Ok, so that's a big-bore 460.
Discussion in 'Chainsaws and Power Equipment' started by Jon1270, Apr 3, 2014.
  1. Jon1270
    Jon1270
    Pittsburgh, PA
    I'm checking another model off my list of coveted saws I need to try. I bought this saw as a box of parts last fall, and just finished putting it together today. What the previous owner thought was a broken connecting rod turned out to only be a shattered piston skirt. The worm gear for the oiler was shot and the clutch showed signs of having gotten a little warm, so my guess is that he just kept cutting after the oiler quit and the chain tightened up, and that put the extra stress on the engine that triggered the failure.
    Thankfully the cylinder was still in fine shape. After removing a few chunks of piston from the crankcase I pulled the seals and rinsed about half a gallon of gas through the bearings while rotating the crank to rinse out any remaining particles of stray aluminum. Everything felt tight and smooth, so it got new seals, piston and base gasket. Passed the vac & pressure tests, so the rest of the parts followed, with a new chain catcher and spark plug boot. I was able to try it out on a blown-down cherry trunk at the end of my street, just before the rain hit.
    SolarandWood, thistle, Boog and 4 others like this.
  2. MasterMech
    How stock is that muffler? I've said it before, dual-port swap is almost mandatory on a 460.
    clemsonfor, HoneyFuzz and Pyroholic like this.
  3. Jon1270
    Jon1270
    Pittsburgh, PA
    It's totally stock, and the front is a bit mashed in so it could stand replacement anyhow.
    HoneyFuzz likes this.
  4. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Awesome... there's a basket-case 460 I may end up with (free). It'll need a case split and possibly a crank? I'm not sure if I'm up to it yet, but who knows. If I do it, it'll be all aftermarket parts (despite what I've been reading about AM cranks haha)
    Good job on the rebuild. Nice saw!
    clemsonfor likes this.
  5. DexterDay
    Nice job!! :thumbs:
    If you want around 15% more power, do as MasterMech says, or Hog out the stock opening. I have 3 separate ports on mine. Left side, right side, and the cover. :saw:
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Sweet !
    Chvymn99, mdavlee and DexterDay like this.
  7. nate
    nate Banned
    Palmer, AK
    The issue with messing with the muffler is it makes it LOUD!
    I have a dual port in mine and you can't use it without ear pro. Not the end of the world to me, but chainsaw noise carries far.
    It at idle drowns out my 660 with stock muffler at WOT to give an idea.
    mdavlee likes this.
  8. clemsonfor
    You should be using ear protection with any saw!!! My ears use to rung after running my 390 stock. Now I use muffs all the way.
    My 650 with hogged out port and DP cover is loud!!! I can't hear my music in the muffs very well cause of it!!
    Chvymn99 likes this.
  9. MasterMech
    Paging Swags....... Swags to aisle 3 for customer assistance.......
    Sean is running a big-bore 460 with the DP muffler. While I acknowledge that they are loud, they weren't obnoxiously so.
    And Clem is right, there hasn't been a gas powered saw made that that you should be running without hearing protection. In the shop, I might make a test cut or two without the muffs but no more than that and some saws have a pair of ear muffs with them at all times. (Like my 1050.....)
    clemsonfor, mdavlee and Chvymn99 like this.
  10. MasterMech
    The aftermarket DP mufflers are cheap and work great. If you get one with an internal birdcage, cut it out before you install the muffler.
    mdavlee likes this.
  11. nate
    nate Banned
    Palmer, AK
    I guess I didn't explain well enough.
    Yes the operator should have on ear pro. But how many stock saws have you run that you NEEDED it?
    NEEDED as in start it up and first thought is holy crap I'm going deaf.
    I wish I had a decibel meter. I wouldn't be surprised if to follow OSHA regs it was loud enough that a person should have dual hearing pro. (Foamies and muffs).
    Point I was making is that even a stock saw noise carries far. With a minimal muffler if you have any neighbors in a mile or two radius they will hear it for sure.
    Picture guy down the street reving and opened header car for several hours... about the same.
    Just something to consider is all.
  12. HDRock
    Hmm , Interesting! ! ! , I have a sound level meter.
    Never used it for testing chainsaw decibels.
    I could test the saws I have, and ship it out and pass it around for other testing
    BrianK and clemsonfor like this.
  13. Chvymn99
    Lookin' good.:thumbs:....
  14. DexterDay
    When I met up with member Rookie1 yesterday, he showed me a pretty cool saw. One I had never even heard of. It was an 023L. Its a special model that is designed to be quiet. It has a baffle/snorkel on the intake, and a baffle in the exhaust.
    Its supposedly only 68 decibels at 50 ft. He started it, and I was blown away how quiet it was.
    I'd be interested in how loud certain models are.
    Got Wood? likes this.
  15. HDRock
    50ft ?? Really?
    Who runs a saw from 50 ft?
    More like 2 ft
    I don't run my router, table saw, planer, jointer, at 50 ft
  16. DexterDay
    I think it is on there for the people around you. So if you live in a development, you could run the saw and not bother your neighbors.
  17. HDRock
    OK, I get that
    My objective is focused on operator , Potentially dangerous decibels.
    Mostly I have used my sound level meter for audio tweaking
  18. MasterMech
    Some neighborhoods, usually rather well to do neighborhoods, have noise restrictions in place. Commercial landscapers operating in those neighborhoods need "quiet" tools to get the job done without pizzing off Mrs. Pinesackle across the street, whom is already displeased that there is a nasty pick up truck parked across the street......
    Quiet blowers and saws in addition to cordless and electric tools get it done.
    It all depends on whose Jungle you play in.
    HDRock and clemsonfor like this.
  19. Got Wood?
    Got Wood?
    Amarillo, TX
    My McCulloch 10-10s is pretty loud. That thing lopes like a big block!:saw:
    thistle likes this.
  20. Jon1270
    Jon1270
    Pittsburgh, PA
    I try not to push my luck too much with the chainsaw noise, but my neighborhood is close to a major road so nobody expects to be able to hear crickets chirping anyhow. The houses are mostly brick or stone and damp sound pretty well. I wait until after 10AM on weekdays and noon on Sunday before firing up a saw, and nobody has complained yet.
    Even with the stock muffler, the 460 seems considerably louder than my 361 (also stock).
    clemsonfor and DexterDay like this.
