My 576xp just quit. Looking for guidance
Discussion in 'Chainsaws and Power Equipment' started by mywaynow, Dec 8, 2018.
  1. cnice_37
    cnice_37
    Not sure why you are willing to pull a flywheel and throw money at a coil but not pull the muffler and have a look??
    The 89ohms reading sounds way high, if I read the report correct. It does sound like coil, but I always pull the muffler for a quick look.
    Hammy, Stephiedoll and amateur cutter like this.
  2. Barcroftb
    Barcroftb
    The Mitten
    I suspect your coil is bad. A good coil should measure between 10 to 400 ohms(not k ohms). If you want to test your multimeter turn it to the lowest resistance setting and try a known good coil on one of your other saws.
    Hammy, amateur cutter, Horkn and 3 others like this.
  3. mywaynow
    mywaynow
    Welp. Perhaps the culprit has been found:
  4. mywaynow
    mywaynow
  5. Horkn
  6. huskihl
    huskihl
    I'm gonna go out on a limb and guess that the crank bearings are bad and ruined the seals.
  7. brenndatomu
    Oh man, that sucks. :hair:
    That's why a compression test is needed..."it pulls over hard" doesn't necessarily mean much
    basod, Hammy, cnice_37 and 4 others like this.
  8. amateur cutter
    Actually it does. It means it's got compression, or it's almost seized. That's too bad & l'd bet Kevin's right about the seals.
    basod, Horkn, Hammy and 2 others like this.
  9. cnice_37
    cnice_37
    Yeah that's what I was fearing.
    Block off the intake and exhaust and pressure/vac test. You're in deep now.
    basod, amateur cutter, Horkn and 2 others like this.
  10. MasterMech
  11. mywaynow
    mywaynow
    Intake side of the cylinder is nearly perfect. At least that which I can see over top of the piston. Guess I am going to pull the cylinder over the weekend and get a real read on how bad this is. What do I look for as far as the crank bearings being bad?
  12. huskihl
    huskihl
    Try to wiggle the flywheel up and down or front to back
  13. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    Ouch! I don't know the saw. I'm sure there have been quite a few rebuilds over the years. Maybe some will lead you in the direction for the most economical oem rebuild options.
  14. mywaynow
    mywaynow
    I checked that when I pulled the fly to check the key. All good and tight there.
    Gent at the shop where I picked up the coil said to look at the exhaust side of the cylinder for damage. Apparently the garbage mixture of what is called gasoline in NJ may be the culprit. Ethanol clinging to water that evaporates at the hotter exhaust side leaving little to no oil on the piston/cylinder. Hope to post some less than ugly cylinder pics later. For now it's off to the woods to do my imitation of a squirrel.
  15. Casper
    Casper
    Looks a lot like our old Arctic Cat ZR440 that had an O ring in the head go bad. Coolant leaked into cylinder, and poof, no more residual oil. It looked very similar. I sent cylinder out to have it reworked and am putting it back together at the next opportunity.
  16. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Hey huskihl , that wiggle looks familiar. Still need to get that saw off the shelf and fire it up. mywaynow listen to him, he knows his stuff. When I fried my 660 I was sure it was the mix that was left in for close to a year. I would have just threw a piston/cylinder on it and burned them up too. So happy I listened to huskihl and many others here. It saved me pizzing away more money on the saw. Between work and having issues shaking something I just have not gotten out to work on all the wood that needs processed. Good luck getting your saw back in wood.
  17. Horkn
    I wouldn't be so quick to assume that all was caused by ethanol. I've been running ethanol for ~30 years on all sorts of 2 strokes and the only time I got a burn down that bad was due to carburetor issues ( my tuning, not a mechanical issue) on a rotax 521. It was a cold cold weekend and the sled was running really nice and crisp.. well until.....
    basod, huskihl, Hammy and 5 others like this.
  18. Barcroftb
    Barcroftb
    The Mitten
    If it was my saw I'd pressure/vac test it before I did anything. That looks like more than just ethanol damage.
    basod, huskihl, Hammy and 6 others like this.
  19. The Wood Wolverine
    Agree'd ^^^
    basod, Hammy, Barcroftb and 3 others like this.
  20. brenndatomu
    Yes, this ^ ^ ^
    basod, Hammy, Barcroftb and 4 others like this.
