hit 800 to 900 to light off. Now with that said I would be darn disappointed if I had a mess like that in 2 years.
  14. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    When my princess has a good cat in it it runs really well, not complaining about that. This 300 every two years is quite the annoyance when i thought that it would be a 5 year thing. im finding to be a bit of false advertising......
    Backwoods Savage, Chaz and Eric VW like this.
  15. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    get ready
  16. Locust Post
    3rd year on this cat and it looks good and lights off fine
  17. Eric VW
    Are these just mold-poured refractory or bona fide ceramic?
    Are they treated/coated with rare metals like Platinum as in a vehicle cat?
    Backwoods Savage, Chaz and bobdog2o02 like this.
  18. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    They look like extruded ceramic and they are plated with platinum and palladium.....
  19. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I'm guessing the mfg. Process is something like the mirrors for space telescopes. Atomized precious metal and a negatively charged receiving part.....
  20. Eric VW
    Dayum.... didn’t know we were dealing with Hubble level Chit! :eek:
    :D
