Huzel 365/372
Discussion in 'Chainsaws and Power Equipment' started by Oldman47, Jun 25, 2018.
  1. Oldman47
    Oldman47
    Illinois
    I probably did a bad search job but has anyone done the kit saw of a Huztl 365/372 and documented it here? At about $110 I couldn't pass up their present sale. If this saw goes together as well as the Huztl MS 660 that I did, I will be happy.
    clemsonfor, M2theB, Horkn and 5 others like this.
  2. moresnow
    moresnow
    Betcha I know of a different site that would provide that info.:whistle: Also guessing you have been there!
  3. Eric VW
    clemsonfor, Horkn, Armbru84 and 2 others like this.
  4. Redfin
    Redfin
    central Pa
  5. Oldman47
    Oldman47
    Illinois
    Yes there are other places where they discuss chain saws. I would prefer to find what I am looking for here if I can though. I rather enjoy this place when I am in a wood/saw mood.
  6. huskihl
    huskihl
    Czed Dave has 5 or 6 of them. He'll be along shortly to let you know what's good and what should be replaced
    clemsonfor, Horkn, Eric VW and 2 others like this.
  7. Czed
    Czed
    Wv
    No expert lol
    I've only built one huztl 372 big bore
    The rest were 365 built saw's
    I converted to 372s.
    All of the supplied china fuel and pulse
    Line's have failed.
    I swapped them out for echo 3x6mm
    Fuel line.
    Intake boots and seals have been fine.
    I broke several starter ropes so i bought
    A roll of true blue 4.5.
    Cut most of the "g"off the circlips
    They are a common weak point
    Oem circlips are preferred.
    The china pistons have held up great
    The rings no
    I swap them out for cabers or oem
    1.2 for the double ring pistons.
    1.5 for the 268 and 272 popup pistons
    I use in some of mine.
    I used motoseal on the case gasket
    And to delete the base gasket.
    The china crank bearings have held up
    Great.
    Some use nachi skf or fag bearings. 20180618_184707.jpg 20180616_192048.jpg 20180625_184109.jpg 20180326_124138.jpg
    No problem after that I've been cutting for a year with them
    Not oem but well worth it to me
  8. Czed
    Czed
    Wv
    20180623_154315.jpg 20180623_144658.jpg The wrist pin bearings at least on mine
    Are odd
    They are larger diameter than oem.
    But the id is the same.
    They resemble clutch bearings
    Just longer.
    So i bought oem clutch bearings
    And used them as wp bearings.
    The bottom bearing is oem.
    The farmer tec/huztl cylinders
    Usually are good to go
    Check for sharp port edges
    And casting flash.
    The squish is usually more than
    Oem.
    That's why i run popups
    To get good comp.
  9. Camber
    Camber
    Montana
    Wow czed! Way to go. Talk about getting things dialed in! If that isn't professional, I don't know what is. You deserve a salute.:salute:
    I usually lack the patience when switching from OEM, to unknown.
    clemsonfor, Horkn, Eric VW and 4 others like this.
  10. Czed
    Czed
    Wv
    20170513_175708.jpg 20180616_091522.jpg 20180623_124354.jpg 20180523_101007.jpg 20170930_130403.jpg a few failures I've had
    Hemostats make it easy to swap line's and rope
  11. Czed
    Czed
    Wv
  12. Armbru84
    Armbru84
    Sparta, Michigan
    Czed has me covered :thumbs:
    A lot of what I have read he covered with the weak points. So some small upgrades to certain items and they seem to run pretty good.
  13. huskihl
    huskihl
    Walt just posted a vid on ope. Huztl 372 with 1 tank of fuel through it put a hurtin' on a 372 xtorq in 14ish" ash.
    An unscientific farmer Jones hurtin' at least
  14. 94BULLITT
    94BULLITT
    Frederick County, VA
    I thought about getting one but the shipping is $80.
    clemsonfor, Horkn and brenndatomu like this.
  15. brenndatomu
    Even through HL Supply?
    clemsonfor, 94BULLITT and Horkn like this.
  16. 94BULLITT
    94BULLITT
    It is like $250 plus shipping from HL. $80 isn't bad for shipping a saw around the world, it just makes more than I want to spend on it right now. It will turn into $300 by the time I do a few upgrades and get a bar and chain.
  17. Oldman47
    Oldman47
    Illinois
    No pop up piston for me. I just want to build a basic saw.
    Right now the 372 kit is on sale at Huztl for 110 plus about 80 shipping. It is not the 250+ that 94bullit noted. I have to agree that the B&C will add to the total 190 that I have spent so far.
    M2theB, clemsonfor, Horkn and 4 others like this.
  18. Czed
    Czed
    Wv
    They're easy to work on saw's
  19. brenndatomu
    Yes they are
    M2theB and clemsonfor like this.
  20. Czed
    Czed
    Wv
    Once you learn these saw's
    They are a money maker
    Buy oem saw's that need rebuilt
    And flip them.
    I'm doing this 99 371xp
    It's getting a meteor with cabers
    Fuel and pulse echo line.
    China Seals muffler and throttle cable.
    Rebuilding this for a friend.
    He painted the bar orange
    And it stuck to the bar plate lol 20180628_144458.jpg 20180628_151436.jpg 20180628_151016.jpg 20180628_162705.jpg 20180628_172652.jpg one of the fastest saw's to rebuild as well
    M2theB, Oldman47, Horkn and 3 others like this.
