Huzel 365/372
Discussion in 'Chainsaws and Power Equipment' started by Oldman47, Jun 25, 2018.
  1. Scotty Overkill
    I think Czed touched on one of the most important points when he said about looking at the exhaust and intake ports on the Hutzl/FarmerTec cylinders for sharp edges. Use a Dremel with a small burr and soften up any sharp edges around those ports, then do a good clean out of the cylinder.
    I learned the hard way on a Stihl 034 build I did last summer using a FarmerTec P/C, luckily all I ended up doing was breaking the rings......
  2. Czed
    Czed
    Wv
    15304608074081128164685.jpg I've been cutting 1/2 inch from the bolt tubes on each side.
    To allow more flow
    Noise isn't much louder at all
    And i can tell a difference when cutting.
    Just on the 5.00 china mufflers
    Oem one's get deflectors lol
  3. Czed
    Czed
    Wv
    Walt suprised me
    When he was telling me his first
    Clone 372 is still in use logging
    All china bearings etc.
    It's outlived a few oem 372s
    In that environment
    That's impressive.
    I did have a coil fail recently
    And the huztl replacement was junk.
    Husky used oem 345 346 350 353 etc
    . Coils
    Are easy to find and are interchangeable
    With a 372.
  4. huskihl
    huskihl
    Yep I've used a few HLS coils for the 350 and they've been good. Hard to justify AM when you can find used oem for $15 delivered on the bay. Asian coils for a 394/5 are junk out of the box so far. If someone finds a good source for them please let me know
  5. Czed
    Czed
    Wv
    Tell us how it turns out.
    M2theB and clemsonfor like this.
  6. Oldman47
    Oldman47
    Illinois
    So far I am a bit disappointed in the quality of the cylinder casting.
    According to the Huztl Customer Service folks, their tech support guys figure it will work just fine and I can say that when I test fit the intake boot to it there seemed to be a nice secure fit. I will be using some Yamabond to make sure I get a leak proof connection.
    M2theB, clemsonfor and Mag Craft like this.
  7. brenndatomu
    Yamabond 4...that's good stuff! :yes:
  8. Oldman47
    Oldman47
    Illinois
    Well, I dug in a bit more today and found I need to wait until Monday to get a new 6202-c3 bearing. The one on the right side, clutch side, feels a bit rough and I am not going to assemble this kit just to take it back apart. The only local source for that bearing is closed on weekends and only open from 8:00 AM to 4:30 PM during the week.
    Repeat after me, "It is nice to live in a small town".:hair:
    M2theB, clemsonfor, LongShot and 2 others like this.
  9. Oldman47
    Oldman47
    Illinois
    Update: When shops opened on Monday, none of them had a 6202-c3 but they offered me a 6202-2rs instead. I really didn't want to pay for seals I would just end up trashing and did not want the tighter fit of a 6202 that was designed to run with grease at low RPMs even though I could have removed the seals. I ended up ordering a new bearing on line for under $10 including shipping for a Japanese manufacture 6202-c3 from vxb.com. Now I need to wait for Friday to move forward.
  10. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    eBay bearing shops are the way to go if the local guys aren’t open or don’t have it in stock.
    M2theB and Mag Craft like this.
  11. Oldman47
    Oldman47
    Illinois
    So I ended up with an internet sourced Japanese Nachi bearing and made some progress. Now I am waiting on the o-ring that seals the output shaft side that Farmertec does not include in their "total" package. I have been following the "step by step" videos by "Matthew Olson" to make sure I don't miss something along the way. I also found an intake replacement video by "Donyboy73" for the model 365 that showed me a great trick for getting that hard to place intake boot on the divider of the plate that sits under the carburetor. I did modify the trick a bit by doing his maneuver when the cylinder was not quite all the way down onto the casing.
    I was totally bummed out when I tried to slide the cylinder on over the piston but decided to try it again today before buying a special ring compressor tool and patience got it done this time. I had already decided that getting both rings where they needed to be was not going to be easy even with a ring compressor because the rings were so close to each other.
  12. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Ring compressors are the way to go. It takes a bit of maneuvering to get everything in position, but man it’s easier than zip ties or screw drivers.
    Nachi bearings are excellent quality and are priced at the right point in my opinion.
    M2theB, clemsonfor and brenndatomu like this.
  13. Czed
    Czed
    Wv
    Have you finished the saw?
  14. clemsonfor
    These threads are cool and those are great tips and a great saw at a great price.
    M2theB and Czed like this.
  15. JCMC
    JCMC
    Just outside of Shushan, NY
    Great thread with lots of great Info. Thanks for postin.
    M2theB, Czed and clemsonfor like this.
  16. Czed
    Czed
    Wv
    Running a bigbore with a 28 inch bar
    Dropping poplar 20181012_160124.jpg and oak
    It's been a very good running falling saw.
    I've got under 300.00 in it
    Well worth it to me.
    M2theB and brenndatomu like this.
  17. clemsonfor
    I didnt see the oak till i pulled my screen down. I was like ummm thats oak. Haha
    M2theB likes this.
  18. Czed
    Czed
    Wv
    Bump
    Scotty Overkill and M2theB like this.
