Fun repairing home PC
Discussion in 'Everything Else (off topic)' started by Horkn, Jan 14, 2019.
  1. Horkn
    No, I just swapped the old stuff. Will it boot if there is no ram? There's 4 ram sticks. Do I need to have them in pairs, or particular slots?
    brenndatomu, In the Pines and Chaz like this.
  2. Horkn
    Yellow light is on the motherboard and on the front of the case when I attempt to power it up. The CPU fan does not spin.
  3. Grizzly Adam
    Grizzly Adam Guest
    No ram=no boot. Bad processor = no boot. Bad fan = no boot. Sometimes, not often, bad video card = no boot. If there is onboard video, take the external video card out of the equation.
  4. Horkn
    The yellow light in the mobo
    This led comes on as soon as I turn the PS switch on. It goes out after a few seconds when I unplug/turn it off.
    And in the power button
  5. Horkn
    I don't think this unit has onboard video board. That's a separate card that I swapped over to the new Mobo. I think that led in the mobo tells me the power supply is good. Right?
    I'll try switching RAM around.
    Gotta go out to dinner and drink some tequila soon.
  6. Grizzly Adam
    Grizzly Adam Guest
    Light on the motherboard is a sign that there is power. Suggests the problem is not the power supply.
  7. Chaz
    Chaz
    Southwestern NY
    This seems to be a problem, and if the fan was dying it likely took the processor with it.
    I don't think the processor can even run a second or two without a fan. They generate a lot of heat.
  8. In the Pines
    In the Pines
    Do you have any parts other than the power supply you can swap out for testing?
    a spare video card by chance?
    does the cpu fan spin at all when you hit the power button?
    they will usually (iirc) do a quick spin up even in a non-boot situation. That should rule out if the cpu fan is bad.
    Horkn, brenndatomu and Chaz like this.
  9. brenndatomu
    I'm a complete PC dummy...but would a locked up fan do it...as in maybe just needs cleaned and a bit o lube? I dunno...complete hail mary here...just ignore me if I'm out in left field (I'm used to it ;) :whistle:)
  10. ironpony
    ironpony
    Mid Ohio
    24 oz. ball peen hammer time...............
    Loon, Horkn, In the Pines and 3 others like this.
  11. papadave
  12. Grizzly Adam
    Grizzly Adam Guest
    No, they don't typically lock up like that.
    wildwest, Horkn, In the Pines and 2 others like this.
  13. Creekin
    Creekin
    Manitoba
    24 oz wouldn't do it, 5 lb is so much more satisfying!
    Loon, DaveGunter, Chaz and 2 others like this.
  14. justdraftn
    justdraftn
    On the road
    On boot, have you tried hitting F2 key to load the BIOS or
    the internal diags?
    Either of those two things will tell you more.
  15. Grizzly Adam
    Grizzly Adam Guest
    He said it doesn't boot.
    Horkn, Chaz and In the Pines like this.
  16. justdraftn
    justdraftn
    On the road
    ...ok...when you turn it on,
    if you it the F2 key,
    does BIOS or the internal diags load?
  17. DaveGunter
    DaveGunter
    Where's Stinny he "fixed" his laptop once.
    wildwest, papadave, unclefess and 3 others like this.
  18. Horkn
    Ok, I'm back guys. I think this may be the issue. Chaz the fan on the cpu doesn't spin up at all. I do have an old Dell desktop that this one replaced in the basement. I'll see if there's a fan I can steal.
    Chaz likes this.
  19. Horkn
    brenndatomu , yeah, I cleaned it all up before I swapped the old cpu heatsink and fan . There was a lot of dust on the CPU heatsink. Not clogged, but enough. The fan spins freely bt hand.
    Chaz and brenndatomu like this.
  20. Horkn
    Correct. No boot.
    Would it be possible to swap a different/faster CPU into this mobo? Or would I have to drop in the exact or same "family/series" of CPUs?
