Fireview 201 door air flow settings
Discussion in 'Modern EPA Stoves and Fireplaces' started by BCB, Dec 8, 2016.
  1. Backwoods Savage
    I'm not sure of all the gaskets in that stove but as for replacing, if one goes bad we just replace the whole gasket. We're into our 12th year with our Fireview and have replaced all gaskets once. The top lid gasket has been replaced twice. It seems that gasket went bad after only 2 or 3 years.
    Maina and Chaz like this.
  2. Woody Stover
    Woody Stover
    Southern IN
    Is that the bypass door gasket (I don't think it's in the front of the box, though..?) It might come loose, but should last longer than 2 yrs. without smashing down too much. Some compression will happen though..
    I use OEM gaskets, not the farm store or stove shop stuff; That way I can be certain that the gasket is the type and density that the stove maker wants in there.
    Maina likes this.
  3. BCB
    BCB
    USA
    No this is the baffle gasket that was sent to me from Woodstock with their gasket replacement kit.
    Maina and Marvin like this.
  4. Todd
    Todd
    NW WIS
    I like those older style Woodstock's. I bet that style of baffle allows a little more room in the firebox? Ive also heard that upper cat chamber is a good place to bake potatoes.
    Maina likes this.
  5. BCB
    BCB
    USA
    I haven't seen a 205 in person so I can't compare the room in the firebox. I do know that the cat location on my 201 is different from the 205 which has the cat in the center. I've heard about making hobo potatoes in the top of the stoves but I haven't tried it out yet.
    Maina likes this.
  6. BCB
    BCB
    USA
    Time to order a new baffle :( I was cleaning out the top of the stove this evening and noticed a long crack on the baffle near the cat cover.
  7. BCB
    BCB
    USA
    New baffle arrived the other day. Not looking forward to making a mess tbh lol.
    Loon and fox9988 like this.
  8. BCB
    BCB
    USA
    Installation day for the new baffle. Mid-60s and rainy so no outside work today.
    I took a pic of the old one so you can see how bad the crack was.
    E532118B-7A3E-45DD-A37B-F912F0206394.jpeg EF99BDD5-1BAB-4648-A713-48F61C4FD85A.jpeg C9630E31-50E4-41E0-8492-250A4B302856.jpeg
    Slocum, billb3, brenndatomu and 2 others like this.
