Stove U P S babble
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by jtakeman, Jan 21, 2019.
  1. CleanFire
    CleanFire
    I'm not a fan of refurb units only because depending on the (original) issue, you may be inheriting someone else's headache.. but given the present need.. if it makes sense - then sure - go for it.
    slvrblkk, ivanhoe and jtakeman like this.
  2. jtakeman
    I should not have told the Mrs. about saving 1/2 the :makeitrain"...................... :BrianK:
    Looks like we are steering towards a Tripp Lite OMNIVS1500XL as it has way more capacity on the extended battery option. Not sure its true syn though. Need to do some more diggin!! But instead of only 9 amp hr add on, It has 10 different options on the additional battery. So I might be able to slave in my boat AGM batteries in the off season for longer back up. also says you can hot swap them which is also cool!! :cool:
    OmniVS 120V 1500VA 940W Line Interactive UPS Extended Run Tower USB port (OMNIVS1500XL) | Tripp Lite
    imacman, CleanFire and ivanhoe like this.
  3. jtakeman
    Gonna need assistence on what connectors I can use for attaching more back up batteries!!
    See letter F in image.
    Rich250, CleanFire and ivanhoe like this.
  4. slvrblkk
    slvrblkk
    Northampton, PA
    Jay... it'll be this... The external battery pack should already come with it
    gbreda, imacman, jtakeman and 3 others like this.
  5. ivanhoe
    ivanhoe
    Northern Ontario
    pulse-width modulated (PWM) sine wave so not pure sinewave!
    gbreda, imacman, Rich250 and 4 others like this.
  6. stuckinthemuck
    stuckinthemuck
    Did you contact Enviro to see what the power requirement is? If you only need modified sine wave then the above appliance should work. If you need pure sine wave, you will need something else...
    Just stumbled across this product which says it is pure sine wave and you can adjust the number of batteries to suit your needs...
    Stove Sentry: Emergency Backup for Pellet Stoves and Kerosene Heaters
    Looks like the 707 would be appropriate. The 500 series are not pure sine wave..
  7. jtakeman
    Ya I figured, So far most of the expandable models have been PWM. Looks like triplite smart series is about the only one I see thats pure sine and expandable.. Looking for deals on this one right now.
    SMART750XLA
    :eek: :makeitrain"
    I will do some looking into them. I do like the fact you use your own agm's.
    Rich250, ivanhoe, slvrblkk and 2 others like this.
  8. CleanFire
    CleanFire
    I think there's one complete setup listed up on CL for about 3 benjamins currently.
    No real experience w/ the TrippLite ups units (just wasn't in my IT universe / was always APC) but have used & installed more than a few of their line conditioning devices: always impressed w/ the quality & high grade components in those devices - heavy (!) duty and long life, in my experience.
  9. jtakeman
    Had a free minute tonight after work so I stopped over to the puter shop I used to ticker with. He's got a brand new in the box Tripp Lite SMART750RMXL2U I can have for $150 bucks!! :D
    :banana: :makeitrain" Now I just need to talk momma into it! :eek:
    SmartPro 120V 750VA 600W Line Interactive Sine Wave UPS 2U Rack Tower Extended Run SNMPWEBCARD Option LCD Display USB RB9 Serial (SMART750RMXL2U) | Tripp Lite
    Seems funny, I get all dis chit figure out and not a flicker today!!
    Looks like I'll need a 75 amp male DC connector too. Hoping a local source will have one.
  10. jtakeman
    I didn't read the fine print and it looks like the tripplite drops to 450 watts once you slave in extra battery capacity. It'l be close on start up............ o_O Maybe just use it like I initially intended and slave in a relay in the stat circuit so it just cycles off? I'll have to test it out good first!!
    Found the connectors, Seems us bass boat guys use them on the power poles(shallow water anchors)!! :D ordered a couple sets for $20 clams from the local marine dealer. Woot!!
    Edit: Forgot to post pictures last night. Here they are for proof. I'll pick it up on my way home tonight!! :) Start building a rack/stand for it between watching the rolex 24. :D
    imacman, Rich250, CleanFire and 3 others like this.
  11. jtakeman
    CleanFire I know you said not to stab batteries into a UPS. But these units had me curious when I looked at the charts for optional storage. Seems they are way more expandable than I'll even need!! Popping in my 2 12v agms(24V in series) would be like adding 3 of the BP24V70-3U pack's. 70 is the AH rating, So 3 is approx 210 AH and the 2 AGM together would be really close. Just need to configure the UPS to 3 packs! :)
    Also want to thank all you fella's for the input and idea's. Much appreciated! I'll keep ya all posted on the testing of it. Worser case is I have a stand alone unit to buffer the blips!!
    ivanhoe, Rich250, CleanFire and 2 others like this.
  12. slvrblkk
    slvrblkk
    Northampton, PA
    :thumbs:
    imacman, ivanhoe, Rich250 and 2 others like this.
  13. CleanFire
    CleanFire
    I did JT - on the newer "consumer grade" UPS units, the recharge circuitry has been reduced, for size & weight. Both APC and Cyberpower units do a "slow recharge" now, spec'd to the internal battery pack - takes 6/8/12 hours to slow charge the batteries, after power is restored. That APC BR1500G unit you were looking at, being 1 generation back vs. current: is one of the units that still has more capable recharge circuitry / external expansion capability in a mid-range UPS model.
    But that bad boy there - sure has the "stones" to handle what you want to do .. you "wild-and-crazy" guy.
    x2! :thumbs:
    :popcorn:
  14. jtakeman
    I'm likely not gonna trust the built in charger. I have a auxiliary I use on the boat batteries. 60 amp boost, 10 amp and 2 amp trickle. Seeing I can hot swap the batteries, I'll disconnect and use the boosted charger and save the units built in...... JIC.
    imacman, ivanhoe, Rich250 and 3 others like this.
  15. bogieb
    My guess is NO since this is one of two UPS' recommended by Harman for a controlled shut down in case of power outage. That means they have tested it and found that the stove can tell when it is using the UPS versus outside current.
    Oops, see you already got that answer.
  16. krooser
    krooser
    Waupaca, WI
    I used to work for UPS...
    imacman, ivanhoe, CleanFire and 2 others like this.
  17. jtakeman
    Hopefully get to play this weekend. Waiting on cable connectors........
    imacman, ivanhoe and CleanFire like this.
  18. jtakeman
    Welp got the rack built and started playing. Found the unit would not turn on. Started checking battery voltage and they were "way" low. Charged all night and still no power on?? Pulled the batteries out and bench charging. Both were at 4 volts! o_O They are charging though......... Just wrenched the works. I'll bring them up to 9 volts with a low amp wall wart. Hoping the unit will begin to charge them after that??
    Otherwise I gotta go out and get the gennies maintainer/charger. :rolleyes:
    Rich250, imacman, ivanhoe and 2 others like this.
  19. slvrblkk
    slvrblkk
    Northampton, PA
    Jay....what batteries are in that unit?
    12v 7Ah?
    Rich250, ivanhoe and bogieb like this.
  20. jtakeman
    12v 9Ah
    I'll get the number and post after we fetch more pellets! Dinner first. Me starving!
    edit: Wifey is dillying..... SO! :)
    Pics of battery. Part number HR9-12
