Cast Iron waffle maker whoops...
Discussion in 'The Smokehouse' started by FatBoy85, Oct 27, 2018.
  1. FatBoy85
    FatBoy85
    Washington State
    This morning I had a hankering for something like waffles so I tried the cast iron one I grabbed when my grandpa passed since we found that one before the electric one. Had it all seasoned and greased up but didn’t turn out well...hm. 7864A6A4-7C33-43B0-A3CC-5E68FEE8FBBF.jpeg 0722BB68-068F-4346-8928-203E488C400E.jpeg FCBBFDD6-AA75-4BB1-B4E1-284B083A30F7.jpeg
    If I didn’t do a dang thing right, let me know. I sure would like to use it but if it’s a hanging piece for the wall...bummer.
    J. Dirt, Thor and fishingpol like this.
  2. Chaz
    Chaz
    Southwestern NY
    Well, that certainly doesn't fall into the 'like' category.
    :confused:
  3. FatBoy85
    FatBoy85
    Washington State
    It’s a bummer for sure, I just hope someone has a couple tips for me, I never really got this off the ground. But I’m not one to give up on cast iron, I enjoy cooking with it too much!
    T.Jeff Veal, Thor and Chaz like this.
  4. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    If the recipe calls for veg oil, I'd add a little bit more in. The waffles may come out a little crispier. Try cooking spray, if it smokes, then probably too hot. Start with a lower temp. Test with a tablespoon of the mix and see if it releases.
    I have a cast iron krumcake maker that did the same. I did the above and it worked out well. Keep trying. Looks like a pain to clean that one.
  5. FatBoy85
    FatBoy85
    Washington State
    Yeah it was a little bit at first but after soaking it for an hour or so it wasn’t too bad. As much as I would like to use it, sometimes this kind of iron was used by someone who really knew what to do with it or used it so often in that manner.
    I know of a recipe that involves melted butter in the mix instead of veggie oil,Butter might have better non stick properies if used in right proportions ?? Not gonna throw in the towel, on this yet. Thanks for the input!
    T.Jeff Veal likes this.
  6. woody5506
    woody5506
    Upstate NY
    My guess is too much heat was used. Try it on low but let it preheat for a while. Almost everything I cook stays on low with a long pre heat.
    T.Jeff Veal and FatBoy85 like this.
