Help with a splitter part
Discussion in 'Chainsaws and Power Equipment' started by glorth2, Jun 16, 2018.
  1. glorth2
    glorth2
    Perkasie, PA
    So I wound up picking up a 22 ton Huskee splitter from eBay. Thing is doing a great job so far. I can't believe how much more efficient I am. However, the other day I see this screw/washer combo part there laying on the beam and I see the empty screw hole shown below. It looked obvious so I screwed it back in and called Speeco to try and get more information. A couple days go past with no callback. Next thing, the screw has fallen out again and now I can't find it. I call them back and get someone. He says I should be OK but to get to a hardware store and find a screw with matching threads to put in there. So, I WILL do that but, what is this thing? I don't see it on any parts list in the manual and I don't see any fluid near the hole or anything. The guy said it held a seal in place or something. Thoughts? TIA.
    Backwoods Savage, Eric VW and Horkn like this.
  2. brenndatomu
    That would have been my guess was that it helps lock the end cap and maybe the snap ring in place. Never seen that before, doubt it was added after the factory though...
  3. Horkn
    Yeah it appears to be a "lock" so that the seal cover retainer doohickey can't back off.
    I'd just put some blue threadlock on it when you get a new one from the hardware store.
  4. Horkn
    I'm guessing 3/8- 16 thread?? Unless my scale is off. You know about how long the bolt was, so go off of that as reference.
  5. Eric VW
    Have access to a metal detector?
  6. brenndatomu
    It could be...but a 3/8" screw with a phillips drive head would be an unusual screw...my guess would be 1/4"...probably NC (20)
    Horkn, huskihl, Eric VW and 1 other person like this.
  7. glorth2
    glorth2
    Perkasie, PA
    This is a great idea. Let me check Facebook.
    Horkn, brenndatomu and Eric VW like this.
  8. brenndatomu
    I'd probably check the garage first...but whatev's :whistle: ;) :p
    imwiley1, Horkn, Chvymn99 and 4 others like this.
  9. Fifelaker
    Fifelaker
    Fife Lake Mi.
    I noticed that bolt missing one day while splitting, I finished the day without it. When I got home, I put a 1/4" 20 with a drop of blue loctite on it and it has been there ever since.
    Horkn, Chvymn99, basod and 4 others like this.
  10. JCMC
    JCMC
    Just outside of Shushan, NY
    Or a magnet?
    Horkn, Chvymn99, huskihl and 2 others like this.
  11. triptester
    triptester
    S.E.Wisc.
    The bolt and washer is there to prevent the front cap from being accidently pushed in exposing the lock wire that retains the cap. Any bolt that fits will work just have to determine if SAE or Metric.
    Horkn and glorth2 like this.
  12. glorth2
    glorth2
    Perkasie, PA
    Thanks. I have to admit, I'm not 100% sure I follow. My buddy came over with a metal detector. We found the screw and the flat washer but not that thicker washer(?) that goes in between the flat washer and the end of the cap(?) there. I got a few regular flat washers to stack...and loctite. Drives me nuts that this thing brought me to a grinding halt.
    Horkn likes this.
  13. glorth2
    glorth2
    Perkasie, PA
    So, on the plus side, used a couple small washers to replace the thicker one and everything's been fine. Even found the missing part. Then, earlier in the week, won't start. Never had a problem. Gas is fresh and everything but it just won't turn over. I'm thinking, try a new spark plug?
    Horkn likes this.
  14. Horkn
    Check the old plug first. Also, while the plus is out, pull it over 10-20 times. You may have a swigof bad gas or water. Also check the spark on the plug while pulling it over with the ignition on. Set the plug on the plug hole and see if it Sparks well.
    brenndatomu and glorth2 like this.
  15. glorth2
    glorth2
    Perkasie, PA
    Remove the spark plug and try to start it?
    brenndatomu and Horkn like this.
  16. Horkn
    Yes. Pull it over several times that way.
    TurboDiesel and brenndatomu like this.
  17. TurboDiesel
    make sure the oil is full and it's sitting level. it probably has a low oil cut off
    Horkn, bushpilot and brenndatomu like this.
  18. glorth2
    glorth2
    Perkasie, PA
    Yeah. The oil looks good. I'll revisit this this morning.
    Horkn and TurboDiesel like this.
  19. glorth2
    glorth2
    Perkasie, PA
    So, trying to start it with no plug seemed to have no net gain. Called the local auto place and they had the plug in stock. Picked one up, some oil I'd need anyway and a bit of Seafoam additive just in case. I hit it with everything. Started on the second pull. Back i action.
    stuckinthemuck, Horkn, Chaz and 2 others like this.
  20. Erik B
    Erik B
    Western Wisconsin
    Wonderful feeling when it turns out to be a fairly easy fix:thumbs:
