New to me splitter
Discussion in 'Chainsaws and Power Equipment' started by dwyleecoyote, Feb 13, 2019.
  1. dwyleecoyote
    dwyleecoyote
    Vermilion, OH
    Good morning all. I just got my hands on what I believe to be around a 20 year old splitter, in remarkable condition for the age. Long story short, a good friend and neighbors house exploded, and he has declared he isn't planning to heat with wood in the rebuild. He told me to take the splitter.
    So anyway, it probably has not been run in 2 years. He preferred to split by hand, so it sat a lot between uses. Around 2 years ago he put a cheap chinese carb on it, and said it was never right after that. I only made sure it spins, did not waste gas trying to start. I have ordered an OEM carb. Also replacing fuel lines, shut off valve, oil, spark plug, air filter cartridge, and air filter foam. Also the hydro filter, as it appears to have the original still in place. I have used this splitter before I had my own, and I recall the auto return detent not always holding, I have researched a few tricks for that.
    Anyway, my question here, is does anyone have experience with this weird shim system it has? It seems more complicated then things need to be, the blocks fall out, and I am thinking of just replacing it with a nice stout bracket. Any reason I shouldn't? The contraption in question is the third pic. 20190212_193746_resized.jpg 20190212_193810_resized.jpg 20190212_193827_resized.jpg
    Edit to add: The explosion was not directly caused by the wood burner. A car hit his gas meter and filled the house with gas. There were multiple ignition sources available, and things went bad quickly. Everyone got out, and the only minor injury was a nearby deputy.
    M2theB, bear 1998, WeldrDave and 14 others like this.
  2. brenndatomu
    My neighbor has a splitter like that...he has issues with it breaking the bolts on the wedge slide bracket thingamabob there...
    M2theB, bear 1998, mat60 and 4 others like this.
  3. Backwoods Savage
    We have one like that. An MTD 20 ton with 5 hp B&S engine and love it.
    The shims are said to need replacing but I have never done so. I remember getting a lit of wobble in the wedge so did make something for a shim but don't remember what I did. It was a cheap fix. Splitter is well over 20 years old. I think around 30 years now. We did replace the engine but that is another story. Should not have had to do that but sometimes when you lend out machines they don't always come back as they should...
    If you like I can dig out the manual and print out for you what they say to do with the shims. Just let me know.
    M2theB, bear 1998, WeldrDave and 4 others like this.
  4. dwyleecoyote
    dwyleecoyote
    Vermilion, OH
    The info about the shims would be helpful. I looked around a little online, and it looks like they are just 5/8 bar stock. I haven't asked my buddy if he might have the book. Only chance is if it is in the garage, which is also totaled, but still standing. He has enough to worry about right now. If it's easier, you could just take a picture of those pages and post them? Maybe I will make up a set and put them in, and do something different if it is a problem down the road.
    M2theB, bear 1998, WeldrDave and 8 others like this.
  5. Backwoods Savage
    Okay. Will look up the book in a little bit. If not today then tomorrow for sure.
    bear 1998, WeldrDave, Hammy and 4 others like this.
  6. Canadian border VT
    Glad your friend ok!!
    M2theB, bear 1998, WeldrDave and 7 others like this.
  7. Backwoods Savage
    I don't know if this number is still in operation but is in the manual: 800-800-7310 for Parts and Service
    Thought you might also like the following for filling with fluid.
    If any other information is needed, just ask.
    bear 1998, Stlshrk, Hammy and 10 others like this.
  8. dwyleecoyote
    dwyleecoyote
    Vermilion, OH
    Thanks. It was one hell of a night, and not in a good way.
    bear 1998, WeldrDave, Hammy and 6 others like this.
  9. Casper
    Casper
    I have a White Equipment version. It's 28 yrs old and the I-beam is showing some wear where the gibs ride. Thinking of welding the worn area back up and milling it flush with the unworn parts.
    Thread drift...
    Is this the one on WKYC where the guy who hit the gas main fled and was caught/turned himself in a few days later?
    House explodes in Vermilion after vehicle crashes into gas meter
    bear 1998, Hammy, Midwinter and 4 others like this.
  10. amateur cutter
    Wow! So glad to hear no serious injuries, but what a loss. No real help on the splitter, but it looks simple enough.
    bear 1998, Hammy, Midwinter and 3 others like this.
  11. dwyleecoyote
    dwyleecoyote
    Vermilion, OH
    Yes, that's the one. I was about 100 feet away when it blew, driving away with my buddy who didn't even have time to get dressed. I was just clear of the debris field. Fire page first, less then 30 seconds later call from him. It was -6 at the time.
  12. dwyleecoyote
    dwyleecoyote
    Vermilion, OH
    So in the saga of the splitter, I think I am missing a governor/throttle spring. I think there should be a fine spring that goes where the throttle links up to the carb. It seems like it is running too fast. There is a spring on the diagram that I do not have. I may order the spring, and I will order a tach if I can find out what speed it is supposed to run at. Briggs engine #0195412 1137 01. The spring in question is item 232 on the Briggs diagram, if anyone has any words of wisdom. With the new carb and other parts on it started right up, just need to get things just right.
  13. Casper
    Casper
    Is it the 5hp industrial B&S?
    bear 1998, Hammy and amateur cutter like this.
  14. Stoveburner38
    Stoveburner38
    Springfield,ohio
    I seen that explosion on the news glad the splitter and family made it out ok...
    bear 1998, amateur cutter and Hammy like this.
  15. dwyleecoyote
    dwyleecoyote
    Vermilion, OH
    It is an 8 horse.
  16. dwyleecoyote
    dwyleecoyote
    Vermilion, OH
    So after installing the missing spring, it made no discernable difference. Took it to an old friend of my father's that has a small local shop. $25 later it doesn't sound much different, but I can see where he moved all the adjustments, and said he set it at 3600 rpm, so I am comfortable running it. A couple more tweaks to that gib thingy, and it will split wood side by side with my huskee.
  17. dwyleecoyote
    dwyleecoyote
    Vermilion, OH
    Well, the kids seemed happy with the faster cycle times, they ran a tank of gas through it. Tried flipping the shaft on the control lever, but it still won't hold in return position. Still have to change hydraulic filter and fluid before I tinker with that more. Overall very happy. 20190302_161456.jpg
  18. brenndatomu
  19. dwyleecoyote
    dwyleecoyote
    Vermilion, OH
    Yeah, it just has to wait it's turn though. Maybe this weekend, but I have to take care of the charred maples from the explosion house this weekend, before I will get a chance to fire up a splitter again. Dropped them last night, and got them out of the way, heavy demolition and cleanup equipment is supposed to show up this week. Always something going lately....
  20. amateur cutter
    Yeah, I mean how busy could be right after your friend's house blows up right? Patience dwyleecoyote , stuff'll get done in due time.
    Hammy and brenndatomu like this.
