1960 bath face lift
Discussion in 'The DIY Room' started by wildwest, Jul 22, 2018.
  1. TurboDiesel
    I'm here.
    But I'm not young...o_O
    Yes. Good solder!!!
    This one![​IMG]
    Might be $50 dollars a roll...but...Everything else...SUCKS
    Wolverine flux
    Like this[​IMG]
    And find an acetylene torch
    Burnzomatic, Goss or TurboTorch. As long as it has a hose and doesn't screw right on the torch tank like this.
    If you want a leak, try this style torch...:zip: I can't even solder with one of those...:hair:
  2. TurboDiesel
    Oh... and mesh sand cloth...only MESH sand cloth.
    Looks like this and its only a few bucks
    You'll need a 1/2 and 3/4 inch wire fitting brush also.
    Looks like this
    and don't try to use old dark stained or green corroded copper fittings.
    Chvymn99, papadave, basod and 7 others like this.
  3. TurboDiesel
    Clean the copper pipe and fittings till there is no shine or dark staining.
    (Like this but use the mesh sand cloth. I prefer well used mesh so it's not so aggressive)
  4. Eric VW
    I use -
    And for heat-
    And if there’s still water in the pipe, balled up white bread (not white wheat or any of those “artisan” breads) as a plug... works like a charm.
    :yes:
    Obviously, Timbalina, the young lady ( aka TurboDiesel :D ) shares great knowledge and skill.... just saying that my brother and I did some very high end control boards still in service (14 years running) with what he showed me how to use.
    But to Tim’s credit, my brother always said a tank setup (for heat) was best. :thumbs:
    :salute:
    Chvymn99, Mitch Newton, basod and 7 others like this.
  5. brenndatomu
    Yup, mapp gas cyl works, but "the hose" Tim spoke of makes working in awkward positions SO MUCH easier! :yes:
    fuelrod, Chvymn99, basod and 6 others like this.
  6. Eric VW
    Agreed:)
  7. J. Dirt
    J. Dirt
    How about this one? It’s got a hose!
    D8FDD2B2-3C52-477E-98E8-3436B3141E3E.png :loco: :crazy::wacky::dancer:
  8. TurboDiesel
    Bingo!
    You can't turn a propane tank/torch upside down. And when you're in a tight spot, like against a wall, or plastic tub surround, you'll need to heat from behind the fitting so you dont burn the drywall or melt the tub wall...
  9. TurboDiesel
    that one is good for soldering 2" and up.
    ...and starting forest fires:rofl: :lol:
  10. Canadian border VT
    TurboDiesel my apologies for doing this on phone and referring (through incorrect punctuation) to you as young lady. :eek: your not young and NOT a lady.
    I obviously meant wildwest ..
    I am in construction mode on a cane doing electrical, plumbing and sheet rock:faint:..
    This is hilarious :rofl: :lol::rofl: :lol:
    I can say this.. At least the handicapped are fun to watch work.. I wish I had it on video.. For posterity!!
    Ill post a thread when done and can get to computer! But a quick pic
    Thanks for posting pics of good solder and flux.. My phone Dosent do that well.. Heck I got to clean screen now because of dirty fingers..
    Chvymn99, J. Dirt, papadave and 3 others like this.
  11. TurboDiesel
    worry not, brother. I knew what you meant....and we got a good laugh out of it!:rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
    Chvymn99, J. Dirt, papadave and 2 others like this.
  12. TurboDiesel
    and for the record ... I hate shaving my legs...
    :bug:
    :picard:
  13. papadave
    Ah jeez, almost spit out mah coffee. :rofl: :lol: I hate wasting good coffee.
    Chvymn99, Chaz, TurboDiesel and 2 others like this.
  14. J. Dirt
    J. Dirt
    X2 o_O
    Chvymn99, brenndatomu, Chaz and 2 others like this.
  15. papadave
    TMI.....
    Rule # 8,374........there shall be no pictures posted on FHC of Timbalina shaving his legs.:yes:
  16. wildwest
  17. wildwest
    Bumbling day here, one thing after another, lots of work and little progress deal, you know? :rolleyes:. Anyway, I give up on Lowes website. I found a great little vanity with a top for $59, great, the order finally went through :yes:, I wanted to keep it all at Lowe's so WWW didn't have to make two stops in Cheyenne (he'll be doing it on his lunch hour), but for the last few days I've tried to look there it takes forever to go from one page to another and often errors out. Actually I did have an order placed at Lowes the other night, then received an "order failure" email, sorry, we'll send you a $15 gift certificate in the mail. I've added a tub/shower fixture kit and bath sink and accessories 2 nights in a row, both nights my basket was emptied the next morning though it said 30 days. Ok, thanks, but looks like he'll be doing a pick up at Home Depot too. Same model for the shower a couple bucks less, different model on the sink also a couple bucks less.
    I'll have recreate my research on accessories but I'll do that at Home Depot. Within budget so far anyway:)
  18. wildwest
    I found the plumbing box, but couldn't get it down, I'll look later after WWW gets the box off the shelf. There is infact Bernzomatic, but I didn't see the torch (yet). Hey, guess what! Some of the disappearing plumbers putty cans and teflon tape rolls are are in there :rofl: :lol: Also a few new valves. Hopefully the brushes and pipe cutters are in there too. TurboDiesel , what makes that solder quality opposed to others? The flux can feels empty, its dinged up so I can't open it, ( I may or may not tend to use solder for many crafts/projects/rigging that have nothing to do with plumbing :emb: ) Eyeing this:
  19. TurboDiesel
    First you want the solder to be "lead free" which is all you can buy now...
    BUT, the "silver bearing" solder has a lower melting point, quite similar to the old 50/50 lead solder, which was very easy to use since it would flow around the joint very easily and evenly. :yes:
    Look for Sterling, Worthington or Lennox.
    They all have the same purple label.
    Chaz, brenndatomu and wildwest like this.
  20. TurboDiesel
    Looks like there are other brands with the same contents. We only buy the Sterling.
    The boss told me a couple weeks ago he paid $1200 for a case...:bug:
    Chvymn99, Chaz, J. Dirt and 2 others like this.
