Bummer
Discussion in 'Chainsaws and Power Equipment' started by Stephiedoll, May 6, 2018.
  1. Stephiedoll
    Stephiedoll
    Omaha, NE.
    That sounds like a good idea. Saturday morning was the first time I've started it in some time, maybe June, & never checked the gas that was in it. My big bad. It started without a lot of effort, other than the compression wanting to pull my arm off. I know it needed some tuning, but not my strong suite, and even made the comment to the arborist I was helping that I needed to take it in for a tune-up. I should learn to pressure test, but right now buried at work so planned on new top end and take in for tuning. That sounds like a great offer and I may just take you up on it. Keep the ideas coming and I hope I can repay everyone.
    Horkn, brenndatomu and huskihl like this.
  2. Stephiedoll
    Stephiedoll
    Omaha, NE.
    I have little doubt that this is fuel related.
  3. Shawn Curry
    Shawn Curry
    Western NY
    An air leak would seem a lot like a tuning issue.
  4. 94BULLITT
    94BULLITT
    Frederick County, VA
    I heard the pistons in these kits were not any good. Have you heard this? I have not heard of any failures but the Hyway piston I put in mine when I rebuild it was beefier than the cross.
    brenndatomu likes this.
  5. huskihl
    huskihl
    No. Never heard of that. What probably happened was, on the downstroke, the rings hung on the exhaust floor and busted the top of the piston off.
    I've had Meteor, FT, and Cross in front of me at the same time and didn't notice anything alarming between them. Meteor was more shiny and may be more consistent in size, but I didn't mic them
  6. Redfin
    Redfin
    central Pa
    Its certainly worth a shot but the plating on some of these am cylinders is a crap shoot.
    You will probably find by the time the transfer is gone the plating is hosed.
    huskihl, brenndatomu and Moparmyway like this.
  7. 94BULLITT
    94BULLITT
    It was John Reilly that said that about the piston. The hyway piston I used had extra bracing cast into it that the cross didn't have.
    Sent from my SM-G950U using Tapatalk
    huskihl and brenndatomu like this.
  8. huskihl
    huskihl
    Don't know. Never heard of a failure I guess. Some of the finest builders I know grind 10 or 15 grams back out of the piston to lighten it back up.
    Horkn and 94BULLITT like this.
  9. amateur cutter
    Yes it does!!!!
    Chvymn99, Horkn and brenndatomu like this.
  10. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Cross kit ordered and I will be taking huskihl up on his offer, THANK YOU & I will let you know when it arrives. What else do people recommend that I order to complete the rebuild? I am going to check in to vacuum testing. When I first stared the saw last weekend it was running & idling great. Only reason I was thinking tune-up was for wide-open-throttle. I am told the current cylinder does not have a base gasket, do you recommend I get one for the replacement?
    Thanks again all.
    Stephanie
  11. brenndatomu
    Not unless the squish is too tight...whoever assembles it can check that for you.
    Horkn and Shawn Curry like this.
  12. huskihl
    huskihl
    Your old gasket will work if it's not beat up. Or you can assemble it using a sealant like motoseal. But you' have to check your squishband to piston crown clearance with thin electrical solder. Ideally, you want around .020 - .025". Others have done it and got .020. Mine was only .013", which isn' enough gap
    Horkn, Mag Craft, Shawn Curry and 3 others like this.
  13. Stephiedoll
    Stephiedoll
    Omaha, NE.
    It's here.:dex:Now just have to do some sweet talking to huskihl :emb:
    Hammy, basod, Horkn and 4 others like this.
  14. Stephiedoll
    Stephiedoll
    Omaha, NE.
    piston
    Hammy, basod, Redfin and 8 others like this.
  15. huskihl
    huskihl
    Pm'ed
    Hammy, Horkn, Chaz and 4 others like this.
  16. Stephiedoll
    Stephiedoll
    Omaha, NE.
    To those of you that ship saws on a regular basis, what shipping company do you use? Best rate?
    Again, thanks Kevin.
  17. Armbru84
    Armbru84
    Sparta, Michigan
    I always use USPS...but I know others sip Fedex and UPS. I think they are all pretty close.
  18. huskihl
    huskihl
    I always use USPS. No FedEx or ups drop off locations within 40 minutes of me.
  19. Redfin
    Redfin
    central Pa
    Make sure the piston does not bind sliding down into the bore. I have two Cross kits here where the bottom of the cylinder is way to tight.
  20. brenndatomu
    My chicom piston skirts kissed the crank just ever so slightly when I first checked it...enough to have caused problems for sure!
    Horkn, Mag Craft and Redfin like this.
