Harman P61a floppy flame guide?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Feb 5, 2019.
  1. don2222
    don2222
    Salem NH
    Do they have the air notches in the back?
    The one on the left has the air notches for the Fluted Burn Pot!
    Ssyko and bogieb like this.
  2. ZBrooks
    ZBrooks
    Kuna, Id
    The burnpot that came with my P61a-2 (new in 2014) looks like the new burnpot in your second set of pictures. Same burnpot that came with the auto ignite kit that I used to update my older P61.
    Ssyko and slvrblkk like this.
  3. bogieb
    My P61a has the flat one and the P43 has the curved one. Maybe it depends on year?
    Ssyko, slvrblkk and ttdberg like this.
  4. bogieb
    Neither of mine have those notches.
  5. don2222
    don2222
    Salem NH
    Thanks for checking.
    As far as I know that is correct, but the new Fluted Burn Pot is made for the newer Accentra FS & Insert, P43 and Advance.
    Although you may want this upgrade!
    Last night the temp was down into the 20’s.
    I just ran my P61a on Room Temp in the basement with the Fluted Burn Pot with the air notches in the flame guide and WooHaHo we had to keep turning the temp dial down so we would not Roast like a coffee bean!!!! At 3:30 am had to turn it down again because the bedroom was getting too hot!!! More heat with less pellets!
  6. Lousyweather
    Lousyweather
    all good theory and conjecture here! Harman actually has 3 flame guides:
    1. 3-00-03000
    2. 3-00-08534
    3. 3-00-06644 (pretty much just the Advance)
    I dunno.....I am on the fence for replacing a burn pot and gaskets and flame guide, given the cost of doing so, verses the purported gain in heat value by changing such. I think one might be better served by keeping the heat exchanger (and stove!) clean.
  7. ttdberg
    ttdberg Pellet Pig
    CT
    Yup maybe they switched during a model “refresh” year. Perhaps at the same time they switched over to the UL feeder for a given model? My P68 is a 2008 and P43 is a 2014 and they both have the arched guides with notches. How old are your stoves?
    Ssyko, bogieb and slvrblkk like this.
  8. don2222
    don2222
    Salem NH
    Yes I agree with that.
    In my case, the pot in the stove was an old used pot which I thought was good until the flame guide kept sliding! Very Frustrating!!
    Since I replaced the burn pot with a brand new burn pot, No More Floppy Plane guide!! So that did actually fix the problem!!!
  9. bogieb
    The P43 shows a date of Sept. 2012 and my P61a is Oct. 2013. Now when they were actually made is anybody's guess - at least my limited understanding is that date is when they ship to a dealer (I could be misremembering though).
    Ssyko and ttdberg like this.
  10. don2222
    don2222
    Salem NH
    My 2 P61a stoves are about 15 years young and my Advance is about 14 years young
    My Quadrafire Contour is 18 years young and can still do the pie warming in the warmer compartment and I will never part with it!! I use it to warm my shed. They all work like brand new!!
  11. badbob
    badbob
    The "fluted"? burn pot is for Accentra inserts,but not the FS.The accentra 52i also has an updated pot,but that has been out for a while.
  12. don2222
    don2222
    Salem NH
    According to this, the updated Fluted Burn Pot is for all of these stoves.
    It works great on my P61a too!!
  13. badbob
    badbob
    Yes,I was just pointing it out,as it is not for the FS,as your other post said.Anyway,there is an up dated pot for the FS.Looks the same as the old pot,except,just ahead of where the flame guide rests,there are 2 raised bumps.HHHMMMM??
    Ssyko, bogieb, jtakeman and 2 others like this.
  14. don2222
    don2222
    Salem NH
    Is it a Fluted Pot?
  15. badbob
    badbob
    Um,no,looks like bumps to keep the flame guide in position,although the instructions say a new flame guide purchase is necessary.I did not research it,and look at the recommended flame guide.
    Ssyko, bogieb and don2222 like this.
  16. don2222
    don2222
    Salem NH
    Hello
    It has been a week and the same flame guide on the old Burn pot has not moved 1 mm on the new burn pot. Therefore, it was not a dirty stove or the flame guide it was the older burn pot!!!!
    So the case of the floppy flame guide is closed!
  17. badbob
    badbob
    Cool
    bogieb likes this.
