Help!! Tube came off...
Discussion in 'Chainsaws and Power Equipment' started by Marvin, Jan 12, 2019.
  1. Marvin
    Marvin
    Huntingdon, Pa
    So I took the cover off of my cs2165 to clean it up a bit and bumped this tube. It came off and I am not positive where it goes. I was kind of guessing it goes on the outlet on the right side of the pics below but wasn't sure. Where does it go from there though? Any help would be appreciated!
    Hammy likes this.
  2. huskihl
    huskihl
    Might be part of a tank vent. That's the only other hose I can think of. Is there a fitting on the air filter elbow? I think that's only on the 390 though
    Hammy, HDRock and Marvin like this.
  3. Marvin
    Marvin
    Huntingdon, Pa
    I dont see one. I was thinking it fit on the "nipple" (not sure what else to call it) just under the right end of the tube on the second pic. I just cant figure out where it would go from there. Maybe the hole just in front of my index finger on the second pic? That just vents out of the compartment.
  4. Marvin
    Marvin
    Huntingdon, Pa
    I had the saw tipped on its side (oriented as if I would be filling with fuel) and noticed a small leak of fuel coming out under here somewhere. Would that have anything to do with it?
    Hammy likes this.
  5. Easy Livin' 3000
    Easy Livin' 3000
    North side of the ridge
    I can't help you, but to commiserate. I do $hit like this all the time. Frustrating, but I bet you'll get your answer here soon.
    Hammy, HDRock, Ou812 and 1 other person like this.
  6. Marvin
    Marvin
    Huntingdon, Pa
    Thanks Ed. Yeah I am a diy type of guy when I shouldn't be all the time :rofl: :lol:
    I'll tell you one thing though, after I get this straightened out it wont happen again cause next time I'll know. :thumbs:
    Hammy, HDRock, eatonpcat and 2 others like this.
  7. huskihl
    huskihl
    It's gotta be part of the tank vent. It'll probably need some disassembly to get it back where it was. If you take the handle bar off and remove the left a/v screw above the fuel cap, you can lift the case/carb floor up away from the rear handle to reconnect it.
  8. MAF143
    MAF143
    North Central OH
  9. Nixon
    Nixon
    West Sunbury,Pa .
    A769532E-931F-4117-BEB8-36193D4C0B71.jpeg 3717A086-FED9-4052-A95A-3196D7F40EFD.jpeg That is your vent tube . One end connects to that fitting just in front of your carb’s fuel line .the other end goes to the fuel vent check valve in the rear handle .
  10. Marvin
    Marvin
    Huntingdon, Pa
    Thanks everyone for the help. I got it back where it belongs.
  11. Easy Livin' 3000
    Easy Livin' 3000
    Nice outcome, Marvin.
    And, thanks for the help, Nixon. Helpful pictures.
    Nixon, Hammy and Marvin like this.
  12. Marvin
    Marvin
    Huntingdon, Pa
    X2 :thumbs:
    Nixon and Hammy like this.
