What's The Best Way To Stack On Pallets?
Discussion in 'The Wood Pile' started by Ralphie Boy, Aug 11, 2018.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I want to open up more space in my wood storage area by elimanating some of the long lines of well seasoned, single stacked wood. This fall I'm expecting to have another 25 to 30 trees to process and I want more room to single stack the new stuff for the next 3 or 4 years.
    I'm thinking about condensing long rows into stacks on squares of 4 pallets. Any thoughts on how to stack? Interlocking rows some how. Pictures would be great, I'm a visual learning kind of person. Thanks!
    :salute:
  2. Chaz
    Chaz
    Southwestern NY
    I wouldn't interlock rows, just crib the ends and fill in between.
  3. Eric VW
  4. OhioStihl
    OhioStihl
    Southern Ohio
    Do you have to single stack? I stack two rows on a pallet with an air space between them for drying.
  5. Backwoods Savage
    If the wood is stacked indoors, I have to ask why even use pallets? Stack right on Mother Earth or on cement or whatever the floor is.
  6. brenndatomu
    I stack mine just like this...2 rows wide leaving an inch or two (or 4) between the rows...every now and then I take a split and put right in the middle, half in each row, just like OhioStihl has right on the end of his stack there. It ties the rows together for much more stability...you can stack a short or ugly on the ends of the "tie split" to keep the stack go up nice n level.
  7. milleo
    milleo
  8. TurboDiesel
  9. TurboDiesel
  10. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I have a low ceiling on my wood shed, roughly 7 feet. I put down some #2 gravel and removed the pallets. Wood stays dry, but I gained a few inches of height and less walking hazards from pallets.
  11. T.Jeff Veal
    It depends on how much room you want to take up and materials you have on hand. If you can keep the pallets off the ground they will last a long time. If your wood is dry, stack it tight.
    The first shed is 7 1/2 ft wide, 14ft deep and about 6 1/2 high on low side. It holds 5 cords, 9 rows of 18" wood, with scrap OSB on top of pallet floor, next two raxks are built from 50 x 50 pallets, so they hold 1 full cord per side. Fairly cheap to build.
  12. bushpilot
    bushpilot
    Eastern Washington
    Yep, this ^^^.
  13. Highbeam
    Highbeam
    After many years of double rows on pallets I’m moving to a woodshed. These rows are each about 1.25 cords and have sat there for 2-3 years waiting to be burned. I moved up to foam pallets that don’t rot and you can’t step through.
  14. billb3
    Can't say it is the BEST way, but having very similar materials on hand as milleo that's pretty much what my stacks look like.
  15. milleo
    milleo
    Thanks I think thats from 2014....I have a lot more wood and once it is 3 or 4 years dry I move what I burn for the winter into the garage...:)
  16. james.crowton007
    james.crowton007
    Has anyone heard of a website going around that you pay 25.00 a year and they are supposed to email you when free firewood is available from a few companies?! Thanks guys
  17. billb3
    This one in Cleveland ?
    About Us
  18. Midwinter
  19. Backwoods Savage
    Welcome to the forum James.
    I'm no help with what you are looking for but good luck in finding them.
  20. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Mine is two rows with pallets up on blocks. Those pallets are around 4-5 years old. I have firewood, not pretty wood.:D
