Hearth build
Discussion in 'Modern EPA Stoves and Fireplaces' started by BigPapi, Jul 26, 2018.
  1. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    If it’s too low then it must be treated as an alcove location (codes for that).
  2. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    My upstairs stove.
  3. Canadian border VT
    I think you need the IS at the highest setting in order to use the ash pan. In my opinion you definitely want the ash pan. If going out.. Consider going straight out back then up.. Like Backwoods Savage a stove top thermometer and cat probe will give you all info you need at front of stove..
  4. Chaz
    Chaz
    Southwestern NY
    IS doesn't have to be @ highest setting for the ash pan. I believe we are at the second lowest setting with ours.
    Our stove sits at 31.5" from durock to stovetop.
    Still debating on our hearth build as well, so I'll certainly be watching for ideas.
    :popcorn:
  5. Canadian border VT
    Chaz thanks for correction!! Good to know!!
  6. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Is it a corner install?
  7. BigPapi
    BigPapi
    The hills of Western MA
    Not a corner install. It will be against an exterior wall.
    Nice setup on the upstairs stove there, Buckthorn.
  8. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Thanks. Corner installs present more challenges, usually.
    Are you going to make a fire wall with 1” of air gap behind the stone?
  9. BigPapi
    BigPapi
    They do - we considered a corner install but would have wound up running the chimney in the front of the house, or moving the place where electrical service enters. Neither of which were we interested in!
    With the rear heat shield Woodstock lists the IS as 6" clearance in back, so unless the chief or insurance want to see a gap, we will likely not build with one.
  10. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Sounds good. Our stove is close-clearance as well. The stovepipe is double wall so that can get close, too.
    We wanted overkill plus the idea that we may eventually change out our stoves. The NFPA regs are a good read before ya start building.
    Maina, BigPapi, papadave and 5 others like this.
  11. wildwest
    Dear Husband is overkill on safety. I appreciate that. Not afraid to cut a corner on certain non-dangerous things, but safety- we both agree on overkill.
    Maina, BigPapi, papadave and 7 others like this.
  12. BigPapi
    BigPapi
    Made some decisions over the last few days. We'll build the pad from 2x10for a final height of about 12". 12x24 slate tile for the pad, airstone for the vertical surfaces. At 12" we can adjust the legs as needed to get the right final height, before cutting in the chimney of course. Mrs Papi felt this would be the easiest height for her to sit in a chair and load if necessary.
    The raised section will be built a bit more shallow than the hearth pad, and will be constructed with 2x8 on top of 2x10, for a finished height around 17".
    MA has a tax free weekend coming up, so we'll purchase supplies then to save some coin. Stove should be ready shortly thereafter, then we can schedule the chimney man.
    Pics to come, of course. ☺
    Maina, Eric VW, wildwest and 5 others like this.
  13. Scotty Overkill
    If I may make a recommendation, I'd go with a raised hearth if at all possible....
    I'm seriously considering raising the hearth in my kitchen. The older I get, the achier my joints get, and it's easier loading, cleaning, and viewing a raised stove...lol
    OhioStihl, Maina, BigPapi and 7 others like this.
  14. Chaz
    Chaz
    Southwestern NY
    He is doing a raised hearth, or that's the plan.
    Not sure this is the best idea, our IS can put out some heat.
    Looking forward to the final design.
    :yes::popcorn:
    Maina, BigPapi, Eric VW and 3 others like this.
  15. Marvin
    Marvin
    Huntingdon, Pa
    Looking forward to this one :yes:
    Maina, BigPapi, Eric VW and 2 others like this.
  16. Mwalsh9152
    Mwalsh9152
    Pelham NH
    Sounds like its gonna be sweet! Cant wait to see it. If the finances work out, I'll be redoing my hearth and wall next year, sounds like we have similar plans for stone.
    Maina, BigPapi, Eric VW and 1 other person like this.
  17. BigPapi
    BigPapi
    Part one done. Frame for the main hearth pad is done. It's 48x42, framed with 2x8, 11" on center, 3 /4" plywood on top, which will get two sheets of durock, mortar, and slate tile for a finished height of 9 3/4". It was nice to have help. ;)
    -edit- Those are Mrs Papi's pink toes in the shot. I don't work in flip flops.
    Maina, Eric VW, brenndatomu and 5 others like this.
  18. Chaz
    Chaz
    Southwestern NY
    And.. wait for it.
    :D
  19. Eric VW
    Do you own a pair of slippahs?
    bobdog2o02 livs seeing pics of men’s slippahs....:whistle:
  20. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Nice platform and Genny.
    Maina, BigPapi, wildwest and 2 others like this.
