Two guesses
Discussion in 'The Wood Pile' started by jrider, Feb 16, 2019.
  1. jrider
    jrider
    E6AF7C0F-84B3-4A99-A5B7-3B81E587F723.jpeg 59D3EEB6-AC98-4B09-95D5-59C51DEE144C.jpeg I finally got around to working on the big oak logs that got dropped off. This particular log was between 14” and 16” in length and you can see the average size of my splits. The two questions are how much do you think it weighs and how many splits. I know the # of splits because I counted out of curiosity. The weight I determined by taking 20 random splits and putting them on the scale. So let’s here those guesses. Oh and that’s a 32” bar on the saw
  2. Boogeyman
    Boogeyman
    Central Indiana
    40 splits, weight of 247lbs
    metalcuttr, Chvymn99, Horkn and 7 others like this.
  3. Eric VW
    Red oak family.... 325 lbs. 58 splits....:salute:
    What’d I win???!
    metalcuttr, Chvymn99, huskihl and 8 others like this.
  4. Marvin
    Marvin
    Huntingdon, Pa
    48 splits 416 lbs
    metalcuttr, Chvymn99, Horkn and 5 others like this.
  5. amateur cutter
    My Red Oak blocks at 2' long & 36" dia run North of 600LBS. & yield about 30 splits, but I split big. Gonna say 375 & 42 splits.
    metalcuttr, Chvymn99, Slocum and 3 others like this.
  6. Chaz
    Chaz
    Southwestern NY
    50 splits.. 327 lbs
    metalcuttr, Chvymn99, Slocum and 4 others like this.
  7. M2theB
    M2theB
    Central Massachusetts
    70 splits
    210 lbs
  8. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
    283 lbs. 113 splits.
  9. mr.finn
    mr.finn
    Mass
    I'll play this one. Pin Oak, 350 lbs and 64 splits.
    metalcuttr, Chvymn99, Chaz and 5 others like this.
  10. moresnow
    moresnow
    :popcorn::cheers: Just going to watch this!
  11. JustWood
    JustWood Guest
    491 lbs
    71 splits
    metalcuttr, Chvymn99, Chaz and 3 others like this.
  12. billb3
    a 32 x 16 inch cylinder would be 2.9 x 1.3 feet = um, 8.5 cubic feet cubic feet ; oak weighs 45 pounds per cubic foot, so 45x8.5 = 382 pounds
    guessing 64 splits
    edit: 64 is taken so I'll do 63
    2nd edit: 2nd guess seeing as there are 2; 381 pounds 65 splits
  13. billb3
    What's the prize?
    One dry red oak split to be picked up three years from now on Feb 16, 2022 at 7:55AM ?
  14. Paul bunion
    Paul bunion
    Bring one piece inside by your stove and weigh it tomorrow. It’s amazing how much it drops. Probably 10% of its original weight in 24 hours if that wood was cut green and just came off the stump.
    Green of the stump oak will lose about 40% of its original weight.
  15. imwiley1
    imwiley1
    Wisconsin
    300lbs and 45 splits. PM me for prize mailing address.
    metalcuttr, Chvymn99, Chaz and 4 others like this.
  16. jrider
    jrider
    Except that bar doesn’t reach the ground and it’s about 10”-12” wider than it is tall
  17. jrider
    jrider
    So far there’s been one person fairly close to the number of splits
    metalcuttr, Chvymn99, Chaz and 2 others like this.
  18. billb3
    I was being too conservative with actual usable bar length ?
    metalcuttr, Chaz and amateur cutter like this.
  19. brenndatomu
    310 lbs EDIT: that was dried...green is 443 lbs.
    47 splits
  20. amateur cutter
    Did the log lift pick it ok? Did you run it through the 6 way on the first pass?
