  1. Luneyburg
    Luneyburg
    Hills of Central Mass
    Ditto CF as usual I am late to the party , sounds like you had a good one man !
  2. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Took my Model 60 Marlin to a smith today spending about $45 to have the action cleared,cleaned and oiled it had a shell jammed in it the last couple of years from when I couldn't get the bolt all the way back. Weak was I. Not bad for a '71 or so Model 60. The stores I bought my guns at are long gone.
  3. subsailor
    subsailor
    Winthrop, Maine
    Caliber?
  4. Earl764
    Earl764
    CT
    Bear size.
  5. imacman
    imacman
    Denver, NC
    .22 LR
  6. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    It was only made in one Caliber that I knew of .22LR.
  7. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Only if you are good enough, otherwise you'd just get them bears mad at ya...
  8. Luneyburg
    Luneyburg
    What a day out waking the dog sitting on a bench in the Lunenburg common Glorious day IMG_0124.JPG
  9. ttdberg
    ttdberg Pellet Pig
    CT
    Couldn’t ask for better weather than we have here this morning. 70° and a slight breeze to keep the bugs away. Took the dogs for a two hour walk. Enjoying every second of it because starting tomorrow we’re slated to get a week of humidity and rain.
  10. jtakeman
    :tears:
    We do need some rain though............... At least its before my vacation starts! :D
  11. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    No vacation for this Bear.
  12. imacman
    imacman
    Denver, NC
    :thumbs: :coldone:
  13. bogieb
    Calling this project done. Do need to repaint the bird bath so it blends in better, but its probably 30 YO - I found it in an overgrown garden over by the swamp when I moved in. The broken pedestal (I assume they belong together) has sat in the back on the other side of the house since I moved in. Anyway, I digress, here is my finished sitting area that catches a nice breeze.
    From the back porch (with a little zoom)
    From directly in front of it
    The right side log planter where I placed two Oriental Lilies and to either side are columbines. The previously planted ferns are there (except the one that something dragged off o_O) and I moved the poor sunburned hosta (on the right) from the driveway garden to this shaded area last weekend.
    The left log planter has two oriental lilliws. In the middle is a columbine and to the right is creeping winter berry. You can't see the foxglove that I blanted behind the planter a couple of weeks ago. It is spent, so I didn't feel too bad - besides, none of this was planned, it just happened, and I can always move the foxglove next year. finished left planter oriental lillies-columbine-creep winter berry.jpg
    Those log planter have been in my shed since TSC had a wicked fall sale last year. I picked them up for around $20 each. Didn't have a plan for them, but figured I would find a use eventually :thumbs:.
  14. gbreda
    gbreda
    NH
    Removed the saddle valve for the fridge water line and installed a sharkbite ball valve today.
    It was a tight fit as there ave several tee's close to the cut which meant not much pipe movement to work the new valve in. I had to put more side pressure that I wanted on the pipes to get it in but in it went. A sudden slight quick movement made me say oh chit, hope I didnt break a solder joint somewhere. Dont see any issue and so far so good.
    20/20 hindsight when I put in the saddle valve years ago and I would have put it on another long pipe run about 6 feet away that would have been soooo much easier to get the new valve in. Had to plug the saddle valve hole ( cut that part out and put the valve there) so there was no choice.
  15. schoondog
    schoondog
    Dutchess County N.Y.
    Nice work boieb !! I feel more relaxed by just looking at the pics.!!
    Doggy
  16. corkman
    corkman
    Southeastern mass
    Spent the morning with my good friend and our boys on a charter boat out of Plymouth Ma. Got 2 keepers. 34” and 36”
  17. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    It's raining, it is pouring the old Bear is snoring!!
  18. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  19. imacman
    imacman
    Denver, NC
    Partly cloudy/sunny, 84*, humidity is at 65%. Chance of rain & boomers....... Pretty much repeat this for the next 10 days. :confused:
  20. will711
    will711
    Pocono Mts.
    No like that Pete :hair:
